U: Prove Limit $\lim_{x{\rightarrow}c}\sqrt{x}=\sqrt{c}$
  • Thread starter Thread starter kreil
    Limit Proof
The discussion revolves around proving the limit \(\lim_{x{\rightarrow}c}\sqrt{x}=\sqrt{c}\) using the epsilon-delta definition of limits. Participants are exploring how to manipulate the expression \(|\sqrt{x}-\sqrt{c}|\) and its relationship to \(|x-c|\) to establish the limit rigorously.
  • Participants discuss bounding the denominator \(\sqrt{x}+\sqrt{c}\) and consider various approaches to ensure the expression remains less than \(\epsilon\). There are attempts to find suitable values for \(\delta\) and questions about the validity of certain choices. Some participants suggest using specific values or forms to simplify the comparison.
The discussion is active, with participants sharing different strategies and questioning the validity of each other's approaches. Some guidance has been offered regarding bounding the denominator, but there is no clear consensus on the best method yet.
Participants are working under the constraints of the epsilon-delta definition of limits, and there is an emphasis on ensuring that all steps adhere to this formalism. The discussion also touches on the importance of not relying on specific examples to prove general cases.
kreil
Insights Author
Show [tex]\lim_{x{\rightarrow}c}\sqrt{x}=\sqrt{c}[/tex]
In other words, [tex]\forall \epsilon > 0 \exists \delta > 0 s.t. |x-c|< \delta \implies |\sqrt{x}-\sqrt{c}|< \epsilon[/tex]
So [tex]0<|x-c|<\delta \implies |\sqrt{x}-\sqrt{c}|=|\frac{x-c}{\sqrt{x}+\sqrt{c}}|[/tex]
and this is where I am stuck, a hint the teacher gave was "bound the denominator" but I am not sure how to do that...can anyone help?
Josh
You want to show:
[tex]\frac{|x-c|}{\sqrt{x}+\sqrt{c} } < \epsilon[/tex]
The way these things work is that you want to find something bigger than the LHS that is still smaller than RHS, because then the LHS is definitely smaller than the RHS. So keep replacing the LHS by something bigger and bigger until it's in a form that is easy to compare to the RHS. What can you replace the denominator by (that's independent of x) to get something larger than the LHS?
[tex]\frac{|x-c|}{\sqrt{x}+\sqrt{c}}<\frac{|x-c|}{1}<\delta=\epsilon[/tex]
Can I do that and just choose delta = epsilon?
No, that isn't true. If x=c=1/16, then the denominator is 1/2, and so the LHS is not less than the middle. The bound will depend on c.
[tex]\frac{|x-c|}{\sqrt{x}+\sqrt{c}}<\frac{|x-c|}{3\sqrt{c}}[/tex]
then this should work since if x=c=1/16, the LHS is 1/2 and the RHS is 3/4
can I then continue this so that
[tex]\frac{|x-c|}{3\sqrt{c}}<3\sqrt{c}\delta=\epsilon[/tex] ...??
No. First of all, you can't show something works with a single example. But it doesn't even work for that one. Remember, if you want to increase a fraction, you have to decrease its denominator. So you have to find something that is less than [itex]\sqrt{x}+\sqrt{c}[/itex].
so how about just squareroot of c?
Yea, that's less than [itex]\sqrt{x}+\sqrt{c}[/itex]. So what's your answer?
In other words, choose [tex]\delta=\frac{\epsilon}{\sqrt{c}}[/tex]
[tex]\frac{|x-c|}{\sqrt{x}+\sqrt{c}}<\frac{|x-c|}{\sqrt{c}}<\sqrt{c} \delta = \epsilon[/tex]
Looks good.
Another limit question
I need to show that [tex]\lim_{x{\rightarrow}a}x^3=a^3[/tex]
then [tex]0<|x-a|<\delta \implies |x^3-a^3|< \epsilon[/tex]
I'm having a lot of trouble getting the cubed terms to be less than an expression with |x-a|. Should I try turning the cubed terms into a fraction? I need a direction to go in.
Josh
x^3 - a^3 = (x - a)(x^2 + ax + a^2).
Also you could use |x|, |a| < |a| + e. That turns the second factor into something less than 3(a + e)^2
Yet Another E-d proof
I got that one now, thanks.
Now this one is giving me a problem...
Show [tex]\lim_{x{\rightarrow}1}\frac{x^2-x+1}{x+1}=\frac{1}{2}[/tex]
i.e. show [tex]\forall \epsilon > 0 \exists \delta > 0 s.t. |x-1|< \delta \implies |\frac{x^2-x+1}{x+1}-\frac{1}{2}|<\epsilon[/tex]
The teacher says to let [tex]x=1+ \lambda[/tex] so that as [tex]x \rightarrow 1, \lambda \rightarrow 0[/tex]. I wasn't quite sure how to properly incorporate this into the proof, because it gave me problems choosing delta:
[tex]|\frac{x^2-x+1}{x+1}-\frac{1}{2}|=|\frac{2x^2-3x+1}{2(x+1)}<br /> |=|\frac{(1+ \lambda -1)(2+2 \lambda -1)}{2(1+ \lambda +1)}|=|\frac{(\lambda)(2 \lambda +1)}{2( \lambda + 2)}=0< \epsilon[/tex]
I know that this can't be right since it doesn't even require me to choose a delta, so it doesn't really satisfy the definition. Any help incorporating the hint will be helpful.
lambda is not equal to 0, lambda is some constant. You want to show that when 0 < |lambda| < delta for some delta, your expression on the right is less than epsilon.
