Tympani in a concert hall: calculating Sound Pressure Level (SPL) and delay
The discussion revolves around calculating sound pressure levels (SPL) and delays related to sound reflections in a concert hall setting. The original poster presents a scenario involving a tympani, direct sound measurements, and reflections from sidewalls, raising questions about the interpretation of given data and the calculations involved.
  • Participants explore the relationship between sound pressure and distance, questioning how reflections affect SPL. They discuss the calculations for distance traveled by sound and the implications of timing for direct and reflected sounds.
There is ongoing exploration of the assumptions in the problem statement, particularly regarding the timing of sound reflections. Some participants suggest that the phrasing of the question may lead to confusion about the delay times, while others provide calculations and reasoning to clarify the SPL of the reflected sound.
Participants note potential ambiguities in the problem statement, particularly concerning the timing of the reflection's arrival and the assumptions of perfect reflection. There is also mention of varying interpretations of the equations provided in the textbook.
Rorshach
Hello. I have a problem, which is as follows:
A seat in a concert hall is 84 ft from the tympani. The tympanist strikesa single note. The sound pressure level of the direct sound of the note at the seat is measured to be 55 dB. The first reflection from the nearest sidewall arrives at the seat 105 msec after the arrival of the direct sound.
A) How far does the reflection travel to reach the seat?
B) What is the SPL of the reflection at the seat, assuming perfect reflection at the wall?
C) How long will the reflection be delayed after arrival of the direct sound at the seat?
sound speed in air:
1130 ft/sec
SPL=20log(p/pref)
The thing is, they are all solved in the book right under the data, but I don't understand anything beyond the first question and its solution. I would like to ask for some explanation on how why this is solved in this particular way.
First one is easy, I got this:
A)distance=(1130ft/sec)(0.105 sec)=118.7 ft
Please help me understand the other two questions.
Solutions to the are:
B)52 dB
C)30.7 msec
So far point C) is most confusing to me, isn't the answer given in the problem(105 msec)?
Rorshach said:
B)52 dB
How does sound pressure depend on distance?
That is wrong. If this is given as the correct answer then I conclude that the information given is garbled. My guess is that the given 105msec is not the delay after the direct sound. That would explain why question C makes no sense.
I wrote everything down word for word from my book. I am barely on page 30 and so far there have been few questionable equations, but those two just boggle me. Under every question there are equations and small adnotations for what is being done to solve the problem, so I will write entire problem as it stands in the book, starting with solution for the first question and ending on the last question:
A) How far does the reflectiontravel to reach the seat?
Distance=(1130 ft/sec)(0.105 sec)=118.7 ft
B)What is the SPL of the reflection at the seat, assuming perfect reflection at the wall?
First, the level L, 1 ft from the tympani, must be estimated:
55=L-20log(84/1)
L=55+38.5=93.5dB
The SPL of the reflection at the seat is:
dB=93.5-20log(118.7/1)=93.5-41.5=52dB
C)How long will the reflection be delayed after arrival of the direct sound at the seat?
The reflection will arrive after the direct sound at the seat after:
delay=(118.7-84)/1130ft/sec=30.7 msec
A free field is also assumed here. The 30.7 msec reflection might be called an incipient echo.
I am lost on how this is done, please people, if you understand how this is solved like this- explain it to me like to a 6 yo.
Suppose it takes time t for the direct sound to arrive.
According to the question, it takes time t+0.105 s for the reflected sound. That makes the total distance traveled by the reflected sound 1130(t+0.105)=84+118.7ft.
Judging from the given answers to a and c, I suggest the question is supposed to read:
"The first reflection from the nearest sidewall arrives at the seat 105 msec after being emitted"
I am sorry, but I still don't understand it. Maybe one of my brain cells is locked, but the the second, and especially the third question and their solutions are not understandable to me. Why the "delay" is not 105 msec? That question is constructed in such a way that it leaves no option but to think that 105 msec is what they ask for.
You do not seem to understand my previous post. I am saying that the question has been misstated. It is supposed to say that the 105ms is from when the timpani made the sound to when the echo arrived. That makes the answer 118.7ft correct for a), and the time between the two arrivals is 105ms-(84/1130)s = 31msec.
I will reply separately re b).
For b, how does the sound pressure depend on distance?
Sorry for not replying for so long- my laptop had a severe malfunction of graphics card after windows 10 update. Sound pressure decreases with 1/r at a distance from sound source.
Ok.
You are given the SPL of the direct sound. If the sound pressure of the direct sound is pdirect, what is the relationship between that and pref?
Using the known distances, what is the relationship between pdirect and preflected?
I understood it some time ago, sorry for not responding for so long- did You mean this approach:
p ∝ 1/r
p1 ∝ 1/r1
p2 ∝ 1/r2
p2/p1 = r1/r2
p2 = p1 * r1/r2
SPLreflected = 20log10(preflected/preference)
p ∝ 1/r
p1 ∝ 1/r1
p2 ∝ 1/r2
p2/p1 = r1/r2
p2 = p1 * r1/r2
Yes, except that that sequence is not mathematically correct.
p1 ∝ 1/r1 does not mean anything. Proportionality is a property of variables, whereas p1 and p2 are constants. Better would be
p ∝ 1/r
p =k/r for some constant k
p1 =k/r1
Etc.
Yes, You are right. There is also one more problem- an easy one, about loudspeaker SPL.In the book they give the solution, but when I checked it on calculator, the results were different. Results they gave were intuitive, but formulas they used give completely different result. Do You think I can post this problem in this thread or should I start a new one?
Better to post a new one.
Ok, I will. Thank You for your help- I have one question regarding the approach You suggested. The results from method proposed in the book (52 dB) differ slightly from the one You proposed(~51dB). Is it ok? I mean, the dependence of acoustic pressure on distance is not a strict rule, but more of an approximation, right?
I get 52dB. Please post your working.
55 dB = 20log(p1/pref)
55 = 20log(p1/20*10-6)
2.75 = log(p1/20*10-6)
102.75 = p1/20*10-6
p1 = 102.75 * 20*10-6
p1 = 0.01 Pa
r1 = 84 ft
r2 = 118.7 ft
p∝1/r
p1 = k/r1
p2 = k/r2
p2 = p1 * r1/r2p2 = p1 * r1/r2
p2 = 0.01 Pa * 84/118.7 = 0.007 Pa
SPL2 = 20log(0.007/(20*10-6)) = 50.881 ≈ 51 dB
Rorshach said:
p1 = 0.01 Pa
Here you are down to only 1 sig fig.
By plugging in numbers straight away you run the risk of a lot of rounding error accumulation.
There are many advantages in keeping everything symbolic until the end.
r1 = 84ft
t2 = 0.105s
c = 1130f/s
r2 = ct2
p1/p2=r2/r1
SPL2=SPL1+20 log(p2/p1)
= SPL1+20 log(r1/(ct2))
= 55+20 log(84/(1130x0.105)) = 52
12K
