Trying to understand Lorentz Transformations
69 replies · 10K views
NoahsArk
I am trying to understand the general form of the Lorentz Transformations before I even get into the long process of deriving that into the specific equations. In Taylor and Wheeler's, Spacetime Physics book they give this as the general form:
t= Bx1 + Dt1
x= Gx1 + Ht1
In the equation for t, why is x being added into the equation? I don't understand, if we are trying to convert time in one reference frame to time in another, why we'd be adding x when x is distance.
Similarly, in the equation for x, why are we adding t?
Also, in the equation for t, I know that the coefficient, D, in front of t1 is γ which is derived from the invariance of the interval. In the equation for, x, though, the authors give vγ (where v is the velocity of the second (rocket) frame from the perspective of the first (earth) frame), as the coefficient of t1. What is the explanation for that?
Thank you.
It's just the most general linear transformation. They're not really adding x or t into the equation - they're just not assuming they can leave either out. So this is the form of transformation with the fewest possible assumptions. If the transformations had turned out not to depend on x or t (like the Galilean t transform) the relevant coefficient would be zero.
The derivation should justify the values somewhere. It depends what derivation you are following. Where are you looking in Taylor and Wheeler?
If you go back to basic Newtonian physics and have one reference frame moving at velocity ##v## relative to another, then:
##x' = x - vt##
That's because the origin of the second reference frame is moving at velocity ##v##.
This is called the Galilean transformation, the other part of which is the obvious ##t' =t##.
The basic idea of the Lorentz transformation is that you want to generalise these two equations:
##x' = x - vt## becomes in general ##x' = Ax + Bt##
And ##t' = t## becomes ##t' = Ct + Dx##
And, to see whether anything else makes sense, apart from the Galilean solution: ##A = 1, B = -v, C = 1, D = 0##. Are there any other possible solutions that make physical sense?
I'm not sure why, when trying to figure out t based on t1[/S
UP], we need to know what x is at all.
In my book it's the "special topic" chapter which is between chapters 3 and 4. It's on page 100.
PeroK: "The basic idea of the Lorentz transformation is that you want to generalize these two equations:"
For the case where x1 = 0, then the equation to convert time would be t = γt1. I am still not sure why when x1 is greater than zero, we have to add x1 into the equation.
t' = t is very familiar, but it's just not compatible with special relativity. Basically, you'll have to come to terms with the fact that t' depends on t and x, and not just t, in order to understand special relativity. Truly understaning all of the consequences of this will take a while, some are not obvious. Unfortunately, just rejecting the idea that t' depends on t and x out of hand isn't going to get you anywhere useful :(.
NoahsArk said:
I'm not sure why, when trying to figure out t based on t1, we need to know what x is at all.
Why wouldn’t you? You are just assuming that you can neglect x, but there is no physical basis for that assumption.
The idea here is to make as few assumptions as possible and then derive as much as you can with as few assumptions as possible. You are assuming that B=0, which is a very strong and unjustified assumption. The derivation is not assuming any value for B, it could turn out to be 0, but they are not assuming that. It could turn out to be non-zero, but they are not assuming that either.
So leaving B in is not an assumption, so it needn’t be justified. Setting B=0 a priori is an assumption and requires justification
My understanding of the Lorentz transformations is that we use them for situations where some event in the rocket frame (x1) occurred some distance in front of the rocket. To know that distance from Earth's frame, we need to know how far away that event occurred from the rocket (using the rocket measurement) and multiply that distance by γ, and add that number to the distance that the rocket traveled from us (v times γt1). So, it would make sense to me why we use t1 to try and figure out x. The reverse, though, I can't explain- i.e. why we need x1 to figure out t.
To me though, putting X into the equation has no more reason than putting any other variable in it. The only reason I can think of is my vague notion that it has something to do with relativity of simultaneity, and if an event occurred some distance away from the rocket, the mere distance alone from the rocket will affect x1's time measurement of that event. Seems like there should be a simpler explanation than that though.
