Troubleshooting a Simple C++ if/else Question for New Programmers
  • Context: C/C++
  • Thread starter Thread starter Saladsamurai
    C++
2 replies · 15K views
Saladsamurai
What is wrong with mine? I am super new to programming and am trying to figure this stuff out on my own. The stuff in the tutorial is even too advanced for me.
Here it is:
I am sure it is really easy to see, but I do not understand the error :confused:
The else statement has no if statement immediately preceding it.
The proper syntax is
if (boolean) statement else statement
You have
if (boolean) statement statement else statement
A simple rule that I use: Always use block statements (i.e., statements enclosed in braces) with an if statement, and never put the statement on the same line as the if. While C and C++ do allow simple statements after an if (or else), many organizations have programming rules that make this construct illegal. The cost of always using the block construct costs is a few extra keystrokes (there is zero performance penalty). The benefits are immense: It is clearer, there is a much reduced chance of introducing a bug, and you can insert break points on the if (or else) statement.
In other words, write it like this:
Code:
if (a < 10)
    y = a*b*c;
    cout << "blah blah" endl;
else
    y = a+b+c;
The use of the curly brackets and indentation really helps you keep track of what's going on, especially when you are using multiple dependent statements, ie:
Code:
if (i > 1)
    if (i = 3)
        cout << "i = 3";
else
     cout << "i is less than or equal to 1";
You also put parenthesis around the statement after else, which is not correct. Else does not make a test like if and else if does. Basically when you put something in parenthesis after if or else if you are saying if whatever is in the parenthesis is true, then do whatever is next. The statement inside of the parenthesis is not even testable, on second glace.
