Trouble using PythonTex variables in Latex file
12 replies · 5K views · last reply
SamRoss
TL;DR
I defined a variable myvar = "hi" but I can't get it to render correctly in the pdf when I use \py{myvar}.
I'm using Visual Studio Code as my text editor. My ultimate goal is to use PythonTex in a Latex file so that I can generate multiple versions of the same worksheet for my class. As a test, I defined a variable myvar = "hi" but I can't get it to render correctly in the pdf when I use \py{myvar}. It just shows me double question marks.
Split-screen view: LaTeX source in a code editor on the left with \py{myvar} on line 13, and the compiled PDF on the right showing "I want this to say hi: ??".
When I hover over \py{myvar}, it says "Missing autoprint content". I have no idea what that means. Any help would be greatly appreciated. Thanks!
jedishrfu said:
Since that doesn’t seem to work, I saw an alternative that you could try:
Code:
\pyc{print(myvar)}
Good news and bad news. The good news is the question marks went away. The bad news is nothing took their place.
Side-by-side screenshot: left, a LaTeX source file with a pycode block setting myvar = "hi" and a line reading I want this to say hi: \pyc{print(myvar)}; right, the compiled PDF page showing the text I want this to say hi:
A more robust way to achieve your goal would be to generate multiple ## \LaTeX ## files from Python using a template, perhaps similar to this:
[CODE title="mark.tpl.tex"]
\documentclass{article}
\begin{document}
Hello \VAR{ name }, you got \VAR{ mark } out of 10.
Well done \VAR{name}!
\end{document}
[/CODE]
You can then iterate over the data for the students, either using simple code like this:
Python:
import re
infile = open('mark.tpl.tex')
template = infile.read()
infile.close()
students = {
    'alice.smith': {
        'name': 'Alice',
        'mark': 9,
    'bob.jones': {
        'name': 'Bob',
        'mark': 7.5,
    'charlie.robinson': {
        'name': 'Charlie',
        'mark': 8,
for student, vars in students.items():
    result = template
    for key, value in vars.items():
        # Substitute variable, allowing for optional whitespace.
        result = re.sub('\\\\VAR{\\s*' + key + '\\s*}', str(value), result)
    # Here we create a .tex file for each student, we could use os.system()
    # to pipe the output through tex to create to .pdf files directly.
    outfile = open('mark-' + student + '.tex', 'w')
    outfile.write(result)
    outfile.close()
... or using a more advanced template engine like Jinja. Note that Jinja is designed for HTML so you have to make some configuration changes to avoid conflicts with ## \LaTeX ## markup. There are some notes here although I don't know if they work (I do a similar thing but using node.js and mustache templates).
Edit: this code works for creating PDF files on my system (just add it after the last line above), it may need to be changed to suit yours:
Python:
    os.system('pdflatex ' + 'mark-' + student + '.tex')
Thank you for your response. This might be something for me to look into later, but right now it is beyond my meager skills. The immediate problem I'm trying to solve is to make those double question marks going away so I can define some variables and have latex render them correctly.
I was able to create a PDF containing the text 'Hello' from the following file
Code:
\documentclass[12pt,a4paper]{article}
\usepackage[utf8]{inputenc}
\usepackage{pythontex}
\begin{pycode}
foo = 'Hello'
\end{pycode}
\begin{document}
\py{foo}
\end{document}
using these steps:
Code:
> pdflatex test.tex
> pythontex test.tex
> pdflatex test.tex
After the first run of LaTeX I also had '??' in the output and a warning about missing autoprint text, but that is to be expected: '??' usually indicates that LaTeX is looking for something in a file which isn't there, usually because to create that file you must first run LaTeX on your document, then run some other tool which looks at the .aux file created by LaTeX in order to work out what it needs to do to create the file. Then you run LaTeX again.
BibTeX, MakeIndex and PythonTex all work this way.
Your LaTeX editor may not have a convenient way to run PythonTex, although you may be able to configure it to do so.