What other variable would you put in? Are there any other coordinates you would use to label an event in an inertial frame other than three for position in space and one for time?
X isn’t being put into the equation. If B=0 then x is not in, which is not rejected a priori.
Again, what is your physical justification for asserting B=0, a priori?
You have already been given the simpler explanation multiple times. The goal is to make as few a priori assumptions as possible. If you don’t make assumptions then you have to allow the possibility that x might be in the equation or it might not.
They are much more general than that. They answer the question:
I say that something happened at point x and time t. You are moving relative to me. Where and when did it happen according to you?
NoahsArk said:
t= Bx1 + Dt1
x= Gx1 + Ht1
From this postulate
[tex]c^2t^2-x^2=(c^2D^2-H^2)(t^1)^2-(G^2-c^2B^2)(x^1)^2+2(c^2BD-GH)x^1 t^1[/tex]
The SR relation, square of invariant distance, $$c^2t^2-x^2=c^2(t^1)^2-(x^1)^2$$ requires non zero B. Thus
[tex]cD=cosh\ \alpha,\ H=sinh\ \alpha[/tex]
[tex]G=cosh\ \gamma,\ cB=sinh\ \gamma[/tex]
[tex]cosh\ \alpha \ sinh\ \gamma=cosh\ \gamma \ sinh\ \alpha[/tex] so [tex]\alpha=\gamma=arctanh\ \beta[/tex]
Introducing beta=v/c above, we get familiar Lorentz transformation formula, assured by uniqueness of series expansion by beta.
Say all the lattice points of the two frames of reference are occupied with synchronized clocks.
The transformation formula tell correspondence of the superposed two FR in space coordinates and clock readings or time coordinates. In this correspondence
[tex]x \approx x'+vt'[/tex] has been obvious at latest since time of Galilei, but
[tex]t \approx t'+v/c^2 x'[/tex] has not been noticed until 20th century because of smallness of vx'/c^2 in most cases.
Thank you for the responses.
To take an example, let's say a rocket is moving ahead of me at v = .8 c. For the time between any two events happening in the rocket, I multiply by 1.67 to get my measurement of the time between the events. No need for Lorentz transformations.
Now say two events occurred at a distance of one light year in front of the rocket. It wouldn't cross my mind to say that I now have to take whatever the rocket time was, multiple by 1.67, and then add one light year to that amount? I'm pretty confused.
Also, if the rocket were very long, do we consider any events happening inside the rocket, whether at the nose or tail of the rocket, as being at X1 = zero in the rocket frame? I am assuming that Lorenz transformations come into play in situations where there is a third frame of reference, like another rocket traveling in front of the first one, but even then I can't see why we'd be thinking of adding X1 to get t.
Following up on this, I was just watching a coursera video on SR (second video on the Lorentz transformations) where he says that the X1 in the equation for t is basically the leading clocks lag principle built into the Lorentz transformations. This makes sense, but I don't see how we could assuming from the beginning that the equation for t must take that general form without prior knowledge that leading clocks lag.
Be precise. There are four events here: the two events you're talking about which we will call E1 and E2, but also E3 ("you look at your wristwatch at the same time as E1") and E4 ("you look at your wristwatch at the same time as E2"). The rocket observer is present at both E1 and E2 so he can directly measure the time between them (call that ##\Delta{T}'##). You multiply ##\Delta{T}'## by 1.67, and that gives us... the time you'll measure between E3 and E4. We then assert (because E1 and E3 happen at the same time, as do E2 and E4) that this is also our measurement of the time between E1 and E2.
How so? The "multiply by 1.67" formula you used is the result of applying the Lorentz transformations in the specific case in which event E1 has coordinates ##(x'=X_0,t'=T_0)## in the spaceship frame and event E2 has coordinates ##(x'=X_0,t'=T_0+\Delta{T}')##.
