Electric Field for Equilibrium of Two Spheres with Charges in a Uniform Field
The discussion focuses on calculating the electric field required for two charged spheres to achieve equilibrium in a uniform electric field. The spheres, with charges of -5.00 x 10^-8 C and +5.00 x 10^-8 C, are suspended 10.0 cm apart at an angle of 10.0° from the vertical. The correct approach involves applying the equations Tcosθ = mg and Tsinθ = kq²/r² + Eq, leading to the determination of the electric field E as 6.47 x 10^3 N/C. However, the initial calculations were incorrect due to misapplication of the forces involved.
  • Understanding of electrostatics, specifically Coulomb's Law.
  • Knowledge of vector components in force analysis.
  • Familiarity with the concept of equilibrium in physics.
  • Ability to manipulate trigonometric functions in physics equations.
  • Study the derivation of Coulomb's Law and its applications in electric fields.
  • Learn about vector decomposition in force analysis for equilibrium problems.
  • Explore the concept of tension in strings and its role in equilibrium scenarios.
  • Investigate the effects of varying angles on the forces acting on charged particles.
Students in physics, particularly those studying electrostatics and equilibrium systems, as well as educators looking for practical examples of electric fields in action.
Bradwast88
Two small spheres, each of mass 2.00 g, are suspended by
light strings 10.0 cm in length. A uniform
electric field is applied in the x direction. The spheres
have charges equal to -5.00 x 10^-8 C and +5.00 x
10^-8 C. Determine the electric field that enables the
spheres to be in equilibrium at an angle theta= 10.0° to the vertical.
F=Eq,F=KqQ/r^2
For the equilibrium of whole system, I have applied the forces along the x-axis.
So then attraction force between two charges=The sum of forces on (-) and (+) charges by the field.And I have noticed that tensions are canceling each other.
(8.99x10^9)(5x10x10^-6)^2/(2x0.1sin10)=2E(5x10^-6)
and I have got E=6.47 x 10^3 N/c for the answer but unfortunately answer was incorrect.
Was there any thing wrong with my equations?
Thanks.
i Dont get ur questions properly. What is the distance between the two spheres? is the angle 10degrees from vertical?
Oh sorry about that yes that is 10 degrees from vertical.
Eq=kq^2/(20sin10)^2+Tsin10...1
mg=Tcos10...2
Solving these two equations u should be able to get the answer.
Ok thanks for it.
But could you please tell me know is there any thing wrong with this statement.
can u give me a diagram of the arrangement because in I assumed electric field to be in the left directrion and positive charge in the left and the negative charge in the right. Is that right?
Negative charge is in the left and positive is in the right.And electric field is in the positive x direction.
Unfortunately I can't provide the diagram.Sorry.
In the equilibrium position, net force acting on the spheres is the sum of electrostatic force and force due to the electric field. In this position the separation between the sphere is given by r = 2Lsinθ.
Ιf T is the tension in the string, then
Tcosθ = mg and
Tsinθ = kq^2/r^2 + Eq.
Now solve for E.
  • · Replies 32 ·
