Engineering Understanding how to re-draw circuits
  • Thread starter Thread starter Lopez
    Circuits
Understanding circuit analysis involves recognizing series and parallel configurations. The user seeks guidance on reading a complex circuit and simplifying it to find currents and voltages. It is suggested to start from the bottom of the circuit, combining resistors in parallel and series to simplify the analysis. The importance of applying Kirchhoff's Current Law (KCL) at specific nodes is emphasized for solving voltages Va and Vb. The discussion highlights that removing components like R5 alters the current values, complicating the solution for Vb.
Lopez
I need to find I1,I2,I3,Va,Vb but i don't even know to read the circuit. i know how to to do series circuits and parallel circuits but not this. How do i read this circuit and know which ones are in parallel or in series. is there a way to re-draw it? I have the solution and answer. Therefore i don't need the step by step solution since i already have it,is just that it doesn't explain why they did it that why.
These are the I1=4A ,I2=1.33, I3=.67, I4=2.67,va=8.0,and vb i don't know.
Please help understanding what is going on in this circuit.
If you need a loop, put in a 20 V battery with the positive plate connected to E. Connect the negative plate of the battery to the 3 grounds at the bottom of the diagram.
Likes Lopez
I would work my way up from the bottom, simplifying bits and pieces as I go. R5 and R3 are in parallel, right? So you could combine those two resistors into a single resistance. Keep chipping away at it until you have a single loop.
Likes Lopez
If you combine circuit elements you will lose that components individual voltage and/or current.
I reccoend doing a KCL at Va and Va. Then solve for Va and Vb, and the currents will be easy to find.
thanks for the tip
if i do ((R5||R3)+R2)||R4 and this would be in series with R1 right? now to get Vb i think i would do Vb=R5(I2-I3) but what if that R5 was not there then how would i solve for vb
If R5 was not there then I2 and I3 would change. you cannot solve for an unknown value with unknown values
58K
