UIUC Phys 102: Exam 3 Prep - Questions 4-6
  • Thread starter Thread starter Alt+F4
    Exam Uiuc
The discussion revolves around clarifying equations and concepts related to Physics 102 exam preparation at UIUC. The user questions the validity of their equations for intensity calculations, specifically regarding I1, I2, and I3, and seeks confirmation on their approach. Additionally, there is a query about determining the order of fringes in a diffraction pattern, with guidance provided on counting from the center. The user also discusses finding focal lengths and magnification, confirming that their calculations align with expected results. Overall, the thread emphasizes the importance of understanding the underlying physics concepts for accurate problem-solving.
Alt+F4
http://online.physics.uiuc.edu/cgi/courses/shell/phys102/fall06/prep2a.pl?practice/exam3/sp06
Questions 4-6 , i don't need it to be solved, i just need to know whether my equations are right cause i have somone else's answers and i don't know how he got them. he Has I1 = I0 / 2 which doesn't make sense
I1 = I0 Cos(45)^2 since it is not verticle correct? if it was verticel it would be I1 = I0/2
I2 = I1 (Cos 45 + Theta ) ^2 since u are trying to find the angle diffrence
I3 = I2 (Cos 45 - Theta) ^2
is that even right at all? if not does anyone know of a site that has lectures to this stuff. Thanks
Question 19. How do u find what order fringe the 2nd and 3rd are in that pic?
http://online.physics.uiuc.edu/cgi/courses/shell/phys102/fall06/prep2a.pl?practice/exam3/sp05
Question 8
So the first one since it is horizontal would be I1 = I0/ 2 so this is only true if it is horizontal or verticle
To get the order of the fringe you just count from the centre, there is no zeroth order for a dark fringe the first dark fringe is the first minimum (trough), the second the second minimuetm etc (from the right of the central line). Anyway that's irrelevant the distance between the 2nd and 3rd fringe is just the distance between the central maximum (0 order) and the first maximum (n=1), which you should know how to find.
more info please :)
Edit: Actually this is what i did
Sin Theta = ( 2.5)(600*10^-9) / ( .3*10^-3) = .005
Sin Theta = (3.5)(600 * 10^-9) / (.3*10^-3) = .007
Angle is .28648
Angle is .40107
Y = Tan theta * L
Did it for both of them, subtracted and i got 1 mm, is the way i solved it correct or would u have had to use 1.5 and 2.5? thanks
Yes this answer is fine, although your working could be a lot of quicker and neater. Do you know what a small angle approximation is? As \theta tends to 0, sin \theta tends to \theta.ame with tan, cos tends to 1 of course.
http://online.physics.uiuc.edu/cgi/courses/shell/phys102/fall06/prep2a.pl?practice/exam3/fa05
Question 6
So i found the focal length and it is 12.5 cm which happens to be the answer. now i just want to make sure that it will be true for other problems if the magnification is half the size. So if it said quarter of a size would it be 6.25 cm instead? Thanks
http://online.physics.uiuc.edu/cgi/courses/shell/phys102/fall06/prep2a.pl?practice/exam3/sp04
QUestion 2
is this something i would have to just know or can i get it form I/d + 1/ O = 1 /F
Question 6
What would be the answer? It is C but i want to know how to solve it. thanks
All right, i got all the stuff up there, i just need help on this one
http://online.physics.uiuc.edu/cgi/courses/shell/phys102/fall06/prep2a.pl?practice/exam3/fa04
Why is A wrong?
So if the focal Length is 5 for the convex then they were converge there
Ignore everything that is above me
http://online.physics.uiuc.edu/cgi/courses/shell/phys102/fall06/prep2a.pl?practice/exam3/sp00
QUestion 25 and 26
