Trying to understand proofs, help me solve this one
  • Thread starter Thread starter IntegrateMe
    Proofs
The discussion focuses on proving that the composition of two surjective functions, f and g, both defined from ℝ to ℝ, is also surjective. It clarifies that a function f is surjective if for every real number y, there exists an x such that f(x) = y. The proof involves demonstrating that for any arbitrary point z in the codomain of f ∘ g, one can find a corresponding y in the domain of f and an x in the domain of g such that f(g(x)) = z. This establishes that f ∘ g is onto.
  • Understanding of surjective functions and their definitions
  • Familiarity with function notation, specifically f: A → B
  • Basic knowledge of real numbers and their properties
  • Concept of function composition, particularly f ∘ g
  • Study the properties of surjective functions in more detail
  • Learn about function composition and its implications in mathematics
  • Explore examples of surjective functions and their proofs
  • Investigate the relationship between the range and codomain of functions
Students of mathematics, particularly those studying real analysis or function theory, as well as educators looking to explain the concept of surjectivity and function composition.
IntegrateMe
Suppose that [itex]f, g : \mathbb{R} \rightarrow \mathbb{R}[/itex] are surjective (ie onto functions with domain [itex]\mathbb{R}[/itex] and allowable output values [itex]\mathbb{R}[/itex]). Prove that [itex]f \circ g[/itex] is also surjective (ie, prove [itex]f \circ g[/itex] is also onto).
First of all, I have absolutely no math theory experience, so I don't really understand what's being asked for here.
I know that ℝ is the set of all real numbers, but I'm not sure what ℝ → ℝ represents.
Can someone explain to me the mathematical terms and give me a breakdown of how this problem would be solved?
f being an onto function means that for every real number y there exists x such that f(x) =y.
[itex]f \colon A \to B[/itex] means a function with name [itex]f[/itex] from the domain [itex]A[/itex] into the codomain [itex]B[/itex]. For instance, consider the function [itex]f\colon \mathbb{R} \to \mathbb{R}\times \mathbb{R}[/itex] defined by the rule [itex]f(x) = (x,x)[/itex]. In this example the domain (e.g., the set [itex]x[/itex] is in) is the real line [itex]\mathbb{R}[/itex] and the codomain is the set [itex]\mathbb{R}\times \mathbb{R}[/itex], e.g., the 2D plane. This function is not onto though, because there are points [itex](a,b) \in \mathbb{R}\times \mathbb{R}[/itex] such that there is no [itex]x \in \mathbb{R}[/itex] with [itex]f(x) = (a,b)[/itex]. To prove this, let [itex]a, b[/itex] be real with [itex]a \neq b[/itex] and assume [itex]f(x) = (a,b)[/itex]. Since [itex]f(x) = (x,x) = (a,b)[/itex] must hold, then [itex]x = a[/itex] and [itex]x = b[/itex] must also be true, but [itex]a \neq b[/itex] so it cannot. The only parts of the codomain that are hit are those on the line [itex]y = x[/itex] which can be written as [itex]L = \{(a,a)\colon a \in \mathbb{R}\}[/itex]. In this case [itex]L[/itex] is the range of [itex]f[/itex] (it's also called the image of [itex]f[/itex]), which is always a subset of the codomain.
However, the function [itex]g\colon \mathbb{R} \to L[/itex] defined by the rule [itex]g(x) = f(x) = (x,x)[/itex] is onto. To prove this, let [itex](a,a) \in L[/itex]. Then we see [itex]a \in \mathbb{R}[/itex] and [itex](a,a) = g(a)[/itex]. Since the element [itex](a,a)[/itex] chosen from [itex]L[/itex] was arbitrary, we see that [itex]g\colon \mathbb{R} \to L[/itex] is an onto function. In this case the range and the codomain of the function [itex]g[/itex] are the same: namely, [itex]L[/itex].
This is really all you need to do in your problem: pick an arbitrary point [itex]z[/itex] in the codomain of [itex]f \circ g[/itex] and find a [itex]y[/itex] in the domain of [itex]f[/itex] such that [itex]f(y) = z[/itex]. Then find an [itex]x[/itex] in the domain of [itex]g[/itex] such that [itex]g(x) = y[/itex]. E.g., you find an [itex]x[/itex] such that [itex]g(x) = y[/itex] and [itex]f(y) = z[/itex] so that [itex]f(g(x)) = z[/itex].
