Twin clocks-is it acceleration?
  • Level: Graduate
  • Thread starter Thread starter phyti
    Acceleration
58 replies · 8K views · last reply
stevendaryl said:
I assume what you mean is that you can describe the geometry of spacetime using noninertial coordinates, and that's certainly true.
Yes. I'm not against geometrical explanations. But if you do it only in the inertial frame, you are not really addressing the issue.
A.T. said:
You are missing the point of the twin paradox.
The question is not: "How can I explain the age difference geometrically in one inertial frame?"
The question is : "Why can't I use the same explanation in both twin's rest frames to get the opposite result?"
The answer to the question is : "Difference in proper acceleration profiles"
Is your point for the scenario in this thread that it doesn't apply to the Twin Paradox because neither twin is inertial?
So the only kind of answer that you will accept is one that shows an inertial explanation for the inertial twin and simply asserts that no such explanation applies to the non-inertial twin (simply because he is non-inertial)?
So when the questioner correctly points out that in the inertial twin's rest frame, there is a constant Time Dilation for the non-inertial twin (assuming instant turn-around), but the rest frame for the non-inertial twin is non-inertial and so it is an incorrect comparison and we simply stop right there. We just call foul?
bobc2 said:
phyti, too much focus is given to the acceleration. It's the path lengths through space-time that should be compared, regardless of whether one or both are accelerating and when the accelerations occur.
I agree with you, that's why the post. The accumulated time on a clock depends on the path. Obviously there must be a change in speed to assume a new direction. Ignoring the separation and reunion, we could easily have the A clock do a reversal, then both paths woud be 'bent'. Which acceleration/deceleration (there is a difference) counts?
Examining the expression for time dilation, the only factor is v/c. The space-time drawing with ct and x axes represents what?...speed, i.e. object motion vt vs. light motion ct, or v/c. The velocity change can be approximated with a series of inertial segments, without any significant loss of accuracy.
I don't understand this comment. Geometrical explanations are frame independent, they are not done in any frame. If an explanation uses any frame then it isn't a geometrical explanation.
However, I agree with what I think is your main point that the answer must be in terms of some asymmetry.
harrylin said:
Acceleration is indeed necessary to break the symmetry in SR (thus ignoring gravitational time dilation); it was the purpose of the "twin" example to clarify that fact. It should be stressed that what matters for the SR calculation is the velocity profiles.
I agree. Geometrically the acceleration is the "bend" in the worldline. That bend breaks the symmetry but by itself it doesn't add or subtract any length to the worldline.
I think that it is an interesting variation, which demonstrates that not only the total amount of proper acceleration matters, but its timing. It leads to a more general explanation of the asymmetry, which also applies to the classic version.
It is okay to assert that an "inertial explanation" doesn't apply to the rest frame of the non-inertial twin, if that is what you mean. But ideally you would also provide a non-inertial explanation for the non-inertial twin's rest frame, which leads to the same result as the rest-frame of the other twin.
This is what most "explainers" do. And I think it is not satisfying to most questioners. I would like to see it explained from both frames.
stevendaryl said:
I think that the answer "different acceleration profiles" for why one twin ages more than the other is misleading. It certainly is true that in flat Minkowsky spacetime, there is no way for two twins to depart and reunite unless one of them accelerates. But using acceleration as the cause of the difference doesn't generalize to other kinds of topologies of spacetime, and doesn't generalize to General Relativity.
In a cylindrical spacetime, you can have twins start off together, depart and reunite later without either twin accelerating. I guess you could say that such an example goes beyond SR, but it doesn't involve any gravity, so it's not very GR-ish, either. It's just geometry.
I don't think that it is misleading at all.
The explanation must be in terms of some asymmetry between the twins. If there is no asymmetry then their ages must be identical. The reason students are confused by the twin scenario is that they have just been introduced to this idea of symmetry under boosts so they believe that the twins are symmetrical.
Saying that "it's just geometry" is not a good answer, after all, you can have symmetrical geometric figures. Even geometrically, you must identify the asymmetry. In the standard twin paradox, the geometrical asymmetry is the bend in the worldline, i.e. the acceleration. So that is an accurate and not misleading answer. In other scenarios there are other asymmetries, the topology or the curvature or whatever.
