- #36
Woodology
- 1
it was used to set the brightnessSummary: I had an old dial tune TV set. Obsolete now.
It had a small button that I think was suppose to improve reception. What did that button do physically?
What you said:
As long as the TV was still turned on, that would help to keep the TV tuned right on the frequency of that chosen channel. If you wanted to change channels or if you turned the TV off and later turned it back on, you would need to do the fine-tune knob (with AFC off) again first, and then re-engage AFC. But that's just my educated guess, unless somebody can remember better or find an old TV manual...
This seems to be the why I never used the button. I never heard it mentioned in the manual about tuning and engaging. And tune another while disengaged and reengage.What you said:
I have another question. If I tuned that to channel 11 but l don’t have signal. What is displayed. I realize it’s static. But is the static the same channel to all without a broadcast?
I don’t know but it’s the Duke"Well, which is it young feller?" (Quiz Question -- what movie is that from?)
The "Improve Reception" control was a fine-tune dial or a single push-button?
it appears soSome the static was quite old, i.e., from 14 billion years ago.
it appears so
Summary:: I had an old dial tune TV set. Obsolete now.
This evening I cruised YouTube and watched a show about the Big Bang and it’s plateau after 20 some days. According to the video Cosmic Mictowave Background had begun to appear. In the same show they say that artifacts in the static on those TV sets were sporadic CMB. I was watching on the tv and a did not think to figure out how to share it here. They discussed the noise with artifacts as CMB. Interesting that back then that CMB was included in a BBT discussion. The button had three positions. Thanks.It is whatever electromagnetic noise there is at the frequency of the channel. That noise will vary from channel to channel and from one location to another.
it appears so
This evening I cruised YouTube and watched a show about the Big Bang and plateau after 20 some days. According to the video Cosmic Mictowave Background had begun to appear. In the same show they say that artifacts in the static were sporadic CMB. I was watching on the tv and a did not think to figure out how to share it here. They discussed the noise with artifacts as CMB. Interesting that back then that CMB was includedIt is whatever electromagnetic noise there is at the frequency of the channel. That noise will vary from channel to channel and from one location to another.
Interesting video! Too bad it leaves so many things unanswered, even the successful experiments.
Now back to that 'rectangular button' you were asking about. Below is a short video that seems to describe it. But first an overall explanation.
The function indeed appears to be switching the Automatic Frequency Control (AFC) On and Off. The AFC functions by controlling the frequency of the local oscillator in the tuner by applying a variable voltage.
If I recall correctly, the varying voltage was obtained from the Ratio Detector used for the FM audio demodulation. A Ratio Detector has the characteristic of having a plus or minus DC offset output depending on whether the incoming IF signal is above or below its resonant frequency. The audio subcarrier is at 4.5MHz, and if the the tuner is on-frequency the IF will be at 4.5MHz.
If the tuner drifts off-frequency the audio IF will differ from the nominal 4.5MHz, the Ratio Detector will then generate a voltage, which is fed back to the tuner to shift the local oscillator frequency.
I suspect the On-Off button was needed because the tuning could only be shifted a small amount, requiring the user to get close to the correct frequency (correct tuning).
Hope this helps!
Cheers,
Tom
