Trying to understand(conceptually) orthogonality
  • Thread starter Thread starter Arnoldjavs3
    Orthogonality
7 replies · 2K views
Arnoldjavs3
if Ax = b has a solution and A^Ty = 0 , is y^T(x) = 0 or y^T(y) =0
I simply do not think i understand the properties to answer this question.
From my understandinging, the transpose of A times y is = 0. This means that A transpose and y(all the members of these two subspaces) are perpendicular. Does this indicate that y is essentially the nullspace of A transpose? A transpose is the rowspace?
Where do I progress on frmo this?
I'd like to add... why is the transpose of these matrices even relevant? I don't understand. Are there properties of the transpose that I'm missing? What are these variables y and x representing? There's just so much here that's confusing me(I'm guessing I don't understand fundamentally)
I know that the row space is orthogonal to the nullspace(and colspace with the left nullspace) how do i use this knowledge to solve this problem?
Do you mean Ax=b has a unique solution?
If it has a unique solution then A is invertible, and hence so is ##A^T##, which allows us to choose between the two alternative answers.
But if we only know that Ax=b has at least one solution, then A may be singular, in which case the question is unanswerable.
Yes it has a unique solution.
What good does it knowing that A^T and ax=b is invertible?
You are given the equation ##A^Ty=0##. Using the fact that ##A## is invertible, and hence so is ##A^T##, rearrange that equation so that y is alone on one side (ie make y the subject of the equation). Then simplify as much as possible.
Well if I were to isolate y from that equation you've stated, wouldn't it just be y = 0? the fact that A is invertible(meaning so is its transpose) confuses me. Why does that help me?
They've asked you if ##y^Tx = 0## or ##y^Ty =0##. The answer is yes if either or both is true.
If you can show that ##y=0##, can you then prove that at least one of those two is true?
If so, the answer to the set question is Yes.
What do y^T(x) and y^T(y) mean?
It would be helpful to state that x and y are vectors in some vector space (such as ##\mathbb{R}^n##?).
Since your question is about orthoganality, there's an inner product lurking about somewhere, so presumably y^T(x) could just as well be written as ##\vec{y} \cdot \vec{x}## and y^T(y) could be written as ##\vec{y} \cdot \vec{y}##
That doesn't make any sense. Two vectors can be perpendicular (or othogonal), but a matrix and a vector aren't things that can be perpendicular to each other.
If ATy = 0, then, yes, y is in the nullspace of AT.
Could you post the problem exactly as given to you? It seems like you're leaving a lot of relevant details out.
