Two questions regarding integrating items
  • Thread starter TFM
    Integrating
24 replies · 3K views · last reply
TFM
I have a couple of questions about some intriguing looking equations.
Firstly, I have to integrate:
[tex]\frac{sin\theta}{cos\theta} d\theta[/tex]
Is there an answer to just dividing them? because sin/cos = tan, but that doesn't seem to help?
Secondly, I have to integrate:
[tex]6e^{-x^2}[/tex]
This One > [tex]6e^{-x^2}[/tex] Should be displaying e to the minus x sqaured
but I didn't think you could integrate a [tex]e^{x^2}[/tex]
Again, this one V
[tex]e^{x^2}[/tex] ?
[tex]\frac{sin\theta}{cos\theta} = tan\theta[/tex]
Given above
Any help would be most appreciated,
TFM
[tex]\int \frac{sin\theta}{cos\theta}d\theta[/tex]
if you let [itex]u=cos\theta[/itex], what is [itex]\frac{du}{d\theta}[/itex]?
For the 2nd one, I don't think you can express that in terms of elementary functions.
[itex]\frac{du}{d\theta} = -sin\theta[/itex]
Is there any way to integrate this, or should I leav it as it is (The question is solving differential equations)
TFM
and so [itex]-du=sin\theta d\theta[/itex].
Now just sub this into the integral and you can get it out.
I have to admit making a small mistake...
The equation to solve is:
[tex]\frac{cos\theta}{tan\theta}[/tex]
TFM
then you need to put tan as sin/cos and get
[tex]\frac{cos^2 \theta}{sin\theta}[/tex]
which in this case put u=sin
So:
[tex]u = sin\theta[/tex]
[tex]\frac{du}{d\theta} = cos\theta[/tex]
[tex]du = cos\theta d\theta[/tex]
so sub-ing in:
[tex]\frac{cos^2 \theta}{sin\theta}d\theta[/tex]
[tex]\frac{du^2 \theta}{u}d\theta[/tex]
Does this look right?
Edit: No it doesn't. Should be
[tex]\frac{du^2 }{u}[/tex]
Does this Look right?
TFM
I think what rock.freak667 wanted you to get was
[tex]\frac{du}{u} \cdot \cos x = \frac{ \sqrt{1-u^2}}{u} du[/tex],
which would warrant an integration by parts.
An alternative method would be to write [tex]\cos^2 x = 1-\sin^2 x[/tex] and divide through.
Could I not use double angle formula:
[tex]cos^2(\theta) = \frac{1-cos(2\theta)}{2}[/tex]
Giving
[tex]\frac{1 - cos(2\theta)}{2sin(\theta)}[/tex]
and then let [tex]u = cos\theta[/tex] again
TFM
How would that help you? What are you going to do with the [itex]cos(2\theta)[/itex] if [itex]u= cos(\theta)[/itex]?
That's true, I just saw the cos squared and remebered that sometime that relation is used to break it down. So:
This gives me
[tex]\frac{cos\theta cos\theta}{sin\theta}d\theta[/tex]
[tex]\frac{cos\theta }{u}du[/tex]
[tex]cos\theta = \sqrt{1 - sin^2\theta}[/tex]
[tex]cos\theta = \sqrt{1 - u^2}[/tex]
so:
[tex]\frac{\sqrt{1 - u^2}}{u}du[/tex]
So integrating by parts:
[tex]\int adb = ab - \int bda[/tex]
[tex]db = u^{-1} ; u^{-2}[/tex]
[tex]a = \sqrt{1 - u^2} ; da =[/tex]
Does this look okay?
TFM
Well if you meant
[tex]db = u^{-1}, b = \log_e u[/tex]
Then that looks fine so far in terms of correctness, though it looks like it won't be fruitful. Perhaps rock.freak667 meant something different to what i Interpreted.
Why didn't you like my suggestion though lol?
Gib Z said:
Well if you meant
Then that looks fine so far in terms of correctness, though it looks like it won't be fruitful. Perhaps rock.freak667 meant something different to what I Interpreted.
I was actually going to do
[tex]b = u^{-1}, db = u^{-2}[/tex]
or is this going the wrong way?
Was your suggestion
An alternative method would be to write [tex]cos^2 x = 1-sin^2 x[/tex] and divide through.
If so, should that not be
[tex]cos^2(\theta) = \frac{1-cos(2\theta)}{2}[/tex] ?
I'm wondering if i have made some mistakes in actually solving the Differential Equations, since out of four DEs I have three which seem to not be able to be completed?
TFM
If I may just check my calculations.
First Question:
[tex]x(t): x' = xt + 6te^{-t^{2}}[/tex]
Subtract -xt from both sides:
[tex]-xt \frac{dx}{dt} = 6te^{-t^{2}}[/tex]
[tex]-x \frac{dx}{dt} = 6te^{-t^{2}}/t[/tex]
[tex]-x dx = 6e^{-t^{2}} dt[/tex]
Does this one look okay?
TFM
[tex]\frac{dx}{dt}=xt+6te^{-t^2}[/tex]
[tex]\frac{dx}{dt}-xt=6te^{-t^2}[/tex]
Do you know how to solve first order differential equations of the form (in your case)
[tex]\frac{dx}{dt}+P(t)x=Q(t)[/tex]?
That would be:
[tex]= e^Fx \int^F q(t)dt + C[/tex]
[tex]F = \int p(t)dt[/tex]
TFM
Sorry, Latex annoys me sometimes when editing:
TFM
Lets see. So:
solution:
And:
[tex]q(t) = 6te^{-t^2}[/tex]
[tex]p(t) = -t[/tex]
so:
[tex]F = \int -t dt = \frac{-t^2}{2}[/tex]
[tex]= e^{\frac{-t^2}{2}}x \int^{\frac{-t^2}{2}}(6te^{-t^2}) dt + C[/tex]
We still seem to have to integrate the [tex]e^{-x^2}[/tex]? Which I thought ewas impossible?
TFM
your integrating factor of exp(-t2/2) is correct.
But your integrand should be
[tex]e^\frac{t^2}{2} 6te^{t^2}[/tex]
Which can be simplified. Then you can integrating using a u substitution.
with
can you add the e values to get:
[tex]6te^{\fract{t^2}{2}+t^2}[/tex]
TFM
So we have:
[tex]e^{\frac{\t^2}{2}}\int 6te^{\frac{-3t^2}{2}}[/tex]
So we have to integrate
[tex]\int 6te^{\frac{-3t^2}{2}}[/tex]
You suggest using a u substitution
Should that be:
[tex]u = \frac{-3t^2}{2}[/tex]
TFM
So:
[tex]U = e^{-\frac{3t^2}{2}}[/tex]
Would du/dt be:
[tex]\frac{du}{dt} = \frac{3}{2}^{-\frac{3t^2}{2}}[/tex]
and thus:
[tex]du = \frac{3}{2}^{-\frac{3t^2}{2}} dt[/tex]
TFM
