Twin paradox without accelerative frame.
118 replies · 12K views
Trojan666ru said:
We reached the same conclusion before the #42nd post. Now answer my #42 question?
OK, here's your post #42:
Trojan666ru said:
I'm making some arrangements in distance from the above question to calculate reflected time
They are separated by 4 LY.
When they receive the first signal from the coordinator, they starts to accelerate and when both the boxes travel exact 1 LY (from the coordinator view) they will attain .5c. That instant is simultaneous for the coordinator. From that instant there will be only 2 LY distance between the boxes. As preplanned the coordinator has already sent another signal for activating the stopwatch at the exact instant it travels (green box) 1 LY. So these events are simultaneous in coordinator frame
Here's a diagram depicting this scenario:
Trojan666ru said:
From the rest frame of red box the green box is the one moving with .8c.
Here's a diagram for the rest frame of the red box:
Trojan666ru said:
So the signal which hits the green box has only 2LY distance between the boxes, so how much time does the signal takes to reach the red box?
Greater than 2 years, Lesser than 2 years or Exact 2 years?
As you can see, in the blue coordinator's rest frame, it takes less than 2 years for the green signal to propagate from the green box to the red box but in the red box's rest frame, it takes more the 2 years.
I wasn't sure which frame you wanted the answer for so I gave you both answers.
Any more questions?
Now there's the problem!
As you said, in the blue box reference frame there is only 2Ly distance between the red box & green box at the instant it reaches .5c
So the reflected light will take only less than 2 years to reach the red box interferometer (in blue box frame)
In addition since the red box is moving with respect to the blue box, its time is dilated and therefore will receive the signal before its stopwatch ticks to 2 years
If the stopwatch & interferometer are a part of time bomb which is programmed not to explode if the signal hits there before 2 years, then from the blue box’ rest frame there won't be any explosion but from the red box’ rest frame, the signal has to travel more than 2Ly distance (as shown in your space-time diagram) and therefore it hits the stopwatch only after 2 years, therefore the bomb explodes!
The stopwatch starting is a specific event. A signal reaching the stopwatch is another event. The time a specific clock reads between two events on its history is invariant in all frames. You are confusing this with judgement about simultaneity, which has no effect on a specific clock. In both of gwellsjr's diagrams, look at the tick marks on the red world world line between when the stopwatch starts and when the signal arrives. It is less than 2 in both frames. This fact is independently computed in both frames. Thus both frames agree the bomb will not go off.
I think you will see that there's no problem.
Correct.
Correct, but again, note that the red box's stopwatch is only Time Dilated in the blue coordinator's rest frame (the first diagram). In the rest frame for the red box, it's own clock is not Time Dilated but the blue coordinator's clock is Time Dilated by the same amount as the red box's stopwatch was Time Dilated in the first frame. Can you see this difference in the two diagrams?
In both frames, the green signal gets to the red stopwatch when it reads about 1.15 years. It's exactly the same in all frames so the bomb won't explode in any frame.
If you go back to my first post (#17) you will see that I said just before the first diagram, "The dots represent 1-year increments of time for each observer". As you can see, the first red dot representing zero years on the stopwatch occurs when the second blue signal arrives from the coordinator which starts the stopwatch ticking. (Actually, the stopwatch has been inactive and sitting at zero for the entire time along the thick red line prior to the first dot.) The next red dot represents one year on the stopwatch and a short time later, the green signal arrives from the green box. The last red dot is when the stopwatch gets to two years and it doesn't happen until after the red box passes both the blue coordinator and the green box. Isn't all this very clear in both diagrams?
It's important to realize that no frame changes what any observer can see or measure. The red box only knows the times that the signals arrive at its location, it has no awareness of when those signal were sent or when other signals arrive at other locations.
