How Do You Calculate Potential Energy in a 2D Oscillator System with Springs?
  • Thread starter Thread starter forestmine
    Oscillators
The discussion focuses on calculating the potential energy of a puck attached to four springs in a 2D oscillator system. The key equations involve the total force F = -kr and the potential energy U = 1/2 * k * r^2, where r^2 = x^2 + y^2. The user initially struggles with the relationship between force and potential energy and realizes the importance of incorporating the unstretched length of the springs (l_0) into their calculations. The discussion highlights the necessity of understanding the gradient of the potential energy to derive the correct expressions for potential energy in terms of the spring displacements.
  • Understanding of classical mechanics, specifically Hooke's Law
  • Familiarity with potential energy concepts in oscillatory systems
  • Knowledge of vector calculus, particularly gradients
  • Basic proficiency in algebraic manipulation of equations
  • Study the derivation of potential energy in multi-spring systems
  • Learn about Taylor series expansions in the context of potential energy
  • Explore the concept of equilibrium positions in oscillatory systems
  • Investigate the relationship between force and potential energy in conservative systems
Students and educators in physics, particularly those studying mechanics and oscillatory motion, as well as anyone involved in engineering applications related to spring systems and potential energy calculations.
forestmine
A puck with mass m sits on a horizontal, frictionless table attached to four identical springs (constant k and unstreched length l_0). The initial lengths of the spring a are not equal to the unstretched lengths. Find the potential for small displacements x,y and show that it has the form 1/2 * k' * r^{2} with r^{2} = x^{2}+ y^{2}.
I'm honestly at a loss with this problem. I know that the total force is F=-kr, where F_{}x = -kx and F_{}y = -ky.
I also know that my potential is minus the gradient of the force. If I were to take the gradient of F, where F = -kx(i) -ky(j), I get F= -k(i) -k(j). Not really sure where to go from here, or if I'm on the right track for that matter.
I'm obviously not looking for the answer, just some help in the right direction. I don't think I fully understand it conceptually to be able to work it analytically. Any tips would be greatly appreciated!
EDIT// Here's some work I've done since posting. Still unsure of how to continue.
To account for all possible positions of the spring,
r1^2=x^2 + (a-y)^2
r2^2=x^2 + (a+y)^2
r3^2=(x+a)^2 + y^2
r4^2=(x-a)^2 + y^2
Now, r will be some variation of the above, so I summed the above 4 equations. I would then think to use U=1/2 * k * r^2, where r^2 is the sum of the above equations. I feel like I'm missing something, though.
EDIT 2// In fact, I definitely don't feel as though that's suitable, because it says that the potential is not at all dependent on l, which of course is false.
You've got things backwards: the force is the gradient of the potential, ##\mathbf{F} = - \nabla U##. Also, the forces should involve the quantity ##a-l_0##.
Whoops, that was a bad mistake. Thanks for catching that.
Though I'm still not really sure what to do. My potential can then be written in terms of x and y components, right?
For instance,
U_x = 1/2 * k * rx^2, but I don't really see what r ought to be. I understand that there should be some dependence on l_0, but I honestly have no idea how. Unless we can essentially rewrite the equations for r_n, with (a-l_0)^2, (a+l_0)^2, etc.
Sorry, I'm so lost on this problem. I know that there are two methods, one of which involves a taylor expansion, and the other, a second derivative of the potential function, but again, I don't even know what my potential function looks like in this case.
Set up the coordinate system so that the mass is sitting at the origin when it's in equilibrium and the springs lie along the axes. The end of the springs lying on the +x axis will be at the point (a,0). What's the potential energy in the spring when the mass is at (0,0)? What's the potential energy in the spring when the mass is at the point (x,y)?