Please, please, please... don't just take my word for this. First, satisfy yourself that the coordinates I just wrote down for E1 and E2 are right for two events that happen at the same place and different times according to the spaceship observer. Then plug them into the Lorentz transformations to see that according to you they happened at different places (separated by ##1.67v\Delta{T}'##) and that if events E3 and E4 happened at the same time as E1 and E2 according to you, then E4 happened ##1.67v\Delta{T}'## after E3.
In this case, the coordinates for E1 in the spaceship frame would be ##(x'=1ly,t'=T_0)## and the coordinates of E2 would be ##(x'=1ly,t'=T_0+\Delta{T}')##. Plug this into the Lorentz transformations and you'll find that the corresponding E3 and E4 are still separated by ##1.67\Delta{T}'##.
No. suppose the length of the rocket is ##L##. We could choose the tail of the rocket to be ##x'=0##, and then an event happening at time T (using the rocket frame) at the nose of the rocket would have coordinates ##(x'=L,t'=T)## while an event happening at the same time at the tail of the rocket would have coordinates ##(x'=0,t'=T)##. (This is exactly your previous question, if the rocket were one lightyear long).
Also, note that although these events happen at the same time using the rocket frame (they both have the same ##t'## coordinate) they do not happen at the same time using the frame in which you are at rest.
No. The Lorentz transformations come into play any time that we know an event happened at location X and time T according to one frame, and we want to calculate the location and time at which that event occurred using another frame.
We start with the most general possible transformation. We're making no assumption about whether leading clocks might lag, trailing clocks might lag, or whether they all stay synchronized... we just don't know, so we assume nothing.
This most general assume-nothing transformation will be of the form$$t'=Ax+Bt\\x'=Cx+Dt$$We use what we know about the behavior of light (the same speed in all frames tells us that ##x\pm{ct}=0## implies ##x'\pm{ct'}=0##) to solve for the values of A, B, C, and D and we end up with the Lorentz transformations...
And then we look at these transformations and see that they're telling us, among other things, that leading clocks lag. So we didn't have any prior knowledge of this, it's the conclusion that we came to at the end.
It's not a question of prior knowldege, it's a question of exploring the alternatives to ##t' =t##.
Let's suppose you were a physics student in 1850 and you and a friend were discussing time and thought of this question: is there any alternative to ##t' = t##? You might say "no, nothing else could possibly make any physical sense". Your friend might say "but, what if, ##t'## depended in some way on ##x## and ##t##? And, you'd say: "it's impossible". Your friend says: "but what if we try?" Just imagine that it's linear (because that's the simplest alternative). What if ##t' = At + Bx## for some ##A, B##?"
You'd say: "you must have prior knowldege of the leading clocks lag rule"! And your friend would say "what's that. then?".
So, your friend simply wants to try something - to see where it leads. But, you are resolute, there is no point in considering an alternative to ##t'= t## unless you already know what the answer will be! You're not allowed even to try.
Not really.
The multiplication only works if the events happen at the same location in the rocket’s frame. If one happens in the front of the rocket and the other happens in the rear of the rocket then the simplified formula fails and you have to use the full Lorentz transform.
Furthermore, if they are in the same location in the rocket’s frame then the simplified formula is the Lorentz transform. Since ##\Delta x=0## that term drops out and you are left with the multiplication. So saying “no need for the Lorentz transform” fails to recognize that the simple multiplication is the Lorentz transform in this specific case.
No matter what, you will apply the Lorentz transform. If you are in a special scenario then the Lorentz transform will automatically simplify to the time dilation formula or some other relevant simple formula. Always using the Lorentz transform will prevent mistakes that arise from incorrectly using a simplified formula and confusion about when to apply the simplified formulas.
For like the fourth time now, no such assumption is made.
Do you understand the concept of a general formula? A general formula is one that captures all of the possibilities. It makes no assumptions about which specific formula is correct, but allows you to pick between the various possible specific formulas by setting one or more parameters. In this case the parameter is B. We make no assumptions about the value of B.
