Understanding Wiki's Milky Way Galaxy rotation chart
The discussion revolves around the interpretation of the Milky Way galaxy rotation curves as presented in a Wikipedia entry, specifically the differences between predicted curves based on visible matter and observed curves that include dark matter. Participants explore the implications of these graphs for understanding the distribution of normal matter and the necessity of dark matter in explaining the velocities of stars, including the Sun.
  • One participant notes a discrepancy between the predicted curve based on visible matter in the Wikipedia graph and another graph showing "visible matter only," questioning why they intersect at the Sun in one graph but not in the other.
  • Another participant suggests that the intersection at the Sun in the first graph likely indicates that the Sun's orbit was used to calculate the total mass of normal matter closer to the center of the Milky Way, which may not reflect the actual distribution of normal matter.
  • Concerns are raised about the uncertainty in estimating the amount of normal matter in the Milky Way due to dust obscuring distant stars, which complicates the interpretation of the graphs.
  • There is speculation about whether some researchers believe that the Sun could have a velocity of 220 km/s even without dark matter, indicating a potential disagreement among experts regarding the necessity of dark matter for the Sun's current velocity.
  • One participant expresses doubt that the velocity discrepancy could be reconciled without dark matter, suggesting that the normal-matter-only scenario may have been presented in a way that optimistically fits the data.
Participants express uncertainty and differing views regarding the implications of the rotation curves and the role of dark matter, indicating that there is no consensus on whether dark matter is necessary for explaining the Sun's velocity.
Participants highlight limitations in the understanding of normal matter distribution due to observational challenges, such as dust obscuration, and the reliance on specific assumptions in the calculations of mass and velocity.
hendoS
I was reading the wikipedia entry for Dark matter halo here:
https://en.wikipedia.org/wiki/Dark_matter_halo
And they have this graph for the Milky Way galaxy rotation curve:
"Galaxy rotation curve for the Milky Way. Vertical axis is speed of rotation about the galactic center. Horizontal axis is distance from the galactic center. The sun is marked with a yellow ball. The observed curve of speed of rotation is blue. The predicted curve based upon stellar mass and gas in the Milky Way is red"
What I don't understand is that I found several other graphs for the Milky way rotation curve that look like this:
Why in the wikipedia graph (top chart) is the predicted curve based on visible matter (red line) so different from the "visible matter only" line in the bottom graph. In the top chart the Sun sits at the intersection of the predicted (visible matter) and observed (visible + dark matter) lines.. but on the bottom graph they don't intersect at the sun. What am I missing here?
Thanks for any help with this!
Space news on Phys.org
There's a large amount of uncertainty about precisely how much normal matter there is in the Milky Way, partially as a result of the fact that there's a lot of dust that blocks much of the light of stars further away (this is why there's a big dark band in images of the Milky Way in visible light).
So I think the best clue is the fact that in the first graph, the two points meet exactly at the location of the Sun. This likely means that they use the Sun's orbit to calculate the total mass of matter that's closer to the center of the Milky Way than we are, then assume that all of that matter is normal matter, and that it's got some particular distribution based on observations.
The graphs that show the "normal matter only" curves as much lower most likely use observational estimates of the total mass of the normal matter, rather than our orbit.
Yeah, that seems like a good explanation since they say it's a predicted curve based on stellar mass. It still seems odd to me that they would do this because there is such a difference in velocity in the second graph (220 km/s vs 160 km/s). You mentioned a lot of uncertainty about how much normal matter is in the Milky way. Is there enough uncertainty that some researchers still think that even without dark matter the sun would have a velocity of 220 km/s? I know that some observed galactic motion absolutely requires dark matter, but what I'm wondering is does this requirement apply at the distance of our solar system. In other words, is there any disagreement among experts that the Milky Way galaxy needs dark matter for our Sun to have its current velocity?
The second graph seems to indicate that the need for dark matter increases as the distance increases from the Galactic center.
I doubt it. My guess is that it was an attempt to give the normal-matter-only situation its best possible chance of fitting the data.
9K
