Two boxes connected with a pulley, one hanging
  • Thread starter Thread starter frozenguy
    Pulley
19 replies · 8K views · last reply
frozenguy
Two boxes connected with a pulley, one hanging *updated*
There is a Mass (m1) on a table. The coefficient of friction between the table and m1 is 0.18. The second mass (m2) is hanging, suspended by a string around a pulley (m3) attached to m1. The pulley has a radius (R) and is considered a solid cylinder.
m1=3.5[kg]
m2=2.8[kg]
m3=1.9[kg]
R=0.089[m]
Find:
a) alpha of the pulley
b.)Ft1
c.)Ft2
d.)omega @ (6.9)
I for solid cylinder = (1/2)M2R2
Fnet=ma
Torquenet=I*alpha
alpha=a/R
I drew a torque fbd for the pulley, I found I for the pulley, I drew fbd's for the boxes, got my equations like
m1-->
X) Ft1-Ff=m1a
Y) Fn-Fg=0
Fn=m1g
Ft1=m1a+Ff
Ft1=m1a+Mew*m1*gm2--->
Y) Ft2-Fg=m2(-a)
Ft2=-m2a+m2g
and finally
Torquenet=I*alpha so
Torque1=R*sin(90)*Ft1 = R*Ft1 (k)
Torque2=R*sin(90)*Ft2 = R*Ft2 (-k)
==>R*Ft1-R*Ft2=I*alpha
and alpha= a/R
So
R*(m1a+Mew*m1*g)-R*(-m2a+m2g)=((1/2)M3R2)*(a/R)
That equation just has one uknown --> a
For a i got 3.97[m/s2]
For alpha I am getting like 44 [rads/s2] and others are getting about about 16 [rad/s2]
Can someone spot what, if anything, I'm doing something wrong?EDIT: Sorry for the mistakes..
It would be easier to spot an error if you showed your three primary equations (for m1, m2, and m3) and your solution for acceleration symbolically (without numerical values plugged in).
Doc Al said:
Which is which? Is m3 the pulley or the hanging mass?
The question identifies the masses. m3 is the pulley
m1=3.5[kg]
m2=2.8[kg]
m3=1.9[kg]
R=0.089[m]
Find:
b.)Ft1
c.)Ft2
d.)omega @ (6.9)
Fnet=ma
Torquenet=I*alpha
alpha=a/R
m1-->
X) Ft1-Ff=m1a
Y) Fn-Fg=0
Fn=m3g
It should be m_1 there
unfortunately in my following equations though, I treated m3 as the mass used in Force of tension 2, where that should have been m2..
I'm starting to screw myself up now, after solving for a from that last equation I wrote up there, I got a different value for a then I originally got..
Then I realized that Ft1 is negative on my fbd, so I tried changing that and I got a totally different number that no one else has.
All I have to do is find my three equations, and solve for a right?? Why is this proving to be so difficult for me..
To make my point more clear: the rotation is clockwise, so the angular rotation is
alpha (-k), not alpha k . This is why we end up with
R*Ft1-R*Ft2=- I*alpha
or
-R*Ft1+R*Ft2= I*alpha
nrqed said:
You are on the right track! Don't get discouraged, you are almost done.
Looks to me like it should be -Ft1+R*Ft2= I alpha
since the mass m2 is falling, the torque on that side is larger than the torque from T1
Ok so with my original equation where I had Ft1 as a positive direction, the equation I got for a was this:
a=(g(m2-Mew*m1))/(m1+m2-(m3/2))
After changing the direction of Ft1 I get a is equal to
a= (-g(Mew*m1-m2))/((m3/2)-m1-m2)
They both result with a value of 3.97[m/s2] but the second equation results in a negative value.. doesn't that mean that one of my directions is off if the value is negative?
There is something fishy going on, indeed. Give me a minute to double check everything.
Meanwhile, can you check carefully the question and make sure that it is exactly what you wrote in your post? Thanks
Wait...you have to change the sign of both Ft1 and Ft2 in your torque equation, not just one
Using
[tex]R T_2 - R T_1 = \frac{1}{2} m_3 R^2 \frac{a}{R}[/tex]
and using the same T2 and T1 you had, I find
[tex]a = \frac{m_3 g - \mu m_1 g}{m_3/2+m_1 + m_2 }[/tex]
Diagram of a pulley system: Mass 1 rests on a table and is connected by Tension #1 over a solid cylinder pulley with a labelled radius to Mass 2 hanging below with Tension #2. Given values listed at left.
Why do I have to change the sign for Ft2? Its positive in the fbd for m3 and the torque from Ft2 is still out of the board (-)
frozenguy said:
Physics diagram of a block on a table connected by a string over a solid cylinder pulley to a hanging block, with labels Tension #1 and Tension #2, a radius marker, and a list of given masses and questions on the left.
please note that I changed the pulley to m3 and the hanging mass to m2 when I posted; I forget why.
AHHH!
And where do they give the coefficient of friction?
In any case, the formula is
[tex]a = \frac{ m(hanging) g - \mu m(on \,table) g}{m(pulley)/2 + m(on \,table) + m(hanging)}[/tex]
I mean that the correct equation is
Ft2 - Ft1 = I alpha
Ft2 - Ft1 = I alpha
I don't get how Ft2 is positive now though. Isn't it (-k) direction (so negative in torque equation) and positive in the fbd for m3?
This is what I explained in post number 7
The angular acceleration is clockwise. This means that the angular acceleration is alpha(-k)
So we get
T2 (-k) + T1 (k) = I alpha (-k)
therefore
-T2 + T1 = - I alpha
or
T2 - T1 = I alpha
So we get
therefore
or
T2 - T1 = I alpha
Oh..
Sorry, I didn't see post 7 somehow. Ok so that makes sense. I thought alpha could be positive and negative, infact I believed it must be able to be +or- but a peer said no. lol.. so it kind of escaped me..
Thank you so much.. So Ft1 will be = -m1a-Mew*m1g
because Ft1 itself is negative in the fbd for m3..
so with the negative Ft1 in the torque equation, that will distribute out and make those two factors positive (in Ft1 itself)
frozenguy said:
Oh..
well, one has to be very careful about the language used. To be exact, alpha itself is always positive (it's the magnitude of the angular acceleration). But the components of the angular acceleration vector may be negative. Note that when I write alpha (-k), the value of alpha itself is positive.
not quite. T1 is positive. And it is given by T1 = m1 a + mu m1 g, as you had initially written.
Ok I got myself all mixed up... I'm on track now lol
Again, thanks so much..
oh, and the picture for some reason doesn't include the Mew, I apologize, but the written part of the question does.
So I get a=2.93 [m/s2]
alpha=33[rad/s2]
thank you!