You're forgetting relativity of simultaneity again. In the red box' rest frame, the signal leaves the green box *before* the red box' stopwatch starts--about a year before, looking at ghwellsjr's spacetime diagram. So the red box' stopwatch is only running for a little over a year when the signal arrives; and since it's the reading on the stopwatch that determines whether the bomb explodes, the bomb does not explode.
What about this quote?
That quote was in response to these questions:
Those questions are not about the Proper Time on a single clock which was your criterion for the bomb, they are about the difference between two Coordinate Times which is different in each coordinate system we use. Note that the Proper Time on the green clock was zero when the signal started and it was 1.15 on the red clock when it was received (in both frames) but the Coordinate Times for those two events are totally unrelated. In the first frame, the Coordinate Times were about 7.15 and 8.5 (with a difference of about 1.35) and in the second frame they were about 7.7 and 10 (with a difference of about 2.3).
If you wanted to make the bomb explode according to the Coordinate Time in one frame and not the other, you would have to incorporate a switch in the bomb which would define which frame it was supposed to respond to and then, depending on the switch, it would either blow up or not in all frames.
In the beginning all three boxes were at rest relative to each other. It is also clear that from all three observers point of view the distances are well defined (ie 4Ly in total and in the middle a half silvered mirror)
But somehow from the red box’ point of view, the green box receives the signal from the coordinator earlier than the red box. Why is it so?
Is that because the coordinator sends the green signal earlier and red later?
Or
The distance between the coordinator and red box suddenly increased & the distance between the coordinator and green box decreased?
George: Probably the distance got suddenly changed, that's what spacetime diagram says, but how?
The latter.
The two pulses are emitted at the same time in the same place. This is one event, so must be one event in all frames. They are received in the same place at the same time - again, one event, so one event in all frames.
However the reflections do not occur at the same place. Observers do not, in general, agree on the simultaneity or order of these events, nor their spatial locations.
In the red frame, the coordinator is moving towards the red box. The light pulse travels to the box, but by the time it gets there the blue co-ordinator is closer to the red box. Its return journey is shorter than its outbound one.
The green box is also coming towards the red box. For the other light pulse, then, the green box is closing the distance it has to cross. After reflection, though, the pulse is chasing after the blue box - it has extra distance to travel to catch it. That means that its outbound journey is shorter than its return journey.
If you require that lightspeed be constant, the only way to resolve this is to allow events to happen in different orders for different people, and different distances apart. The Lorentz transforms desribe the detail. This is Special Relativity.
If you require global simultaneity (that events that are simultaneous for one person are simultaneous for all), then you have to let lightspeed vary to cover the different distances in the same time. The Galilean transforms describe the details. This is Newtonian physics.
Both views are internally logically consistent. However, all experiments capable of differentiating the two agree with Special Relativity.
You are thinking of distance as all there is to know about the separation of two points in space. This is not correct - remember that time is a dimension. The separation between two events in spacetime is the constant thing. It's called the interval:
[tex]s^2=(ct)^2-(x^2+y^2+z^2)[/tex]
Wondering why the distance changes is analogous to wondering why people sitting round a table don't agree whether it's a long table or a wide table.
I suggest you google "block universe" for a better explanation.
Yes, that is all very true. However, you have to be careful with that term "point of view" because it sounds like we are referring to something each box can actually see. Instead, in this context it just means "the Inertial Reference Frame (IRF) in which the object is at rest". In order to determine what each box can actually see, you have to look at the thin lines coming from the other boxes and arriving at the box you are concerned with. Each box has to wait for the light signals to get to it. The farther away the source of the light, the longer it takes to get there.
Since the red box has accelerated it has more than one IRF in which it is at rest so when we want to switch to the IRF in which the red box is at rest at the end of the scenario we have to use the Lorentz Transformation process to see what things look like in this second IRF. But if you do the same thing that I described for the first IRF (draw in light signal lines) you will discover that both IRF's show exactly the same phenomenon in terms of what the red box can actually see.
