Two-car collision with perpendicular velocities
13 replies · 2K views
aimen khattakk
One car of mass 1400 kg is traveling at 45km/h when it collides and becomes entangles with another car mass of mass 1300 kg traveling at 39km/h[E]. What is their velocity after collision
So MA = 1400 kg
VA = 45kh/h
MB = 1300 kg
VB = 39 kh/h [E]
and After Collision:
MAB = 2700kg2. Homework Equations
P = mv
∑P = ∑P'
PA + PB = PAB'
3. The Attempt at a Solution
so I've always been told to solve momentum first so since car A is going South that means it only has a vertical momentum? so
that means PAY = m⋅v
so PAY = 63000kg⋅km/h
similarly for B
so only a horizontal momentum
so PAX = 50700kg⋅km/h [E]
so now I am stuck on what to do, i tried to find the momentum of Pab in the x and y direction then find pab and solve for v but that doesn't work when i tried it. Pab in the x direction just turns out to be the same as pb in the x direction and pab in y direction turns out to be pa in y direction and then using pythaguras theorum to find the hyp and hence find Pab i get 37396 kg⋅km/h and then solving for V by diving the Pab by the total mass of both of the cars together gives me a velocity of 13.85km/h but the answer is 30.0km/h so i think i messed up after solving my momentums for before the collision but idk what i did wrong
Check your Pythagoras calculation again. Show your working.
This number is not correct.
Edit: NascentOxygen beat me to it.
okay so
PABY' = 63000kg⋅km/h and PABX = 50700 kg⋅km/h [E]
so
c2 = a2 + b2
so
c2 = 630002 + 507002
c2 = √630002 + 507002
so c = 37396.6576 kg⋅km/h so this is PAB '
now i need to find the velocity after collison so i took the combined mass and divided it with 37396.6576kg⋅km/h
and my v ends up being 13.85 km/h but the answer is 30 km SE
i do not understand hot i
it is? i don't understand how because i did
507002 + 630002
and since 63000 is actually in the negative direction i basically did
507002 - 630002
and then square rooted it. do i not assign that negative direction? but its going south?
The negative sign isn't applicable here. You use Pythagoras to calculate magnitude.
507002 + 630002
507002 - 630002
What if A was going North instead? Do you expect a different result? Making a diagram of the situation would help.
my calculator is fine, I've used it for all my courses and I am in 2 other math courses so its not broken, but i took ur advice and tried it with another one and still getting the same answer
oh wait, so since I am looking for the overall momentum of Pab after the collision, i don't need to consider negative and positives? since I am not going in a specific direction, rather I am going in 2 directions not one?
NascentOxygen said that because
so c = 37396.6576
is not correct. But this is not what you calculated, as you stated in a subsequent post.
and I am basically looking for the sum of 2 vectors so it would be that the cars are going S of E not just S or just E so doing what i did earlier would have made the direction be just south right?
You already have the sum of the two vectors. What you are looking for is the magnitude of the resultant vector.
that is the Pab not the velc
OH so since I am looking for the magnitude i don't need to consider their directions so it would just be
c2 = 630002+ 507002
so c = 80867.11 kg⋅km/h ??
so then velocity would be 80867.11 kg⋅km/h / 2700kg
so v = 29.9 km/h! thank you! that makes so much more sense!
You are adding two perpendicular quantities. The hypotenuse will be longer than either of the perpendicular components.
