Understanding Singular Linear Maps: R^m -> R^n
annoymage
the question here said
is L, linear transformation/mapping is singular?
i'm still googling the definition singular linear map,
can anyone give me the definition please T_T
p/s; i thought it L maybe the matrix representation, but the question
L : R^m -> R^n
but aren't matrix representation are define on L: M(m,1) -> M(n,1)
should i take transpose of R^m and R^n ?
If L is a linear map between finite-dimensional vector spaces (such as [itex]\mathbb{R}^m[/itex] and [itex]\mathbb{R}^n[/itex]), then it can be represented by a matrix. In fact, it can be represented by many different matrices, each corresponding to different choices of basis. But sometimes the answer to a question can be clearer if you don't focus on the matrix representation. Unfortunately, you did not fully state the question! (i.e., how is L defined?)
In any case, a singular linear map is simply one that does not have an inverse. It can fail to have an inverse in one (or both) of two ways: (1) it is not injective, meaning there exist [itex]a \neq b \in \mathbb{R}^m[/itex] such that [itex]L(a) = L(b)[/itex]; or (2) it is not surjective, meaning that there exists some [itex]b \in \mathbb{R}^n[/itex] such that [itex]L(a) \neq b[/itex] for all [itex]a \in \mathbb{R}^m[/itex].
If [itex]m \neq n[/itex], then [itex]L[/itex] is guaranteed to be singular. (Why?)
thanks for the definition.
And your question, I can see If m<n then not surjective means singular
if m>n then not injective means singular. But still working on that. Tomorrow i'll try to post, help check it.
Anyway, i don't understand this,
what topic should i study for this thing?
Correct, surjectivity is impossible when [itex]m < n[/itex], and injectivity is impossible when [itex]m > n[/itex].
Well, the topic is linear algebra, but you can study it at several levels of sophistication. Are you taking a course in it? If so, have you seen the definition of a linear map between two vector spaces? It should look something like this:
If V and W are vector spaces over the same field K and [itex]L : V \rightarrow W[/itex], then L is a linear map if the following are true for all [itex]v, v_1, v_2 \in V[/itex], and [itex]k \in K[/itex]:
(1) [itex]L(v_1 + v_2) = L(v_1) + L(v_2)[/itex]
(2) [itex]L(kv) = kL(v)[/itex]
doesn't matter, i think i found it, i'll read it forthwith
yea i did pass that topic, only my lecture note doesn't define what singularity of linear map is, anyway thank you so much
