Two charges accelerated first by ##\Delta{V}##, then by ##\vec{B}##
  • Thread starter Thread starter mcastillo356
    Charges
The discussion centers on the relationship between the radii of circular paths of two charged particles accelerated by the same electric potential difference, ##\Delta{V}##, and subjected to a magnetic field ##\vec{B}##. The derived formula indicates that the ratio of the radii, ##R_1/R_2##, is equal to the square root of the mass ratio, expressed as ##R_1/R_2=[m_1/m_2]^{1/2}##. Participants debated the influence of velocity and charge on the radius, ultimately confirming that the correct answer is option a).
  • Understanding of classical mechanics, specifically motion of charged particles in magnetic fields.
  • Familiarity with the concepts of electric potential difference and magnetic fields.
  • Knowledge of the equations governing circular motion of charged particles, particularly ##R=\dfrac{mE}{|q|B}##.
  • Basic algebra skills to manipulate equations and ratios.
  • Study the derivation of the radius of circular motion for charged particles in magnetic fields.
  • Learn about the Lorentz force and its application to charged particles in electric and magnetic fields.
  • Explore the implications of mass and charge on the motion of particles in electromagnetic fields.
  • Investigate the effects of varying electric potential differences on particle trajectories.
Physics students, educators, and professionals in fields related to electromagnetism and particle physics will benefit from this discussion, particularly those focusing on the dynamics of charged particles in magnetic fields.
mcastillo356
Two particles of the same charge and masses ##m_1## and ##m_2## are accelerated by the same difference of electric potential ##\Delta{V}##. Then they enter at a place where there is a magnetic field ##\vec{B}## perpendicular to their movement direction. What relation is between the radius of the circular path drawn by both particles?
a)##R_1/R_2=[m_1/m_2]^{1/2}##
b)##R_1/R_2=m_1\Delta{V}/m_2 B##
c)##R_1/R_2=m_1/m_2##
d##R_1/R_2=m_2/m_1##
##R=\dfrac{m E}{|q|B}##
$$R_1=\dfrac{m_1 E}{|q|B}$$
$$R_2=\dfrac{m_2 E}{|q|B}$$
$$\therefore{\dfrac{R_1}{R_2}=\dfrac{m_1}{m_2}}$$
In my opinion, the answer to a this multiple choice question is c)
mcastillo356 said:
Homework Statement:: Two particles of the same charge and masses ##m_1## and ##m_2## are accelerated by the same difference of electric potential ##\Delta{V}##. Then they enter at a place where there is a magnetic field ##\vec{B}## perpendicular to their movement direction. What relation is between the radius of the circular path drawn by both particles?
Relevant Equations:: ##R=\dfrac{m E}{|q|B}##
Are you sure about the dependence on ##E##?
No, not at all. What about ##r=\dfrac{mv}{qB}=\dfrac{\sqrt{2qVm}}{qB}=\dfrac{1}{B}\times{\left(\sqrt{\dfrac{2Vm}{q}}\right)}##? Could be a way?
That looks better!
Well, I infer that the answer is the same, because ##v##, ##q## and ##B## are the same for both particles: ##\dfrac{R_1}{R_2}=\dfrac{m_1}{m_2}##
  • Skeptical
What happened to the square root?
No, ##v## is not the same. I must deal with ##r=\dfrac{1}{B}\times{\left(\sqrt{\dfrac{2Vm}{q}}\right)}##
I don't understand. This looks right. ##B, V## and ##q## are constant. That gives you ##r \propto \sqrt m##, no?
hmm.. That's wright. Is it a contradition to state ##r\propto\sqrt m## and ##r\propto m##?
It can only be one or the other.
So I must say rather this one: ##\dfrac{R_1}{R_2}=\dfrac{\sqrt{m_1}}{\sqrt{m_2}}##. This is ##R_1/R_2=[m_1/m_2]^{1/2}##: the a) choice
:smile:
  • · Replies 23 ·
