- 372
The source code is as follows:
I tried this webpage here:
https://www.tutorialspoint.com/compile_c_online.php
to compile and execute the source code (I didn't write this file, I got it from someone);
I get the following errors:
sh-4.2$ gcc -o main *.c
/tmp/cc42Vpo
: In function `bindist':
main.c:(.text+0x1308): undefined reference to `sqrt'
main.c:(.text+0x1400): undefined reference to `sqrt'
main.c:(.text+0x146a): undefined reference to `sqrt'
collect2: error: ld returned 1 exit status
sh-4.2$ main
sh: main: command not found
Isn't the sqrt operation defined in the library of math?
How to fix this code so that it will run appropriately?, btw it's a bit dated from the nineties of the 20th century. :-)
Thanks.
C:
#include <stdio.h>
#include <math.h>
#define pi 3.14159265
#define nbin 10000
#define small 1.e-12
int addj(int data[nbin],double *tw,double x,double y,double vx,double vy, int xn,int j,double tc);
void billiard(int data[nbin],int nx,int nt,double x);
void bindist(int data[nbin], int nb, int nt);
int menue(void);
double ran1(long *idum);
void tabulate(int data[nbin], int nb, int rows);
void main(void)
int c; /* menue variable*/
int col; /*number of columns in table*/
int data[nbin]; /* array of binned data*/
int i; /*dummy index*/
long idum; /*randum number generator seed*/
int j; /*dummy index*/
int nb; /*number of bins*/
int nt; /*number of data points collected*/
int nx; /*number of bins in x-direction*/
double x; /*initial x-coordinate, the initial
y-coordinate is set to zero*/
printf("input integer random number generator seed ");
scanf("%d",&idum);
idum=-idum; /*random number generator is initialized
by negative integer seed*/
while((c=menue()) !=1)
switch (c)
case 2:
printf("input number of points nt ");
scanf("%d",&nt);
printf("input number of bins ");
scanf("%d",&nb);
for (i=0;i<nb;i++) data[i]=0;
for(i=0;i<nt;i++)
j=ran1(&idum)*nb;
data[j]++;
break;
case 3:
printf("sqrt of no of bins ");
scanf("%d", &nx);
nb=nx*nx;
printf("input 0<x <1, or x<0 for random start ");
scanf("%lf",&x);
if (x<0) x=ran1(&idum);
scanf("%d",&nt);
for(i=0;i<nb;i++)data[i]=0;
billiard(data,nx,nt,x);
break;
case 4:
bindist(data,nb,nt);
break;
case 5:
col=10;
tabulate(data,nb,col);
break;
int addj(int data[nbin],double *tw,double x,double y,double vx,double vy,int nx,int j, double tc)
int k; /*column and bin number*/
int l; /*row number*/
double xn;
xn=((double)nx)-small;
while (*tw>=1)
x+=(1.-tc)*vx;
y+=(1-tc)*vy;
*tw+=-1;
tc=0;
l=y*xn;
k=x*xn;
k+=l*nx;
/*printf("x= %f, y= %f, k= %d, vx= %f,tw=%f \n",x,y,k,vx,*tw);*/
data[k]++;
j++;
return j;
int i=0; /*switch label*/
int j=0; /*time for next data point*/
double tc; /*current time*/
double tw; /*time to hit the wall*/
double xx; /*temporary x-coordinate*/
double y; /*y-coordinate*/
double yy; /*temporary y-coordinate*/
double vx; /*magnitude of x-velocity*/
double vy; /*magnitude of y-velocity*/
double vxm; /* -vx*/
double vym; /* -vy*/
printf("x-initial= %f\n",x);
printf("input vx>0 ");
scanf("%lf",&vx);
printf("input vy>0 ");
scanf("%lf",&vy);
vxm=-vx;
vym=-vy;
tw=y=0;
while (j<nt)
tc=tw;
/*printf("i=%d\n",i);*/
switch (i)
case 0: /* 0<x<1,y=0, xspeed >0, y speed >0 */
yy=(1.-x)*vy/vx;
if (yy<1.)
