Understanding the Relationship Between Spin and Magnetic Moment
  • Thread starter Thread starter pivoxa15
    Definition Spin
The discussion centers on the relationship between spin and magnetic moment in particles, specifically electrons and protons. It is established that the spin of an electron is opposite in direction to its magnetic moment due to the definitions of magnetic moment (u = Ia) and spin. The magnetic moment is influenced by charge, while spin is not, leading to the conclusion that the spin of a proton aligns with its magnetic moment. The conversation highlights the complexity of these concepts and the need for clarity in understanding their definitions.
  • Understanding of quantum mechanics concepts such as spin and magnetic moment.
  • Familiarity with vector mathematics, particularly cross products (r x v).
  • Knowledge of particle physics, specifically the properties of electrons and protons.
  • Basic grasp of classical electromagnetism and its relation to particle behavior.
  • Research the mathematical formulation of magnetic moment in quantum mechanics.
  • Study the implications of charge on magnetic moment and spin in particles.
  • Explore the concept of angular momentum in quantum systems.
  • Learn about the role of spin in quantum field theory and particle interactions.
Students and researchers in physics, particularly those focusing on quantum mechanics, particle physics, and electromagnetism, will benefit from this discussion.
pivoxa15
The spin is opposite in direction to the magnetic moment of the electron. Is that because the magnetic moment, u is defined as Ia where a is the area vector and spin is defined with the same direction as if it had components around it that swirl around with the angular momentum being (r)x(v) so is always oppsite in direction to the magnetic moment. So the spin of the proton would always have the same sign as its magnetic moment?
Hello.
I don't understand what is your question... perhaps you can rearrange it a little bit.
So...
This is an statement.
Is this your answer or part of your problem?
This seems to be a guess of yours, Isn't it?
If you put it clearer, so we can help :wink:
Regards.
The electron has negative charge, the proton positive charge.
Mag mom is proportional to charge. Spin isn't.
The key part of my question is
'...spin is defined with the same direction as if it had components around it that swirl around with the angular momentum being (r)x(v) so is always oppsite in direction to the magnetic moment [since as Meir Achuz said, the spin does not take into account the charge].'
The rest is trying to draw a comparison with something that is understandable classically which is the magnetic moment.
So spin is like the area vector of a spinning particle. However in the electron nothing is spinning. But we still give this area vector. This vector is different to the mangetic moment when the charge is negative.
So I have given a go at answering my own question. Is it correct?
  • · Replies 19 ·