No, look at the thin lines coming out of the coordinator, in both diagrams, they depart at the same time.
Trojan666ru said:
Or
No, in the second IRF, the distances are Length Contracted by the same amount but it's because the propagation of light is c in all directions in any IRF (by SR's definition) and all the boxes are moving so the ones moving in the same direction as the light will take longer and the ones traveling against the light will take less itme.
ghwellsjr said:
... Any questions or further concerns? ...
According to your first diagram in #59 (the twins scenario being described in the IRF showing the coordinator at rest), the SR theory represents both travelers moving toward each other at a relative speed equal to c in that IRF (their initial distance is 4 light-years and they meet 4 years later).
Should each of them travel at 0.7c toward the coordinator (instead of 0.5c), would the SR theory indicate that their relative speed in respect to each other is equal to 1.4c in the coordinator's IRF?
More generally, is it correct to assume that the standard addition of vectors still holds for velocities provided their magnitudes relate to the same IRF?
Usually this speed is called a "closing speed" rather than a "relative speed", so as to distinguish it from the speed that each measures relative to themselves.
Yes, that would be a closing speed of 1.4 c.
Closing speed doesn't really have a direction, so it isn't a vector.
I would say that if in frame A you have object B traveling with velocity ##\vec v_{BA}## and object C traveling with velocity ##\vec v_{CA}##, then the separation velocity (in frame A) of object C from object B is just the difference ##\vec v_{CA} - \vec v_{BA}##, which is a vector.
However, this separation velocity does not equal the the velocity of C in B's rest frame ##\vec v_{CB}## (which is what we normally mean by the relative velocity of C and B). For that, you need a vector version of the "relativistic velocity addition" formula, which I'm too lazy to look up at the moment.
One formulation in, terms of 4-velocities, for the relative speed is:
v = || U2 - (U1 ∙ U2) U1 || / (U1 ∙ U2)
The spatial direction vector of U2 relative to U1 is then:
U2 - (U1 ∙ U2) U1
If this is computed in components in some inertial frame, the spatial vector will be expressed in axes parallel to that inertial frame, which is often what you want.
DaleSpam said:
... Yes, that would be a closing speed of 1.4 c. ...
Thanks for your answer. I tried to extrapolate a diagram by Gwellsjr to address the first phase of the basic twins scenario, assuming that each traveler and the associated clock moves away from the coordinator at a relative speed of 0.7c (in respect to the coordinator's rest frame), whilst sending light pulses backwards at a definite frequency. I concluded that each traveler would still receive the light pulses propagating the “ticks” of the other traveler's clock, in spite of their “closing speed” (does this wording also hold if both travelers move away from each other?) equal to 1.4c in the coordinator's rest frame. This sounds non-intuitive. Is it correct? Actually on the diagram it seems that 2c is the absolute upper limit for this exchange of information taking place, isn't it?
ghwellsjr said:
Now I will transform the scenario into the rest frame of the red box after it has accelerated to 0.5c:
As you can see, the previous analysis of what they each can actually see is maintained in this space time diagram, but in addition, we can see the other analysis where the green box started accelerating way before the red box did and that's why both of them can accumulate the same amount of time (3.5 years) during their trips, but only the green box is Time Dilated in red's rest frame.
That's what i do not understand yet. Even before starting experiment (while everybody is at rest with respect to everyone) how can the green box receive the information for acceleration earlier than red box?
If i conduct this experiment in small scale, with a 100m distance, and if I'm sitting inside the red box, will i see the green box receiving the signal earlier than me?
What if we have no plan to accelerate the boxes? Still the green box receives the signal earlier?
Sugdub said:
I concluded that each traveler would still receive the light pulses propagating the “ticks” of the other traveler's clock, in spite of their “closing speed” ... equal to 1.4c in the coordinator's rest frame. This sounds non-intuitive. Is it correct?
Yes, it is correct. The 1.4 c closing speed is not the speed of anything, so it is not relevant to determining whether or not something can outrun a light signal.
