mfb said:
The moon has an orbital velocity of 1.02 km/s, or roughly Mach 3. The Earth at the equator has a rotation speed of a bit more than Mach 1, leaving a difference of a bit less than Mach 2 if the eclipse is directly at zenith. It works with a Concorde - but only close to the equator around noon.
But doesn't the Earth rotate in opposite the direction that the moon travels? edit: No!
So wouldn't you add the speeds? edit: again, No!
And should we take into account the orbital speed of the Earth around the sun? edit: You can't even figure out which way things are turning, Om. You are hopelessly, rotationally, dyslexic. Just give it up.
This is probably why I just extrapolated the information from the map, as I don't even know which direction things are turning.
Wait!
From following Ceres, I know that the Earth travels counterclockwise around the sun. (30,000 m/s)
And the moon travels counterclockwise, because it shifts to the left every day. (1020 m/s)
And the Earth spins counterclockwise, because the sun appears to move
counterclockwise. (460 m/s)
<scratches head for awhile>
Never mind. This is an
OFF TOPIC, impossibly hard, homework problem...
<scratches head some more... Maybe if I converted everything to radians/sec...>
Nope! I can feel an aneurysm in my brain throbbing...
Borg said:
My list continues to grow...
As does mine. Thanks for the reminder. I've actually been researching this since at least March 10th, and am realizing that I'm not even close to being prepared.
I noticed yesterday in another thread, regarding photographing the sun,
Andy Resnick said:
using only an ND4 metallic filter,
that I'll need a special filter. And given that my camera doesn't list what size adapter I need, I had to measure and cut out one of my diffraction grating slide thingys. I think it's 42 mm.
ps. Just don't forget to put fresh batteries in you camera. When I went to the museum to take pictures of the SR-71, I turned my camera on, and it immediately went dead. Fortunately, I had a spare set with me. Always carry spare batteries!
