Two charged spheres are connected
11 replies · 6K views · last reply
1MileCrash
Two identical conducting spheres, fixed in place, attract each other with an electrostatic force of 0.108N when their center-to-center separation is 50 cm. The spheres are then connected by a thin conducting wire. When the wire is removed, the spheres repel each other with an electrostatic force of 0.0360N. Of the initial charges on the spheres, with a positive net charge, what was the negative charge on one of them and the positive on the other before they were connected?
F = kqqr^-2
First I noted that the charges must be equal after being connected. I called this charge q3.
Then (.25)0.036 = k(q3)^2
.009 = k(q3)^2
1x10^-6 = q^3
Since some charge n was removed from q1 and given to q2 for this to happen,
q1 - n = `1x10^-6
q2 + n = 1x10^-6
Suggesting that q1 + q2 = 2x10^-6.
With that in mind, since
0.108(.25) = k(q1)(q2),
(q1)(q2) = 3x10^-12
Substituting results in the quadratic
0 = -(q2)^2 + (2x10^-6)(q2) - (3x10^-12)
which has no real solution.
Thoughts?
Note that one of the charges q1 or q2 is given to be positive while the other is negative. So, this equation is inconsistent (left side positive, right side negative).
[oops, I see Ibix essentially already gave you this hint.]
well the ans are 10^-6, -10^-6 ,3 x 10^-6,-3x 10^-6 is tht rite?
I corrected the sign error and solved the quadratic which has two solutions, 3x10^-6 and -10^-6.
I don't know how to get those other results you got. The problem specifies a positive net charge but i would still like to know.
well after chrge becomes q1-n and q2+n. and force wud become k(q1-n)(q2+n)/r^2. and
q1-n=q2+n u cn get value of n in terms of q1 and q2. n frm first eqn u have value of q1xq2...frm tht u will get four values of charges...even if ques demands positive chrge it will be both +10^6 and 3x10^6.
You got the possible values of charge on the second capacitor: it can be charged with 3x10^-6 C or -10^-6 C. The charge of the first capacitor is either -10^-6 C or 3x10^-6 C, respectively, as the sum of charges is 2x10^-6 C.
The equation for q3 had a positive and a negative solution, but the negative has been excluded.
ehild
Further to ehild's response, either 10-6 or -10-6 solve your first equation. The second is forbidden by the requirement of a net positive charge, but if you run with it anyway you get the other two answers sirisha gave. I believe that you are correct and sirisha has overlooked the positivity requirement.
ya didnt see the positive charge ...bt if only positive charges are to be included it will be both...
The question only requires a net positive charge. There could not be an attractive force initially if the charges were not opposite signs.
i did ths que a fewdaysbk n in my que net positive chrge wasnt specified so all the four ans came..
