Calculating Maximum Height of a Hanging Block on a Pulley System
  • Thread starter Thread starter jphillip
    Blocks Pully
The discussion focuses on calculating the maximum height reached by a 2.2 kg block in a pulley system with a 3.2 kg block. The initial acceleration of the system is determined using the formula (3.2 kg - 2.2 kg) / (3.2 kg + 2.2 kg) = 0.185g, resulting in an acceleration of 1.81 m/s². The final velocity is calculated using conservation of energy principles, leading to a maximum height of 3.93 m for the lighter block after the heavier block hits the ground. The participants emphasize the importance of deriving formulas independently and understanding the underlying physics concepts.
  • Understanding of Newton's laws of motion (F = ma)
  • Basic knowledge of kinematics and equations of motion
  • Familiarity with conservation of energy principles
  • Ability to perform calculations involving gravitational acceleration (9.8 m/s²)
  • Study the derivation of kinematic equations for motion under gravity
  • Learn about conservation of mechanical energy in physics
  • Explore pulley systems and their dynamics in introductory physics
  • Practice solving problems involving multiple masses and acceleration
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to enhance their understanding of pulley systems and energy conservation principles.
jphillip
two blocks (2.2kg and 3.2kg) both hanging 1.80 m from the ground on a pulley(massless / frictionless) that is 4.80 m from the ground.
What is the maximum height the smaller block (2.2kg) reaches, when the system is released?
It appears that I need to find its velocity first of the system as the 3.2kg falls 1.8 m to the ground.
(3.2kg-2.2kg) / (3.2kg+2.2kg) = .185g * (9.8m/s2) = 1.81 m/s2
Then once the big block hits the ground, calc the additional height of the little block will rise additionally from the velocity created.
v2 - v2i / 2 (g)
1.812 / 2(9.8 m/s2) = .168 m + 1.8m (initial drop / increase)
Is this correct?
welcome to pf!
hi jphillip! welcome to pf! :smile:
where did you get this formula from? :confused:
(it's only partly correct :redface:)
(your second formula is fine)
I got the first formula from an example in my book that appeared to be calculating what I thought I needed. An elevator question, what did I miss or am I missing
thought so! :rolleyes:
always work out the formula yourself :wink:
what should it be? :smile:
I believe F = ma which worked out a = F/m
So
3.2kg - 2.2kg = 1kg * 9.8 = F
(3.2 + 2.2) = m ? (not sure here)
I think
jphillip said:
I believe F = ma …
well, that certainly would work, but you want v not a …
so it's quicker to use conservation of energy :wink:
O.K.
V2 = 2(1.81m/s2)(1.80m)
jphillip said:
O.K.
yes! :biggrin:
So that gets me the velocity2 I would then have to solve for the additional distance correct
yes :smile:
(same method as you used at the start)
\sqrt{2*1.81*1.80} = v = 2.55
2.552 / (2*9.8m/s2) = y = .332 + 3.6 (1.80(starting height)+1.80 accl height)
total height 3.93m
i'm finding it difficult to follow this without any formulas :redface:
(and why did you bother to square-root that, when you were only going to square it again immediately after? :confused:)
Here are the formulas that I have used... initial height = 1.80m
N - Newtons
kg - kilograms
(Block 1 31.31N - Block 2 21.56N) / (block 1 3.3kg + block 2 2.2kg) = a
So
(31.36N - 21.56N) / (3.2kg + 2.2kg) = 1.8148 m/s2
Then solve for Velocity using v2 = v2i + 2a(y)
V2= 0 + 2(1.8148m/s2)(1.80) = 6.5338 which is velocity not squared
Now solve for the actual distance using the same formula on
v = 6.5338 (not squared from above)
a = 9.8 gravity
v / 2(a) = y
6.5338 / 2(9.8) = .332 which should be the height of the lighter block 2.2kg with momentum after the 3.2 kg block hits the ground.
hi jphillip! :smile:
(just got up :zzz: …)
i think you have the correct result, but what do you mean by "not squared"? :confused:
that 6.53338 is v2
have you done conservation of energy in class (KE + PE = constant)?
you can avoid finding the acceleration by using mgh - Mgh = (m + M)v2/2
I have not made it to conservation of energy in Class. Thanks for the help I am sure I will be back for more. I am really enjoying this class, just not the summer version of I believe LOL.
ok, that's something to look forward to! :biggrin:
just to recap, your equations (without conservation of energy) should have been
(F = ma): mg - T = ma, Mg - T = -Ma, so (subtracting) (m-M)g = (m+M)a, or a = (m-M)/(m+M)
v2 = 2as1
v2 = 2gs2 :wink:
  • · Replies 22 ·
