Two Vectors of Equal Magnitudes
21 replies · 21K views · last reply
danielatha4
Two vectors A and B have precisely equal magnitudes. For the magnitude of A + B to be 25 times greater than the magnitude of A - B, what must be the angle between A and B?
Hint Given:
Without loss of generality, you could assume that A and B are unit vectors. Also, the orientation of the vectors is irrelevant, so you're free to assume for example that one vector lies along the x axis, or that they're symmetrically located about an axis.
How would you draw triangles to represent the two vector combinations, and how are the angles in these two triangles related?
I really don't where to start with this one. I set up an isosceles triangle with the two legs as the vectors, but I can't find any angles. I also don't know how to apply the fact that A+B is 25 times A-B.
Hint Given:
Why don't you just use the law of cosines?
I don't have three sides.
The third side is supposed to be the resultant(A-B & A+B).
I don't know what you call it but
Resultant= sqrt(A^2 +B^2 + 2ABcosine(theta) )
Use first the + sign for A+B and - for A-B.
Hi danielatha4! :smile:
Draw two triangles together, one with sides A and B, the other with A and -B.
In other words, a triangle PQR where the midpoint of QR is O, OP = A, OQ = B, OR = -B. :wink:
Okay tinytim, I took your suggestion and drew two triangles with the sharing side of A. The base of the right triangle is B and the base of the left triangle is -B. The right side of the big triangle is A+B and the left side of the big triangle is A-B.
I need the angle across from A+B, as that is the angle between vectors A and B. And since it is an isosceles triangle I would think
[tex]\alpha[/tex]= arccos( 1 - [tex]\frac{(A+B)^2}{2A^2}[/tex])
However this reduces to arccos(-1) = 180
I do know that the other angle (between A and -B) is 180-[tex]\alpha[/tex]
And I'm stuck again with applying that A+B and A-B have a relation.
(Sorry, I haven't quite followed what you've done. :redface:)
Hint: Since A = B, the triangle is in a circle, and the double-B side is a diameter.
So … ? :smile:
I'm sorry, I still can't figure anything out. I've applied the law of cosines to just about every angle and I can't come up with any answers that are of use to me.
Here's a picture of what I drew
Edit: Where x=(A+B)
x/25=(A+B)/25=(A-B)
  • Handwritten sketch of a triangle with a cevian from the apex to the base, labelled A on the cevian, x on the left and right sides, 25 on the left side, B on the two base segments, 2A = 2B along the base, angles alpha and beta marked, and 180 minus theta at the base.
It's a triangle in a circle, and the base is a diameter of the circle, so the angle opposite the base is … ? :smile:
Use the hint.
If you assume that
A=(1,0) and
B=(x,y)
Then |A|=|B| implies that
(x^2)+(y^2)=1
Then, by using both facts as well as the fact that
|A+B|=25|A-B|
You can easily solve for x and y and finding the angle is easy. No diagrams are needed. You guys are making it way to hard.
I don't understand your approach Pinu7
So the angle across the base should be 90 degrees right?
I then solved for beta in my diagram and found it to be arctan(25)=87.8 therefore alpha must be 2.2. Therefore on the right triangle, theta = 180 - 2(2.2) = 175.6
This isn't right.
Yup! :smile:
This isn't right.
(i make arctan(25)=87.7)
How about the supplementary angle, theta = 2(2.2) or 2(2.3) ?
If Beta is 87.7, then that means alpha is 2.3, right?
Theta is 180 - 2(2.3) = 175. This isn't right either.
How do you assume theta is 2(2.3)?
I agree with Pinu7, using the law of cosines twice (once for [itex]|\mathbf{A}+\mathbf{B}|[/itex] and the other for [itex]|\mathbf{A}-\mathbf{B}|[/itex] ) makes this a lot easier since we know that [itex]|\mathbf{A}|=\mathbf{B}|[/itex]:
[tex] \cos[\gamma]=1-\frac{c^2}{2a^2}[/tex]
where [itex]c[/itex] is the normal hypotenuse and [itex]\gamma[/itex] the angle between [itex]a[/itex] and [itex]b[/itex].
We can ASSUME that
A=(1,0) in a particular coordinate system.
So if
B=(x,y)
we must have x^2+y^2=1 (since the magnitude of B is 1)
|A+B|=25|A-B| or
|(x+1,y)|=25|(x-1,y)|
x and y can be solved by simple algebra(remember that x^2+y^2=1 so we have 2 equations and 2 variables)
And then, arctan(y/x) would be the angle.
Pinu7 said:
We can ASSUME that
So if
B=(x,y)
|A+B|=25|A-B| or
shouldn't it be arctan(y/25x)?
No, since A=(1,0) lies on the horizontal axis, then the angle between A and B is the angle B makes with the horizontal so
tan(angle)=vertical side/horizontal side=y/x
(the horizontal component of B is x, not 25x, I do not know where that came from)
Touche...not sure why, but I was erroneously thinking that you'd need to take into account the 25 from the ratio of a-b and a+b. Plus the fact that the denominator should contain the 25 made me think it'd need to be there also.
I am usually wrong before I get it right. Though, I think in this case using the two laws of cosines for isosceles triangles would be easier than your method.
(just got up :zzz: …)
The angle between A and B can be either the angle on the left or the angle on the right.
(They add up to 180º, of course.)
A question that asks "what must be the angle between …" usually means the "principal" value, ie the value < 180º. :wink:
As long as you get the right answer!
interesting solution.
note that you should guess right off the bat that it will be a small angle. if the unit vectors point in nearly the same direction, then they should subtract to something very small and add to something much bigger, e.g. the ratio A+B / A-B = 25.
All you really need here is law of cosines; draw A pointing in the pos. x direction, B at some angle above. Find (A+B)^2, (A-B)^2, then think of how to use your ratio 25.