When you draw a space time diagram or integrate the path element, you are assuming a frame. My point is that to convince people that the result is indeed frame independent, you have to do it for both frames.
I don't think so. Analogy with plane geometry:
Drawing curves, comparing angles, sliding figures, measuring lengths with a string, etc. [In SR, measuring time with a clock is equivalent to measuring length with a string in plane geometry].
do not involve coordinates. You can then draw on the plane many different cartesian coordinates, or polar coordinates, then do calculations in terms of those.
In SR you have a particular type of flat geometry. You can draw on it without coordinates. It has, objectively, straight lines. If you draw curvilinear coordinates on it, your curves are still curves - you haven't made them straight in a geometric sense.
As for frames, I think a key thing that is hard to convince people is that there is actually no such thing as a global non-inertial frame in SR (just as there is no such thing as a global frame at all in GR - inertial or otherwise). There are many possible accelerated coordinates (equivalent to curvilineary coordinates on a plane), each of which will represent the intrinsic flat geometry superficially differently.
Ok, good.
Isn't that what I did in these threads:
https://www.physicsforums.com/showthread.php?t=670653&page=10 post #135
https://www.physicsforums.com/showthread.php?t=644948&page=6 posts #92 and #93
https://www.physicsforums.com/showthread.php?t=671398&page=3 posts #35 and #36
In each of these three cases I provided an inertial spacetime diagram for the stay-at-home twin's inertial rest frame and a non-inertial spacetime diagram for the traveling twin's non-inertial rest frame and yet none of the OP's for which I provided these diagrams responded with any statement to the effect that they understood the diagrams. I just don't know if they are effective.
Didn't I explain it from both frames and didn't I show that both rest frames lead to the same results?
PAllen said:
I don't think so. Analogy with plane geometry...
It depends on who you're trying to convince. You ought to be right, but my experience is that for most audiences A.T. is. It may just be that you get to deal with a better class of audience. :smile:
Actually my phrase "I don't think so" was referring to specifically A.T.'s statement:
"When you draw a space time diagram or integrate the path element, you are assuming a frame"
for which I agree computing an integral requires coordinates, but drawing a spacetime diagram does not.
I was not making any statement about pedagogy. On that score, I find different arguments work for different people.
When you draw a diagram with twin A at a constant space coordinate, you have assumed twin's A rest frame.
I disagree, any more than saying drawing a straight line on a blank paper assumes a coodinate system. Maybe I'll fill in the coordinates at a angle to the line if I choose to add them.
Sorry, no idea what you mean.
You have, but that didn't happen when you drew the twins' worldlines, it happened when you added the axes to the diagram.
One interesting pedagogical trick: Draw up a spacetime diagram without the axes, then draw up a bunch of transparencies, each with their own set of t and x axes - and then drop the various transparencies onto the diagram to show how coordinates work. This has the nice property of making it clear that the proper intervals belong to the coordinate-free picture, and suggests why "frames" are called that.
(There still is one downside - some people fall into the trap of believing that one particular frame, namely the one in which the x and t axes are at a 90-degree angle, is somehow special and distinguished).
I don't understand them either.
Spacetime diagram of twin worldlines: vertical black line for the stay-at-home twin from 2007 to 2017 and a blue V-shaped path for the traveling twin, with light signal lines crossing between them and years labelled on both sides.
I don't understand the phase where they have constant separation. In reality the blue signals send during that phase should arrive blueshifted, but there is no movement of the source in the diagram. If the signals are simply a picture seen through telescope, the angular size of blue twin, as seen by black twin would be increasing after turnaround. But in the diagram the viewing distance is constant for a few years.
I think it is very difficult to make a smooth and correct diagram for the sharp turnaround version. The simpler case might be the one with constant proper acceleration, then you have just one coordinates chart (Rindler) for the rest frame of the accelerating twin, not two that you have to merge somehow.
See Fig 7:
http://cds.cern.ch/record/497203/files/0104077.pdf
Note: Rindler coordinates are radar coordinates for the uniformly accelerating observer; Fermi-normal coordinates (ones modeling a rigid grid of rulers) have extra terms in the metric, and the coordinate axes are different. For an inertial frame in SR, these two coordinate building approaches produce the same result. The is really why (IMO) you can reasonably talk about (global) inertial frames in SR - different reasonable methods of building coordinates agree. It is also why I insist there is actually no such thing as an a (global) accelerated frame even in SR: even for the the simplest acceleration (uniform), the two simplest physical methods of building coordinates produce a different result.
