Two charges accelerated first by ##\Delta{V}##, then by ##\vec{B}##
  • Thread starter mcastillo356
    Charges
11 replies · 1K views · last reply
mcastillo356
Two particles of the same charge and masses ##m_1## and ##m_2## are accelerated by the same difference of electric potential ##\Delta{V}##. Then they enter at a place where there is a magnetic field ##\vec{B}## perpendicular to their movement direction. What relation is between the radius of the circular path drawn by both particles?
a)##R_1/R_2=[m_1/m_2]^{1/2}##
b)##R_1/R_2=m_1\Delta{V}/m_2 B##
c)##R_1/R_2=m_1/m_2##
d##R_1/R_2=m_2/m_1##
##R=\dfrac{m E}{|q|B}##
$$R_1=\dfrac{m_1 E}{|q|B}$$
$$R_2=\dfrac{m_2 E}{|q|B}$$
$$\therefore{\dfrac{R_1}{R_2}=\dfrac{m_1}{m_2}}$$
In my opinion, the answer to a this multiple choice question is c)
mcastillo356 said:
Homework Statement:: Two particles of the same charge and masses ##m_1## and ##m_2## are accelerated by the same difference of electric potential ##\Delta{V}##. Then they enter at a place where there is a magnetic field ##\vec{B}## perpendicular to their movement direction. What relation is between the radius of the circular path drawn by both particles?
Relevant Equations:: ##R=\dfrac{m E}{|q|B}##
Are you sure about the dependence on ##E##?
No, not at all. What about ##r=\dfrac{mv}{qB}=\dfrac{\sqrt{2qVm}}{qB}=\dfrac{1}{B}\times{\left(\sqrt{\dfrac{2Vm}{q}}\right)}##? Could be a way?
That looks better!
Well, I infer that the answer is the same, because ##v##, ##q## and ##B## are the same for both particles: ##\dfrac{R_1}{R_2}=\dfrac{m_1}{m_2}##
  • Skeptical
What happened to the square root?
No, ##v## is not the same. I must deal with ##r=\dfrac{1}{B}\times{\left(\sqrt{\dfrac{2Vm}{q}}\right)}##
I don't understand. This looks right. ##B, V## and ##q## are constant. That gives you ##r \propto \sqrt m##, no?
hmm.. That's wright. Is it a contradition to state ##r\propto\sqrt m## and ##r\propto m##?
It can only be one or the other.
So I must say rather this one: ##\dfrac{R_1}{R_2}=\dfrac{\sqrt{m_1}}{\sqrt{m_2}}##. This is ##R_1/R_2=[m_1/m_2]^{1/2}##: the a) choice
