Underfloor heating (UFH) systems are influenced by the thermal properties of floor coverings, such as wood and ceramic tiles, which can affect energy losses. Higher flow temperatures may be required when using insulating materials like carpet, leading to increased downward heat loss and potentially lowering the efficiency of heat pumps. In well-insulated homes, these issues are minimal; however, poorly insulated structures may experience significant energy consumption increases. To optimize UFH performance, it is advisable to use low TOG carpets and engineered wood flooring, and to consider insulation strategies like expanded polystyrene (EPS) strips along external walls.
- Understanding of underfloor heating (UFH) systems
- Knowledge of thermal properties of flooring materials
- Familiarity with heat pump efficiency metrics, specifically Coefficient of Performance (COP)
- Basic principles of building insulation and energy loss
- Research the impact of thermal insulation on underfloor heating efficiency
- Learn about low TOG carpet options suitable for UFH
- Investigate engineered wood flooring specifications for use with UFH
- Explore insulation techniques, such as using expanded polystyrene (EPS) in construction
Homeowners, builders, and energy efficiency consultants interested in optimizing underfloor heating systems and reducing energy consumption in residential properties.