In this version of radar coordinates the horizontal does not represent proper distance along a simultaneity surface. Instead, it represents 1/2 round trip travel time for a signal (from traveler to home and back) as measured by sudden turnaround traveler, times c. For classic sudden turnaround, there is, indeed, a period of time when such signals have constant round trip time. Proper distance along the same simultaneity lines would produce a different diagram. And, of course, since the diagram is drawn from traveler perspective, the simultaneity lines are straight.
Thanks. Do you have some links on Fermi-normal coordinates in uniformly accelerated frames and Minkowski space-time? The wiki says it is just a generalization of Rindler for curved space-times, so I assumed that for accelerated frames in flat space time they yield the same results.
For a beautiful derivation that Rindler coordinates are radar coordinates, our very own George Jones recently produced:
https://www.physicsforums.com/showpost.php?p=4278480&postcount=5
From the wikipedia article, the metric for Rindler coordinates is:
ds^2 = - g^2 x^2 dt^2 + dx^2 ...
I don't know of a good online reference for Fermi-Normal coordinates of a uniformly accelerated observer in SR. However, section 6.6 of MTW derives this (without calling it that). This section is all flat spacetime. The metric becomes:
ds^2 = -(1+ g x)^2 dt^2 + dx^2 ...
Note how this form approaches Minkowski metric for x=0. For Rindler coordinates x=0 represents the horizon. Also note that if you just transform Rindler to have its x=1 line become new x=0, you still don't get Fermi Normal; you get:
ds^2 = -(g+gx)^2 dt^2 + dx^2 ...
What you need is x' = x - 1/g to get from Rindler to Fermi-Normal.
[Edit: On further thought, it appears that Fermi-Normal coordinates as above, for a uniformly accelerating observer would still have the same simultaneity surfaces as Rindler and Radar - just labeled differently. Thus, it seems, you need change in acceleration - e.g. the classic twin with slightly rounded turnaround - to expose the difference between Radar simultaneity and Born Rigid simultaneity (which is what Fermi-Normal uses).]
I think we are talking about different kinds of explanations. What I would call a geometric explanation wouldn't draw any coordinates.
Spacetime diagram of a twin paradox scenario: coordinate time in years against coordinate distance in light-years, with a vertical worldline labelled 2007 to 2015 and a bent worldline turning around near 2015 and returning to 2017, with blue and black grid lines between them.
See Fig 7:
See Fig 9 of your above link. Barbara is the "Immediate Turn-around" traveler, Alex stays at home. The diagram is showing the non-inertial rest frame of Barbara.
The diagram uses radar coordinates, the same approach as Einstein's convention, but applied to a non inertial observer. Since the resulting coordinates are non inertial you can get red and blue shifting without relative motion. I.e. The standard inertial frame formulas don't apply.
Thanks for the explanation. So you say for constant g there is no difference. But what would the difference be otherwise? Would you actually get different age differences by integrating the paths, or just different simultaneity in between?
Just different simultaneity in between. Also different applicability:
- Fermi-Normal simultaneity = Born rigid simultaneity = spacelike geodesic 4-orthogonal to world line tangent = simultaneity of intantaneous comoving inertial frame are all inapplicable to an instant turnaround; they are also inapplicable to a W shaped twin path (the simultaneity lines intersect).
- Radar simultaneity works for instant turnaround and W shaped trajectory with no problems.
However, where they both work, any observable is computed to be the same. Something non-observable, like distant simultaneity between world lines, is different.
Do Fermi-Normal coordinates have the same proper acceleration for every x? Because in Rindler coordinates it varies with x.
As I realized when I saw that a trivial coordinate transform went from Rindler to Fermi-Normal:
- their lines of simultaneity are identical
- the feature of varying proper acceleration for world lines of constant x, at different x values, is a feature of both.
Since the writer of a paper is so familiar with their own material, there is
always the possibility for the reader to misinterpret or not understand some
parts due to insufficient details, excessive complexity, verboseness,
mistakes, etc. Having experienced this as a reader, this is an attempt at an
improved version of the original post.
https://www.physicsforums.com/attachments/56188