There is no exchange of information taking place at anything greater than c, but 2 c is the upper limit of closing speed.
Don't forget that simultaneity is frame-dependent, which means that statements about simultaneity inherently have no meaning unless you also state the frame that simultaneity is judged relative to. So, the question you asked is inherently incomplete.
You should ask something more like "how can the green box receive the information for acceleration earlier than red box in a frame where they are all moving to the left?". Then the answer is "because the light has less distance to travel to reach the green box it takes less time".
The distance scale is not relevant. If the green box moves towards the emitter then it will receive the signal earlier.
Future plans are also not relevant.
"Earlier" is frame-dependent. The green box receives the information earlier with respect to the frame in which the red box is at rest *after* it has accelerated. Changing frames changes the time coordinates of all events, not just the ones after a certain point.
It depends on how you assign time coordinates to events on the green box's worldline. Since the events of the green box receiving the signal, and of the red box receiving the signal, are spacelike separated, their time ordering (which one happened "first") is not invariant; it's frame-dependent. So you can assign any time ordering you like and still be consistent with all observations.
The diagram ghwellsjr drew assumes that the red box assigns time coordinates to all events using the inertial frame in which it is at rest after it has accelerated. But there are other ways it could assign time coordinates to events that could give different answers.
The fundamental point you keep on missing is the one I said above, which I'll restate: The time ordering of spacelike separated events is not invariant. Therefore it is not a good thing to focus on if you're trying to understand what's happening. You should focus on things that are invariant, like the fact that the red clock and the green clock show the same reading when they meet.
Re-uploaded diagrams
You showed the rest frame for the red box after acceleration. Here's the rest frame for the red box before acceleration with the Proper Times on their stopwatches marked:
The issue of which box received the signal first depends on the frame because we are talking about simultaneity issues which are frame dependent. If you look at the third diagram in my first post (#17) you will see that the red box receives the signal for acceleration earlier than the green box. In the above frame, they both receive their respective signals at the same Coordinate Time of 3 years when their stopwatches are activated to start ticking from zero. But neither one can see that the other one received his signal at the same time as his own. Observers cannot see Coordinate Times for remote events.
But later on, each one can see the other one receiving the reflected signal or the image of the Proper Time on the other ones stopwatch. In the above diagram, can you see that the green signal that came from the green box when it started to accelerate (at its Proper Time of zero) arrives at the red box when the Proper Time on his stopwatch reached about 2.3 years? I hope the Proper Time markings have made this very clear.
The same thing applies for the green box watching the Proper Time on the red box's stopwatch. He also sees the red box's stopwatch start ticking when the Proper Time on his own stopwatch reaches 2.3 years.
I have added the same Proper Time markings on the diagram that you showed:
Can you see that the Proper Times on both stopwatches and the signals that go to and from them are identical in both frames even though the Coordinate Times and Coordinate distances are different? Both of these frames contain identical information. The boxes don't know that we have drawn two different diagrams with different coordinates. All they know is what they can see when, according to the Proper Times on their own stopwatches, the signals arrive at their own locations.
No, just like in the above two diagrams, you won't see what is happening on the other box until later on. But if you go to the effort of sending radar signals (like you mentioned in your first post) and collecting observational data and you apply Einstein's convention that light travels at c in any Inertial Reference Frame, then you can construct a non-inertial rest frame for yourself and from that you can construct either of the above two inertial diagrams and then you will be able to see what we can see.
Trojan666ru said:
What if i have no plan to accelerate my boxes? Still the green box receives the signal earlier?
The issue of which is earlier is dependent on the frame you chose to answer the question in. But what they can see, measure and observe is the same in all frames. If you imagine in the above diagrams that the red and green lines continue in straight lines, then you will see the image of the red box starting its stopwatch when your own stopwatch reaches 4 years, but remember, in this case, your Proper Time is not dilated in the original defining IRF.
