- 22,820
- 14,877
The displaced water, not the object itself.DaveC426913 said:29g? Last measurement was 216g.
The discussion centers on identifying a component from a nuclear research establishment, speculated to be related to coolant systems for nuclear fuel rods. Participants suggest it may be a prototype spacer grid or brace for a CANDU reactor, potentially made from stainless steel or zirconium. The object features precise drilling and a design aimed at minimizing drag, indicating its function in high fluid flow areas. Measurements indicate a density consistent with stainless steel, ruling out zirconium, and further investigation into its purpose is encouraged.
PREREQUISITESNuclear engineers, researchers in nuclear technology, and anyone interested in the design and function of reactor components will benefit from this discussion.
29g of water so 29mlDaveC426913 said:29g? Last measurement was 216g.So, non-magnetic?
Awesome thanks for that. So next Q will be what is an AGR brace... off to GoogleAstronuc said:300 series stainless steel should be around 8 g/cm3, give or take. It would be slightly greater density if contained Mo or Nb, and the British used something similar to a Type 347, but much greater Ni content, e.g., 20Cr/25Ni/0.7Mn/0.5Nb, which would be more like 8.2-8.3 g/cm3.
I have a colleague who tentatively identified the component as an AGR brace, as opposed to spacer grid. He will check his drawings.
marcosmatt said:Awesome thanks for that. So next Q will be what is an AGR brace... off to Google
What is AGR Fuel?
AGR fuel is a type of oxide fuel made from uranium dioxide powder. An AGR fuel element is made up of uranium oxide pellets stacked inside stainless steel tubes, which are grouped together in a graphite sleeve to form a fuel assembly. Thirty-six stainless steel tubes, each containing 64 pellets, make up an assembly. The steel tubes are held by a machined brace – a recent innovation that improves fuel performance and nuclear safety.
The water flowing out of the faucet, and maybe the dice? Or was the picture of the street signs from your kitchen window?Orodruin said:In my book at least two illustrations are based on photos I took in my kitchen.
The faucet and the soap film between two rings.berkeman said:The water flowing out of the faucet, and maybe the dice? Or was the picture of the street signs from your kitchen window?
Yea. That is taken in central Stockholm. I took the picture (I actually went looking for catenaries specifically and had some ideas on where to find them - the flowing water in the background was a bonus) and wrote the equations. The publisher’s graphics designers put the picture into a couple of suggestions for the cover and asked which was my favorite.berkeman said:[ continuing_slight_hijack ]
Did you take the cover picture too? It gives insights into how your mind works...
[ /hijack ]
marcosmatt said:So didn't believe earlier result so made something to measure better. This brings me to 29g and a density of 7.4g/cm^3. That I believe is around the stainless steel mark. Few pics for entertainment value![]()
