Trying to obtain a 2nd order ODE
  • Level: Undergrad
  • Thread starter Thread starter AAli
    2nd order Ode
6 replies · 3K views
AAli
Hi I'm having a slight issue trying to obtain a 2nd order ODE with respect to x (so involves implicit differentiation in this case) from the equation below. I would greatly appreciate any help or tips to solve this problem.
I've removed the coefficients to make things a litter easier. Thank you.
AAli said:
Hi I'm having a slight issue trying to obtain a 2nd ODE with respect to x (so involves implicit differentiation in this case) from the equation below. I would greatly appreciate any help or tips to solve this problem.
Your question isn't clear to me. Are you trying to obtain a 2nd order ODE? If so, I'm not sure that will lead to anything productive. A different approach would be to move all the terms involving dy/dx to one side, and then solve for dy/dx in terms of everything else. The resulting equation is separable, so it's possible a solution could be found without resorting to the implicit differentiation you're talking about.
Hi, my goal was to eventually obtain a set of coupled first order differential equations from the 2nd order ODE, so I'm happy to try a quicker approach to solve this problem. Could you please elaborate on the highlighted bit. Thank you.
Edit: order
AAli said:
Hi, my goal was to eventually obtain a set of coupled first order differential equations from the 2nd ODE, so I'm happy to try a quicker approach to solve this problem. Could you please elaborate on the highlighted bit. Thank you.
"2nd ODE" does not mean "second order differential equation." Please try to be more clear in what you write. Edit: I see that you have edited your post to include the word "order."
The strategy you're describing won't work, as far as I can tell. It does no good to convert a 1st-order DE to 2nd order for the purpose obtaining two first-order DEs.
What I'm suggesting is to move all the terms in dy/dx to one side, and then solve algebraically for dy/dx.
I get ##\frac {dy}{dx} = \frac{y^{1/2}(1 - y^{1/2} - y)}{y^{1/2}(y^{-1/2} + 1 - y)}##.
This is separable, and would be very simple to solve except for one sign in the fraction on the right.
I did as you advised but I got something slightly different:
##\frac {dy}{dx} = \frac{y^{1/2}(1 - y^{1/2} - y)}{y^{1/2}(y^{-1/2} + 1 - y^{-3/2})}##.
Yes, I made a mistake on the last term in the denominator.
You mentioned earlier that you removed the coefficients. You should put them back in, as both numerator and denominator might be further factorable.
