Turbine performance: understanding notation
The discussion focuses on understanding turbine performance specifications, particularly the terms GT12, 72 Trim, and 0.39 A/R. GT12 refers to the model of the turbine, while 0.39 indicates the area-to-radius ratio. The 72 Trim designation is related to the design of the turbine wheel, impacting its performance characteristics. Additionally, the user seeks guidance on generating a corrected mass flow rate versus pressure ratio curve for a two-wheel bootstrap air cycle machine under varying flight conditions, despite lacking standard data at STP. The conversation emphasizes the importance of understanding these specifications for accurate performance analysis.
Rahul Mohan P
Hi Guys. This is for my post graduation project. I came across a turbine performance map where the turbine specs are mentioned as GT12, 72 Trim, 0.39 A/R. Now what exactly these terms means. Please help.
zAbso said:
http://turbobygarrett.com/turbobygarrett/wheel_trim
This should explain what trim is, I only briefly read over it but it should help.
Thank You. I have data for a two wheel bootstarp air cycle machine used in aircraft environmental control system for air-conditioning under working conditions. The data is for different flight conditions, different temperature and pressure. I want generate corrected mass flow rate vs pressure ratio curve of the turbine used in the system. I don't have the standard data noted at STP (standard pressure and temperature) conditions, and no manufacture provided performance curve, but can I generate a curve using the available values which is not taken under STP conditions.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 24 ·
11K
