Two waves of light in air travel through a layer
The discussion revolves around the phase difference between two waves of light traveling through different layers of plastic after initially being in phase. The problem involves concepts from optics, specifically relating to wavelength, phase, and refractive indices.
  • Participants explore the calculation of phase difference in terms of wavelengths and question the interpretation of the results. There is a focus on distinguishing between phase difference as an angle and the number of wavelengths.
Some participants have provided clarifications regarding the terminology used in the problem, particularly about phase difference and its representation. There is an ongoing exploration of the correct interpretation of the results, with no explicit consensus reached on the final answer.
Participants note potential confusion regarding the units of the answers provided and the appropriateness of the answer sheet's presentation. There is also a mention of imposed homework rules that may affect the interpretation of the results.
Any Help
Two waves of light in air, of wavelength 550 nm, are initially in phase. They then both travel through a layer of plastic as shown in the figure, with L1 = 4.00 μm, n1 = 1.40, L2 = 3.50 μm , and n2 = 1.60. What is their phase difference after they both have emerged from the layers, when they arrive at the same point?
N is the numbers of lemdas
N1=L1*n1/λ
N2=L2*n2/λ
N in air = (L1-L2)/λ n(air)=1
N2+Nair-N2=0.909 but the correct answer is 5.71?
"Phase difference" is an angle (in radians), not the number of λ's.
What is the name of the difference in wavelengths?
You could also call the difference in wavelengths the "phase difference". So, the answer of .909 wavelengths is a correct answer. However, does the answer of 5.71 include any units?
TSny said:
You could also call the difference in wavelengths the "phase difference". However, does the answer of 5.71 include any units?
no only number
Any Help said:
no only number
"Bad form" on the part of the answer sheet.
10K
10K
