Truss Forces: Calculating F(AD) and F(AB) for Resolution of Forces
  • Thread starter Thread starter chetzread
    Forces Trusses
The discussion focuses on calculating the forces F(AD) and F(AB) in a truss system. It establishes that the force F(AD) points towards joint A, indicating compression, while the force F(AB) is derived from the equation (1/sqrt(2))(48.08), which is negative and points leftward. The resolution of forces into vertical and horizontal components is confirmed as essential for these calculations, with the positive X direction defined as rightward.
  • Understanding of truss analysis principles
  • Knowledge of force resolution into components
  • Familiarity with vector notation and directionality
  • Basic proficiency in algebraic manipulation
  • Study the method of joints in truss analysis
  • Learn about calculating internal forces in truss members
  • Explore the concept of equilibrium in static structures
  • Review vector decomposition techniques in physics
Engineering students, structural analysts, and professionals involved in mechanical and civil engineering who are working on truss systems and force calculations.
chetzread
from the calculation of F(AD), the force should point towards A,right? (red arrow)
but, in the calculation of F(AB), the (1/sqrt rt2)(48.08) should be positive,right? (which is pointing towards LEFT)?
2. Homework Equations
this involve the resolution of forces into vertical and horizontal axes,am i right?
chetzread said:
1.)
Positive X is rightward, as the equation HA -28 = 0 defined at the start of the solution.
Member AD was found to be in compression and so exerts a leftward force at joint A, so the term 1/(√2)(48.08) is negative.