This is getting very frustrating. It seems that you are not even making an effort to understand this point. You keep on saying that we are making an assumption when in fact it is you that are the only one making an assumption, and you have not once even attempted to justify your assumption! You have this totally backwards and are repeating it over and over with no attempt to figure it out. Stop! We are not assuming anything! Stop saying that we are. The only assumption here is your unjustified assumption that B=0. The next time you use the word “assumption” please make sure that it refers specifically to your assumption that B=0.
@NoahsArk - are you asking your question backwards? Is the underlying question "why ##x## and not ##z## or temperature or the price of gold or something"?
Ibix said:
are you asking your question backwards? Is the underlying question "why xxx and not zzz or temperature or the price of gold or something"?
Yes, that is exactly what I am asking.
Dale: It's a difficult concept for me. I understand what the general form of an equation is. I just don't see how people originally came up with the idea that the general equation took that form.
Maybe they took a guess!
How much of physics started with an educated or inspired guess? Where did Newton get his law of gravitation? Maybe he guessed:
##F = \frac{GMm}{r}##
And that didn't work.
Then he guessed:
##F = \frac{GMm}{r^2}##
And that worked.
If that hadn't worked he might have tried:
##F = \frac{GMm}{r^3}##
In fact, it doesn't matter at the end of the day where the equation came from. As long as you can demonstrate that it has the properties you want. The law of gravitation being a case in point.
Hmmm. Are you saying that as long as the equation is giving the right results, I should just learn it and use it and not get too bogged down in how it originated?
OK, that is fine, but please stop asserting that the equation with B is an assumption, it is the opposite of an assumption. So the question is what reasoning led them to believe that the linear expression was the correct generalization.
The first thing that we need to do is to understand what it is that a transformation is doing and what kind of transformation we are looking for. A transformation is intended to change one set of coordinates into another set of coordinates. So if we have Cartesian coordinates we might change them into polar coordinates. Coordinates are just ways to numerically label different times and places.
Now, we are particularly interested in inertial coordinate systems, that is we like coordinates where free particles go in a straight line at constant velocity, following Newton's first law. Any coordinates where all free particles have straight lines as their worldlines are inertial coordinates, so if we want to study the transformations from one inertial frame to another inertial frame then we want to study transformations that map straight lines to other straight lines.
The simplest such transformation is a linear transformation, which is the form chosen in the derivation you cited. So the reason for choosing that generalization is that it is the simplest generalization that has the necessary property of mapping straight lines to straight lines.
Nugatory said:
No. suppose the length of the rocket is LLL. We could choose the tail of the rocket to be x′=0x′=0x'=0, and then an event happening at time T (using the rocket frame) at the nose of the rocket would have coordinates (x′=L,t′=T)(x′=L,t′=T)(x'=L,t'=T) while an event happening at the same time at the tail of the rocket would have coordinates (x′=0,t′=T)
Thank you for clarifying that.
In the equation y = mx + b, the first time I read it and the description for it it made sense to me right away. It makes sense because I visualize that what it's describing is a straight light which isn't curved, and I understand why we use each of the terms. The Lorentz equation for time, though, doesn't jump out at me in the same way as being intuitive.
Originally, Einstein didn't come up with it that way - he used his train thought experiment. But then people showed that the transforms are simply an expression of symmetries, and this is a more abstract but much more powerful way of thinking, that underlies all fundamental physics post-Einstein.
The transforms simply relate coordinates on spacetime, so they can only depend on the coordinates and the relative velocity of the frames. There are no other physical concepts that are relevant. The transforms have to be linear because if they aren't there's either a special place or a special time or both. We can arbitrarily choose an origin that the coordinates share, and we can arbitrarily choose our x-axis to lie parallel to the relative velocity of the frames.
With those assertions, the most general transformation we can possibly write is$$\begin{eqnarray*}t'&=&At+Bx+Cy+Dz\\
x'&=&Et+Fx+Gy+Hz\\
y'&=&It+Jx+Ky+Lz\\
z'&=&Mt+Nx+Oy+Pz\end{eqnarray*}$$where the capital letters are constant. We are not making any assumptions about these constants. Many of them may be zero - but we'll prove that, we won't assume it.