I'm working on another answer to your previous post which may help clarify your questions. I hope to post it shortly.
I can't see you drawings from #81 have you removed it?
I answered this post already but it wasn't a very good answer.
Now I want to show how each observer/object can use radar signals and other observations to determine the answers to all your questions. The important point is that they each will follow the exact same procedure that you described in your very first post where the observer sends signals to the other objects and watches for the echo to get back to him, along with his observation of the time on the other objects' clocks so that he can verify how far away they are from him. And most importantly, the apply Einstein's convention that light travels in all directions at c. It is this one fact that makes the simultaneity issues different in each frame.
So for this purpose, we need to have clocks attached to each object (not just inactive stopwatches that are started at a particular time). We will assume that all three clocks are synchronized to the Coordinate Time in the defining Inertial Reference Frame (IRF) that applies when all three objects are in mutual rest. Here is a spacetime diagram for the defining IRF with Proper Time markings for the red and green boxes. The Proper Time for the blue coordinator matches the Coordinate Time so I didn't make special markings for him. I had to continue the scenario on both ends to enable the radar signals to work:
I have also marked the same signals that are shown in post #61, namely a pair sent by the blue coordinator at his 1-year mark and received by the boxes at their 3-year marks to start their accelerations toward the coordinator and another pair sent by the blue coordinator at his 6.2-year mark and received by the boxes at their 7-year marks when their accelerations end and when they start their stopwatches (which we are not concerned with now) and when they echo signals back toward the coordinator and the other box. When those red and green signals pass through the half silvered mirror located with the coordinator, I show them as yellow as they progress to the other box.
Now I want to go through a little exercise to show how an observer can use radar signals and other observations to construct his own reference frame in which he is at rest. I will start with the blue coordinator because he is already at rest in the defining IRF and the process will be much more obvious. Here is a diagram showing the important blue radar signals that the coordinator sends out and the return reflections coming from the red and green boxes. The coordinator has to be sending out radar signals much more often than I am showing them but I have selected just a few that will make our process easier to perform:
For each radar signal that is sent, the observer keeps track of when it was sent according to the Proper Time on his own clock. After he receives the reflection, he keeps track of the received time and the observed Proper Time on the target. He keeps a log of these three numbers for each radar signal. Then he calculates a distance and a time for each set of numbers. These calculations use Einstein's convention that the radar signal takes the same amount of time to reach the target as it takes for the reflection to get back to the sender. The distance is merely the received time minus the sent time divided by two and then multiplied by the speed of light which in our example is 1. The time at which this distance applies is the average of the sent and received times. This will enable him to make a diagram showing his results as a function of his Proper Time. He is doing this separately for each object.
Let's go through one example at the bottom of the diagram. At his time of -6 years, the coordinator sends out a radar signal (in both directions but we can focus on just one). At his time of -2 years, he gets the reflection signal. He takes the difference, which is 4 and divides by 2 to to get a distance of 2 light-years. He knows that the distance is to the left for the red box and to the right for the green box. He averages -6 and -2 to get -4 as the time the box was 2 LY away. I hope this is clear. Now he just repeats this over and over again and from the calculations, he can draw a diagram just like the one we have been looking at. As he gets to the portions where the boxes are accelerating, his log of sent and received times will include times with fractional parts so we have to interpolate between the dots. Here is his final diagram:
Now we want to graduate to the red box who is going to make a diagram showing the position of the coordinator and the position of the green box as a function of his own Proper Time (marked off by the red dots). We start with the same original defining IRF and draw in the red radar signals sent by the red box and going to the blue coordinator. The reflections are shown in blue as they come back to the red box:
Next, we have a similar diagram showing the red radar signal going to green box and the green reflections coming back to the red box:
And here is the diagram that the red box constructs from all the radar signals and observations of the Proper Times of the other two objects:
I have drawn in the same signals that were in the first diagram in this post so that we can see that the signals arrive at the same times.
