Understanding Buckling: The Impact of Moments vs Applied Forces
  • Thread starter Thread starter roanoar
    Buckling Moment
A moment about the end of a structure cannot cause buckling; buckling is driven by applied forces rather than moments. The deflection equation indicates that the moment is proportional to lateral deflection, but it does not function as a direct cause of buckling. Localized buckling can occur after initial deformation, potentially leading to structural failure. However, the primary concern should be bending stresses resulting from deflection. Understanding these dynamics is crucial for assessing structural integrity.
roanoar
Can a moment about the end of something cause buckling or does it need to be an applied force?
For instance the uploaded image
Thanks!
Although I do not know your end conditions from your drawing, a end applied moment cannot cause buckling. Buckling arise from the deflection equation E I y'' = M where M is proportional to the lateral deflection, y. In your problem, M, shown above, is just your end applied load and is never a function of the deflection.
thank you!
No problem,
I thought I would reply with some additions. My colleague informed me that you can get localized buckling after the beam has deformed. Localized buckling means that it can kink at the edges.
I see. That does make sense. Would that lead to structural failure though?
I honestly don't know. I would suspect, however, that the failure criterion that you need to worry about is the bending stresses due to the deflection.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
