Two men, a crate, and a set of stairs
  • Thread starter Thread starter TFM
    Set
The discussion revolves around calculating the forces exerted by two men carrying a 200kg crate up a 45-degree staircase. Participants initially struggle with the torque equations and the correct application of angles and distances. Key points include the need to consider the center of mass of the crate and the proper use of sine and cosine functions to determine torque. After clarifications and corrections, the correct forces are identified as F1 = 590N and F2 = 1370N. The conversation emphasizes the importance of accurately setting up equations and understanding the physical principles involved.
TFM
[SOLVED] Two men, a crate, and a set of stairs
Two men are carrying acrate up some stairs, at an angle of 45 degrees. the crate weighs 200kg, and the box is 1.25m long by 0.5m high. The force each person applies is verticle. I need to work out the force on each person, but I am not sure where to start. Any ideas?
The forces applied to the box have to sum to g*(200kg) and they also have to create zero net torque around the center of mass of the box. Otherwise the box won't stay at a constant angle. That will give you two equations in two unknowns. That's where to start.
I think I must have my torque equation wrong:
I have
F1+F2=1960 (<-200g)
My Torque calucluations:
F1D = F2D
F1*cos(246.8)*1.346 = F2*cos(68.2)*1.346
which I rearrange to get:
-772.126F1 = 727.881F2
F1=1960-F2
-772.126(1960-F2) = 727.881F2
-1513367+772.126F6 = 727.881F2
-1513367 = -44.2F2
F2=34201
Which is definitely wrong!
The Actual Answers are F1 = 590, F2 = 1370
Any ideas?
I have
F1+F2=1960 (<-200g)
OK.
F1D = F2D
Not sure what you're doing here. What pivot point are you using to calculate torque? Where did you get a distance of 1.346? (That's the diagonal across the side of the crate.)
Hint: Where's the center of mass of the crate?
I was taking the torques from the centre of mass, which I asumed was at the centre of the rectangle, since there was no mention of it being non-uniform
TFM
OK. So explain how you got your angles and distances in your torque equation. (A diagram showing the forces would be helpful.)
The Length of the diagonal was calculated using Pythgoras (x^2+y^2 = Z^2) although the length from the pivot to the force is actually half that length (error)
The angles were calculated using the dimensions of the box to find the inner angle
F1(1960*cos23.3)*0.67 = F2(1960*cos246.8)*0.67
-519F1 = 1212.675F2
F1 = 1960-F2
-519(1960-F2)=1212.675F2
-1018717 +519F2 = 1212.675F2
Which works out as F2 = -1470, which is near the value required but 1=hundred out, excluding the fact that it is a negative.
TFM
OK.
Why is there a 1960 in there? Why are you using cosines? Since you are setting clockwise torques = counterclockwise torque, you can forget about the signs--just worry about magnitudes.
the 1960 and cosine are in thereto determine the torque, since:
Torque = Force * Perp. Distance, the forces and distnbace a=ren't perpendicular, so I used 1960*cos(angle), to calculate the perpendicular force for each Torque.
TFM
Since the forces are all vertical, the perpendicular distance would be horizontal. You'd need the horizontal component of the distance and thus the angle it makes with the horizontal to use cosine. (Since you have the angle with the vertical, you can use sine.)
Also: 1960 is the total force; it shouldn't appear in the torque equation.
I now have:
F1*(sin246.8)0.63 = F2*(sin23.2)0.63
for the Torque equation, which rearrnges to:
-0.61871F1 =0.26518F2
F1 = (1960 - F2)
-0.61871(1960 - F2) = 0.26518F2
-1212.68 + 0.61871F2 = 0.26518F2
-1212.68 = -0.35353F2,
Which gives F2 to be 3430!?
TFM
TFM said:
I now have:
Since all you care about are the magnitudes (you already know which is clockwise, etc.), use angles between 0 and 180. Or just ignore the signs of your sines.
Lose the negative sign. (Realize that a negative sign makes no sense!)
F2 = 1212.675/0.883892 = 1371!:smile:
F1 = 1960 - F2
Thanks Doc Al, great job
:smile: :smile: :smile:
TFM
23K
12K
9K