Thanks very much. This seems to
pasmith said:
...using these steps:
Code:
> pdflatex test.tex
> pythontex test.tex
> pdflatex test.tex
Thank you very much. I feel like I'm getting closer to solving this problem but I still have some questions. You said you used the steps pdflatex test.tex, pythontex test.tex, pdflatex test.tex. I'm not sure what you meant by that. Do you mean you converted the latex into pythontex and then back in latex? If so, how? Also, if my LaTeX editor does not have a convenient way to run PythonTex, how can I configure it to do so? Please bear in mind this is the first "configuring" I will have ever done so, if it is not too much trouble, a step-by-step explanation or a link to a webpage that explains it in a step-by-step manner would be very helpful. I tried searching for answers myself but was unsuccessful. Thanks again!
If you can achieve that you will have slain one alligator but I think you will have a long way to go to produce multiple PDFs each containing multiple substitutions from that one tex file.
I would encourage you to take another look at the solution I posted (forget about Jinja for now, the simple search-and-replace code I used works fine). This should help you drain the swamp in one go.
This stackexchange post explains how to get PythonTex to work with Visual Studio Code. It appears to require manually editing a JSON file in a couple of places.
I use TeXMaker. The user manual is here. Section 3 describes the basic process of compiling a document.
On the toolbar is a drop-down list of standard TeX-related tools, which can be run on the current document by pressing the button to the left.
Dropdown menu of TeX build tools listing Quick Build, LaTeX, Dvi->PS, PDFLaTeX (highlighted), BibTeX, MakeIndex, MPost, PS->PDF, DVI->PDF, Asymptote, LatexMk, R Sweave, XeLaTeX, LuaLaTeX, 1: PythonTeX, 2:, 3:, 4:, 5:.
PythonTeX is not one of these, but as you see I have set is up as the first user defined command. To do this, go to User > User Commands > Edit User Commands and complete the dialog as follows (setting up user commands is only mentioned in passing in the user manual):
Screenshot of the Edit User Commands dialog in TeXMaker: Command 1 is named PythonTeX with Menu Item PythonTeX and command pythontex %.tex; Commands 2 to 5 are empty.
To compile the document correctly, you must do the following:
- Run LaTeX or PDFLaTeX
- Run PythonTex
- Run PDFLaTeX again.
pasmith said:
This stackexchange post explains how to get PythonTex to work with Visual Studio Code. It appears to require manually editing a JSON file in a couple of places.To compile the document correctly, you must do the following:
- Run PythonTex
I did see that stackexchange post but when I tried copying and pasting the code, it didn't work. I downloaded TeXMaker and tried following your instructions but I'm still getting the same error. Here's what I did...
1. I entered the PythonTeX user command.
Edit User Commands dialog in a LaTeX editor with Command 1 named PythonTeX, Menu Item PythonTeX, and Command pythontex %.tex; commands 2 to 5 are empty.
2. I chose PDFLaTeX from the dropdown menu and then clicked on the arrow on the left.
Dropdown menu in a LaTeX editor with the selected entry PDFLaTeX, next to a right-pointing play arrow button.
3. I chose PythonTex from the dropdown menu (the one I just created) and then clicked on the arrow on the left.
Screenshot of a TeXMaker build menu showing a dropdown set to "1: PythonTe" next to a play-style arrow button.
4. I chose PDFLaTeX again and clicked the arrow.
Dropdown menu item showing a right-pointing arrow button beside the selected option PDFLaTeX.
5. I clicked the arrow to the left of View PDF.
Green arrow pointing right next to a dark button labelled View PDF with a dropdown arrow.
Here is the result...
Split screen: a LaTeX source file latex_scrap.tex on the left with a pycode block defining myvar = "hi" and a line using \py{myvar}; the rendered PDF on the right shows "I want this to say hi: ??".
I tried doing the same thing but with LaTeX instead of the first PDFLaTeX and I got the same result. Am I doing something wrong?
  • Screenshot of a build tool dropdown menu showing the selected entry PDFLaTeX, with a right-pointing arrow button to its left.
I'm sure I will have use for it once I'm more comfortable doing some very simple things. Thank you again.
