Troubleshooting Intermittent Text Garbling on HP Laptop Screen
The discussion revolves around troubleshooting intermittent text garbling on an HP laptop screen, likely caused by issues with the video RAM or graphics subsystem. Users suggest several DIY remedies, including reseating memory chips and cleaning the laptop's internals with compressed air. Updating the video card drivers is also recommended, as well as testing with an external monitor to isolate the problem. The consensus indicates that the issue is related to character rendering rather than font data corruption.
  • Understanding of video RAM functionality
  • Familiarity with laptop hardware components
  • Knowledge of video card driver updates
  • Basic troubleshooting techniques for hardware issues
  • Research methods for cleaning laptop internals safely
  • Learn how to update video card drivers on Windows
  • Explore external monitor connection troubleshooting
  • Investigate video RAM testing tools and techniques
This discussion is beneficial for laptop users experiencing display issues, hardware technicians, and IT professionals involved in troubleshooting graphics-related problems.
anorlunda
Staff Emeritus
Homework Helper
Insights Author
My HP laptop screen is intermittently misbehaving 3 or 4 times per day. See an example below. But if I scroll that text off screen, then scroll back again, it renders correctly.
I'm wondering if it just might be a faulty connection.
Should I try to unplug/plug the cables to the screen?
Should I try to re-seat the memory chips?
What other DIY remedies might I try?
Computer science news on Phys.org
Is it cold temperature related?
It looks like the font data is corrupted which could mean a bad disk sector.
Someone here suggested updating the video card drivers.
https://www.computing.net/answers/hardware/text-on-vista-hp-laptop-screen-appears-broken/83369.html
You could also use compressed air to clean out the insides, and reseat any memory cards.
Then the graphic card drivers are OK. To me it looks like a video RAM problem - which again means the graphic card subsystem.
I disagree with the font data problem theory. Characters appear good some places and bad other places. Reseat the easiest connections first. Reseat everything before you consider other hardware problems.
Yeah I noticed that as I looked at it again today and started thinking maybe it’s an issue of graphics updates to the screen as the mouse pointer moves across it.
I couldn’t find a good reference that described the problem though.
If you can connect another monitor through HDMI or other, try that. It may narrow down the possible source of the problem.
No, not the font data. If that were the problem, we would see consistent corruption: all L's should have the same corruption everywhere in the text (see below). Same with all T's, etc.
(Though, oddly, there is consistency with double letters, such as dropped, really, and !)
It does seem to be related to character rendering to-screen. As if, for every character sequentially printed to the screen, a random number of raster lines just doesn't light up.
Notice that its always a line of pixels missing from a character - never individual pixels.
That sure points to contents of the Video Ram. Could be either reading the Character Generator or writing the VIdeo Ram. My first step would be clean all the dust out of the thing, memories don't like hi temps (all they have to sweat is bits, and that's what gets dropped). Hi temps can also disrupt the timing of the interface chips, giving identical visual effects.
Then you can move on to wiggling everything in a socket or connector. Tthough it's probably best to keep clear of the CPU other than dusting it off.
Please keep us updated, if it is working well enough to do so.
Cheers,
Tom
That's a very good point!
What if Anorlunda's computer is corrupting the characters it sends to us here? Would we ever know?
What if he's lying there on the floor right now trying to type "Help! I tried to use a metal featherduster to clean the motherboard and now I'm being electrocuted to death!' but all we're seeing is 'What other DIY remedies might I try?'
Is this a particular program?
Does it happen in the BIOS? Or in another operating system (e.g. linux live cd)?
Did you make any change recently or it started showing sudden?
  • · Replies 30 ·