tw+=yy/vy;
i=1;
j=addj(data,&tw,x,y,vx,vy,nx,j,tc);
x=1.;
y=yy;
else
tw+=1./vy;
i=6;
x+=vx/vy;
y=1;
break;
case 1: /* x=1,0<y=1;xspeed <0, yspeed >0 */
xx=1.-(1.-y)*vx/vy;
if (xx>0)
tw+=(1.-xx)/vx;
i=2;
j=addj(data,&tw,x,y,vxm,vy,nx,j,tc);
y=1;
x=xx;
else
tw+=1./vx;
i=7;
x=0;
y+=vy/vx;
break;
case 2: /* 0<x<1,y=1, xspeed <0, y speed <0 */
yy=1-x*vy/vx;
if (yy>0)
tw+=(1.-yy)/vy;
i=3;
j=addj(data,&tw,x,y,vxm,vym,nx,j,tc);
x=0.;
y=yy;
else
tw+=1./vy;
i=4;
x+=-vx/vy;
y=0;
break;
case 3: /* x=0,0<y=1;xspeed >0, yspeed <0 */
xx=y*vx/vy;
if (xx<1)
tw+=xx/vx;
i=0;
j=addj(data,&tw,x,y,vx,vym,nx,j,tc);
y=0;
x=xx;
else
tw+=1./vx;
i=5;
x=1;
y+=-vy/vx;
break;
case 4: /* 0<x<1,y=0, xspeed <0, y speed >0 */
yy=x*vy/vx;
if (yy<1)
tw+=yy/vy;
i=7;
x=0.;
y=yy;
else
tw+=1./vy;
i=2;
x+=-vx/vy;
y=1;
break;
case 5: /* x=1,0<y=1;xspeed <0, yspeed <0 */
xx=1.-y*vx/vy;
if (xx>0)
tw+=(1.-xx)/vx;
i=4;
y=0;
x=xx;
else
tw+=1./vx;
i=3;
x=0;
y+=-vy/vx;
break;
case 6: /* 0<x<1,y=1, xspeed >0, y speed <0 */
yy=1.-(1.-x)*vy/vx;
if (yy>0)
tw+=(1.-yy)/vy;
i=5;
x=1.;
y=yy;
else
tw+=1./vy;
i=0;
x+=vx/vy;
y=0;
break;
case 7: /* x=0,0<y=1;xspeed <0, yspeed >0 */
xx=(1.-y)*vx/vy;
if (xx<1)
tw+=xx/vx;
i=6;
y=1;
x=xx;
else
tw+=1./vx;
i=1;
x=1;
y+=vy/vx;
break;
/* This routine checks if deviation of number of elements in each bin follows a Gaussian distribution*/
void bindist(int data[nbin], int n, int nt)
double ave, adev, sdev, var, skew, curt;
int j;
double x,y,s=0,p,a,b,c;
x=(double) n;
y=(double) nt;
if (n <= 0) printf("nb must be at least 1 in moment\n");
for (j=0;j<n;j++) s += data[j];
ave=s/n;
adev=var=skew=curt=0.0;
for (j=0;j<n;j++)
adev += fabs(s=data[j]-ave);
var += (p=s*s);
skew += (p *= s);
curt += (p *= s);
adev /= x;
var /=x;
sdev=sqrt(var);
if (var)
skew /= n*var*sdev;
curt=curt/(n*var*var)-3.0;
printf("%39s %11s\n\n","calculated","expected");
a=y/x;
printf("%s %17s %12.4f %12.4f\n","Mean :"," ",ave,a);
c=sqrt(2.*a/pi);
printf("%s %4s %12.4f %12.4f\n","Average Deviation :"," ",adev,c);
b=sqrt(a);
printf("%s %3s %12.4f %12.4f\n","Standard Deviation :"," ",sdev,b);
printf("%s %13s %12.4f %12.4f\n","Variance :"," ",var,a);
printf("%s %13s %12.4f %12.4f\n","Skewness :"," ",skew,0.0);
printf("%s %13s %12.4f %12.4f\n","Kurtosis :"," ",curt,0);
/* to generate menue*/
int menue()
int x;
printf("1 to quit \n");
printf("2 to generate random distribution of points\n");
printf("3 to generate billiard distribution of points \n");
printf("4 to analyze data\n");
printf("5 to tabulate data\n");
scanf("%d", &x);
return x;
/* modified version of ran1 of numerical recipies. NOTE the initial seed should be NEGATIVE!*/
#define IA 16807
#define IM 2147483647
#define AM (1.0/IM)
#define IQ 127773
#define IR 2836
#define NTAB 32
#define NDIV (1+(IM-1)/NTAB)
#define EPS 1.2e-7
#define RNMX (1.0-EPS)
int j;
long k;
static long iy=0;
static long iv[NTAB];
double temp;
if (*idum <= 0 || !iy) {
if (-(*idum) < 1) *idum=1;
else *idum = -(*idum);
for (j=NTAB+7;j>=0;j--) {
k=(*idum)/IQ;
*idum=IA*(*idum-k*IQ)-IR*k;
if (*idum < 0) *idum += IM;
if (j < NTAB) iv[j] = *idum;
iy=iv[0];
k=(*idum)/IQ;
j=iy/NDIV;
iy=iv[j];
iv[j] =*idum;
if((temp=AM*iy)>RNMX)return RNMX;
else return temp;
#undef IA
#undef IM
#undef AM
#undef IQ
#undef IR
#undef NTAB
#undef NDIV
#undef EPS
#undef RNMX
/* to tabulate an integer array, nb is total number of entries,
co is number of columns*/
void tabulate(int data[nbin], int nb, int co)
int i,j,k,x, y;
x=nb/co;
y=nb%co;
k=0;
for (i=0;i<x;i++)
for (j=0;j<co;j++)
printf("%6d",data[k]);
k++;
printf("\n");
for (i=0;i<y;i++)
k++;
printf("\n");
/tmp/cc42Vpo
sh-4.2$ main
Thanks.