All the off-diagonal elements including ##y## or ##z## must be zero from symmetry. Simply rotate your coordinate axes 180° about the x-axis and ##y## becomes ##-y## - but this shouldn't have any effect on ##x'## or ##t'##, and the only way for it to have no effect if those cross terms are zero. We cannot make this argument about off diagonal terms with ##x## because there is a difference if we flip the x-axis (the velocity changes sign) and we can't make this argument about ##t## because flipping the direction of time also flips the direction of velocity.
That tells us that our four equations are just
$$\begin{eqnarray*}t'&=&At+Bx\\
x'&=&Et+Fx\\
y'&=&Ky\\
z'&=&Pz\end{eqnarray*}$$Adding that the inverse transforms must look the same as the forward transforms except for the sign of the velocity (i.e., the principle of relativity) means that we want ##y'=Ky## and ##y=y'/K## to look the same which means ##K=1##, and similarly ##P=1##.
This is where you started. Sweetsprings already posted the derivation from here.
People may have worked on this for a long time. You should not assume that it was intuitively obvious to the casual observer.
Note that if the coefficient B has a value of zero then the term containing x will be zero. So the possibility is there, but it's only a possibility.
If you do not include time then you cannot distinguish between a particle that travels in a straight line at a constant velocity and a particle which travels in a straight line at an accelerating velocity. So you lose the critical distinction between inertial and non-inertial coordinates. Once you include time as a coordinate, then a general linear transformation includes time. Leaving it out is making an assumption.
It may not be intuitive, but sometimes that is why you have to use the math, to make logical leaps that are not intuitive. For you, this is one of those times. You specifically need to use the math a little more until you develop some new intuition.
One way of formulating special relativity is to postulate that the speed of light equal to "c" for all observers. This goal can't be accomplished if one limits oneself to the transform t'=t.
A longish quote from Einstein's 1905 paper might clarify the assumptions made:
Examples of this sort, together with the unsuccessful attempts to discoverany motion of the Earth relatively to the “light medium,” suggest that thephenomena of electrodynamics as well as of mechanics possesses no properties corresponding to the idea of absolute rest. They suggest rather that, as hasalready been shown to the first order of small quantities, the same laws of electrodynamics and optics will be valid for all frames of reference for which theequations of mechanics hold good.1We will raise this conjecture (the purport of which will hereafter be called the “Principle of Relativity”) to the statusof a postulate, and also introduce another postulate, which is only apparently irreconcilable with the former, namely, that light is always propagated in emptyspace with a definite velocitycwhich is independent of the state of motion of the emitting body. These two postulates suffice for the attainment of a simple and consistent theory of the electrodynamics of moving bodies based on Maxwell’s theory for stationary bodies. The introduction of a “luminiferous ether” will prove to be superfluous inasmuch as the view here to be developed will not require an “absolutely stationary space” provided with special properties...
In the end though, it's a matter of whether one wants to learn how the theory works, or not. Ideally, one would let experiment decide whether relativity or classical Newtonian mechanics best matched experimental evidence. In practice, perhaps, if one is a student, one doesn't bother to learn a new theory unless one is pretty sure it's going to be a better theory.
A bit of motivation as to why classical Newtonian mechanics doesn't work quite right might be helpful in motivating one to learn special relativity. I am rather fond of "The Ultimate Speed"
There is a peer-reviewed paper associated with this video that goes into more detail. The video is less dry than the paper, one reason I link to it, though in general one needs to be cautious about accepting any video one may encounter on the internet.
Assuming that one has already decided that special relativity is worth learning, it becomes simple. One can't assume that t'=t and still learn special relativity. The question of why one should learn special relativity is more complex, but it boils down to the fact that it works very well. One can't really understand this point, about how well it works, until one learns the theory in the first place, however.
There are other routes to learning and formulating the theory than EInstein's original approach, but they'll all lead to similar results, where t' is not equal to t.