It's because the red box is applying Einstein's convention that light travels at c in his rest frame.
No, in all frames, the blue coordinator sends signals to both boxes at the same time.
Trojan666ru said:
Or
Not suddenly but gradually as you can see in the last diagram. But again, this is because the red box is applying Einstein's convention to his rest frame. It's not something that he can see or something that is intrinsic to nature. It's a man-made convention (the man being Einstein).
I said at the start that I didn't like my previous answer. I didn't realize at that time that the what you said about the two distances is true but now I realize that those two distances are different in the red box's rest frame. But, keep in mind that we could do this exercise all over again from the point of view of the green box and everything would be opposite. Then the red box would receive the signals from the coordinator earlier than the green box. It all has to do with Einstein's convention and the fact that the farther away an object is, the earlier you have to send a radar signal to it and the later you get its reflection compared to a closer object.
Well, I hope this helps. Keep asking if you have more questions. But please study this response in detail first.
No, at least not on purpose. I don't know why this happens. I can see them on my webpage which means I did upload them but for some reason after doing all the edits, they don't appear for others on the final submission even though they appear for me.
Anyway, I have re-uploaded them so hopefully you can see them now.
With acceleration as slow as in these examples, an important detail may be missed about relativity.
Acceleration, or in other words changes of reference frame, mean changes in what one would call "present".
Unlike velocity, there is practically no limit on acceleration, so it can even be approximated to instantaneous. Then distances and remote clocks may actually be said to suddenly change, i.e. objects seem to jump through space and time. But of course it is not a real, physical change, just a change in point of view.
Acceleration does not require a change in reference frame and doesn't have to mean the kind of instantaneous changes in what one would call "present" that you are talking about. You can do that if you want but since "present" at remote locations is fickle, you can do exactly what I did in post #83 where the acceleration is slow to the scenario in post #81 where the acceleration is instantaneous and you will see a point of view for the red box that is based on actual measurements that the red box can make and it won't have any of the abrupt changes that you refer to.
I invite you to make a diagram for the point of view you think is required by abrupt acceleration for the scenario in post #81 and then I invite you to make one based on the process I describe in post #83. Can you do that?
I've already had lectures on radar measurement by you or maybe by DaleSpam, thank you.
The fact that an observer's own past and future motion affects what he would consider the current state of remote objects makes this a pretty useless system for me.
You and DaleSpam are both free to continue using it of course, but try not to completely distract people interested in learning the subject from the much simpler and objective system of direct application of the Lorentz transforms for the momentarily comoving inertial reference frame of the observer.
georgir said:
...but try not to completely distract people interested in learning the subject from the much simpler and objective system of direct application of the Lorentz transforms for the momentarily comoving inertial reference frame of the observer.
You do realize that this only works locally (in general) right? Oh the irony.
An Inertial Reference Frame (IRF) is based on an observer's own past and future motion--namely that it be inertial. Also, an IRF is exactly identical to using radar measurements. The Lorentz transform only works between two IRF's. So if you object to radar measurements, then you must also object to using a comoving IRF.
And if you think it is much simpler, then I challenge you to make a diagram showing the red box's comoving IRF for this scenario:
Or if you object to the slow acceleration, do it for this scenario:
No point in giving me homework, I know that gradual acceleration would be a hell of a math puzzle for me, and that instant acceleration results in disjointed worldlines, with repeated or missing times.
But the fact remains, radar measurements are no better in other aspects, namely objectivity.
If you have two observers, A at rest relative to a subject some distance away, and B in inertial motion retative to them, and you get observer C that "jumps ship" from A to B at the moment when the two cross, C would not agree with A about the distsance or velocity of the subject a certain time before the jump, nor with B a certain time after it, despite being in exactly the same spot observing exactly the same things as them at the specific moment. Such a system is not something you'd see in a physics textbook, ever.
