Two-dimensional motion practice
  • Thread starter Thread starter gary_shuford
    Motion
1 reply · 4K views
gary_shuford
ok i have a test thursday i need help
1.prove an object thrown upwards with a velocity of 20.0 m/s has the same velocity going up past 5.0 meters as it does falling down past 5.0 meters?
[Vf^2=Vi^2 + 2 (-9.81) delta X] ?
2.A car is driving down a road on a snowy day. The car is traveling at a constant 14.0 m/s and is currently 250.0 metersfrom a tree standing by the side of the road. An incicle 4.0m up from the groun on the tree falls onto the car as it passes. how much time elapsed between the time the car was 250.0 m away from the tree and the moment the icicle landed on the car?
i don't know this one at all i tried
3. A tennis ball rolls off the edge of a cruise ship and lands 35.0 m away from the edge of the ship when it hits the watr. If the ships deck is 31.3 meters above the water what was the balls horizontal velocity?
i used delta y = 1/2 g (deltaT)^2
4. A bullet is fired from a gun help parallel to the gorun. The bullets horizontal velocity is 210.0 m/s If the gun is 1.80 meters above the gound, how far will the bullet travel horizontally before hitting the ground.
5.An athlete in the Olympics throws ashot put. The shot put is in the air for 1.89 seconds and lands 6.7 meters away horizontally. Calculate the intial vertical and horizontal components of the shot puts angular velocity. (horizontal velocity = Vi (cos 0), initialy veritcal = Vi(sin 0)
6. A golf ball lands 123.0 m horizontally away from its position after being stuck. If the ball has an angular velocity of 40.0 m./s and is in the air a total of 6.0 seconds calculate the angle at which the ball was launched
can anyone please just give me the formulas to use then i will try to solve them and then yall can help me from there please and thank you gary shuford
https://www.physicsforums.com/showthread.php?t=110015
There is more to doing these problems than guessing what formula to use. You need to understand what is going on in the problem. Drawing a diagram helps. You may need to use more than one formula. See what you can do. To figure out what you need, list what you know and what you don't.
