How Does the Center of Mass Move in the Two Body Spring Problem?
  • Thread starter Thread starter teme92
    Body Spring
The discussion revolves around a problem involving two blocks connected by a spring on a frictionless surface. The scenario begins with one block being struck, initiating motion and affecting the center of mass and relative positions of the blocks.
  • Participants explore the definitions of center of mass and relative position, questioning how these quantities change after an impact. There is an attempt to derive equations for the center of mass and the relative distance between the blocks.
Some participants have provided conceptual insights regarding the motion of the center of mass and the implications of conservation of momentum. There is ongoing exploration of how to express the relationship between the center of mass and the relative motion of the blocks.
Participants are discussing the initial conditions of the system, including the rest state before impact and the implications of no external forces acting after the impact. There is a focus on understanding the motion in the center of mass frame of reference.
teme92
Two blocks sitting on a frictionless horizontal surface are connected by a light spring. The natural length of the spring is ##d##, and the spring constant is ##k##. The two objects are initially both at rest, with the spring neither stretched nor compressed. At time ##t = 0##, ##m_1## is struck a blow that gives it an initial velocity ##v_0## toward ##m_2##. Taking the initial position of the centre of mass to be zero, use the equations of motion for ##\ddot R## and ##\ddot r## to show that the center of mass and relative position are given by
##R=\frac{m_1v_0}{M}t##, ##r=C+Asin(\omega t+\delta)##
where ##\omega = \sqrt{k/\mu}##. Use the initial condition for ##r## to show ##\delta = 0## and ##C=d##.
##m_1\ddot r_1=F##
##m_2\ddot r_2=-F##
##M\ddot R=0##
##\mu\ddot r=F##
##r_1=R+\frac{m_2}{M}r##
##r_2=R-\frac{m_1}{M}r##
So ##\mu\ddot r=F## is the same as ##\mu\ddot r=m_1a_1##. Differentiating to get:
##\mu\dot r=m_1v_1##, and again
##\mu r=m_1r_1##, where ##r_1=v_0t##
Therefore ##\mu r=m_1v_0t##
##\mu r## simplifies to ##MR##. Subbing in and I get required:
I have no idea how to get ##r=C+Asin(\omega t+\delta)## however. Any help would be greatly appreciated.
Ok, I think you are having some conceptual difficulty here. Do you understand the following?
- ##R## is the location of the centre of mass of the system.
- ##r## is the distance from one mass to the other.
So at the start, before the impact, everything is at rest. So at the start there is no momentum for anything. So ##R## starts out as 0. And ##r## starts out as ##d##. So far so good?
After the impact there is some momentum. This means that the centre of mass of the system has to be moving. But after the impact there are no more external forces. So after the impact, the centre of mass of the system will move with constant velocity. So what does that mean for ##R##?
Now to get the equation for ##r## the easy thing is to go to the centre of mass system of coordinates. In that system you have the centre of momentum at rest, and ##R'## is just 0. In that system, just after the collision, you have the two masses moving towards each other such that they have equal magnitude but opposite sign momentums.
Can you work it out now?
DEvens said:
After the impact there is some momentum. This means that the centre of mass of the system has to be moving. But after the impact there are no more external forces. So after the impact, the centre of mass of the system will move with constant velocity. So what does that mean for RR?
I assume that means that ##R## changes with respect to time.
DEvens said:
Now to get the equation for rr the easy thing is to go to the centre of mass system of coordinates. In that system you have the centre of momentum at rest, and R′R' is just 0. In that system, just after the collision, you have the two masses moving towards each other such that they have equal magnitude but opposite sign momentums.
Is this the conservation of momentum?
Yes, but in what way, exactly? Can you write an equation involving ##\ddot R## from that?
Not really. DEvens is advising you to use the frame of reference of the common mass centre. The behaviour of that common mass centre, R, discussed above, is governed by conservation of momentum. DEvens' later remark about how the two masses move in relation to each other within that reference frame follows from the definition of mass centre.
