What is the Time t for a Train to Travel through a Tunnel between LA and NY?
  • Thread starter Thread starter onsem
The discussion centers on calculating the time, denoted as t, for a train to travel through a hypothetical tunnel between Los Angeles and New York, a distance of 5000 km. The analysis assumes a homogeneous Earth with a radius of 6378 km and neglects friction. The train's motion is described as Simple Harmonic Motion, with its acceleration determined by the formula -(g/R)x, leading to a period of 2π√(R/g). The estimated travel time through the tunnel is approximately 42 minutes, significantly faster than air travel.
  • Understanding of Simple Harmonic Motion
  • Familiarity with gravitational force concepts
  • Knowledge of Isaac Newton's Brachistochrone Problem
  • Basic grasp of Gauss' Law in physics
  • Research the mathematical derivation of Simple Harmonic Motion
  • Explore the implications of gravitational force inside a spherical shell
  • Study the Brachistochrone Problem and its applications in physics
  • Investigate the relationship between gravitational fields and electric fields as per Gauss' Law
Physics students, engineers, and anyone interested in gravitational mechanics and the theoretical implications of tunneling through the Earth.
onsem
Hi,
I need help with interesting assigment.
So, here it is:
I have to work out time t. t is time of a trip by a tunnel digged between LA and NY. Distance between LA and NY by surface is 5000km. Earth radius is 6378km. Friction is ignored. The motion is in a train propeled by a gravitational force Fg. Earth is homogenous.
When the train is moveing towards the centre of Earth the radius is decreasing R->r and then after the centre is increasing again.
Picture for this assigment is here:
http://forum.matweb.cz/viewtopic.php?pid=51967#p51967
Thanks a lot.
This is an interesting and straight forward problem for the shorted route. A more interesting and very challenging problem is finding the fastest route. Almost certainly there is a parabolic tunnel that is faster. A parabolic tunnel will permit the train to accelerate faster at the beginning, with more rapid deceleration at the end. In about 1697, Isaac Newton was challenged to find the fastest route for a frictionless sliding mass to go from point x,y to a lower point x1,y1. He used his newly developed "Calculus of Variations" to solve the problem in one day (according to blogs). His solution, known as the "Brachistochrone Problem", can be found on the web. His solution assumes a constant g, which is not true in this tunnel problem, however. See
http://mathworld.wolfram.com/BrachistochroneProblem.html
I'm looking for solution only for this one case.
Bob S might have said "cycloidal" rather than "parabolical" in his description
of the Brachistochrone problem.
Meantime, your diagram is particularly confusing.
You need to know that the gravity outside a spherical shell is
the same as if its mass was all at the centre, and that it is zero
inside the shell.
For a "homogeneous" Earth (constant density), gravity inside is gr/R.
If you let x be the displacement of the train from the middle of the tunnel,
you find that that the train's acceleration is -(g/R)x.
So no matter where the tunnel is drilled, the train moves in Simple Harmonic Motion
with period 2piSQR(R/g) - the same as a low orbit satellite!
David
inside the shell.
David
How are you accounting for the angle of the incline in the application of gravity? It changes through out the tunnel, and is 90° and hence no contribution to motion in the middle.
I Don't get it.
what is that circle in the middle of the earth?
I can help you solve something like
How much time does it take to travel from NY and LA by a straight tunnel inside the earth...
this can be done by simple harmonic motion ,or another way.
just tell me if this is the problem.
BTW for the problem I stated above, the time is constant for any distance you choose.
EDIT:
Just read David post, and he is right IMO, If this is the problem.
and the answer should be 42 minutes approx(way faster than an airplane :}).
sine of angle = x/r
gr/R * x/r = (g/R)*x
I agree a sensible diagram would help. Draw one:)
David
Ohhh, Now i get what is that circle in the sketch!
It's 2 show what David said, that the effective mass reduces and now the force is M=M(earth)*(r^3 / R(Earth)^3)/r^2 when r is smaller than R(Earth), inside earth.
which finally gives us g(inside Earth aka acceleration,towards the center )=g*x/R(earth) when x is the is the distance from the center of the earth.
i think :D
R is Earth's radius
r is distance of train from Earth's centre.
x is (AS I SAID) the displacement from the middle of the tunnel.
g is the gravitational field at the Earth's surface (of course).
The sphere which gives rise to the gravitational field has radius
r and should be concentric with the earth. The field has magnitude gr/R
and its component towards the middle of the tunnel is gx/R. This is the
acceleration of the train.
If you know Gauss' Law of "electric flux", the gravitational field is analogous to
to the electric field due to a sphere with uniform charge density.
10K
