Uniform circular motion with a pendulum
59 replies · 9K views · last reply
Femme_physics
http://img685.imageshack.us/img685/9250/drawingmo.jpg
In the drawing is depicted a pendulum hammer of an impact device (in both projections). The hammer is made out of shaft AB which upon it is held pendulum OM. At point M of the pendulum is a hammer. According to experiment they settle the pendulum in a condition close to that in the drawing, release it and it drops freely, as depicted in the dashed line in the drawing. At the lowest point of the fall (point N), the hammer reaches the model and breaks it.
Given:
Hammer Weight = 200 [N]
Length of the pendulum = 800mm
A) Calculate the max tension in pendulum OM.
[there is also a clause B, but I'm getting stuck at A]
I've written my question in the attempts
http://img824.imageshack.us/img824/3124/fy1q.jpg
http://img405.imageshack.us/img405/5020/fy2p.jpg
Hi Femme_physics! :wink:
Sorry, I don't understand what you've done. :confused:
Try conservation of energy :smile:​
Hi Fp :)
Short hint this time: it's not a uniform circular motion, so those formulas do not apply.
It's NOT uniform circular motion? O_o
Hmmm. We haven't studied about conservation of energy. This exercise might be off my league for now, then.
Thanks for letting me know!
Well, the hammer falls and accelerates while falling. That's why.
But you do have a formula that you've hardly used yet.
The one that says:
g h = v2 / 2
That would apply...
How do you know I hardly used it? What else do you know about my usages?!?
g h = v2 / 2
Hmm...how is this formula called?
We were given a list of such formulas but I don't see it. Or maybe I don't have yours and tiny-tim's super math vision feat.
http://img9.imageshack.us/img9/4261/listofsuchformulas.jpg
It's the formula in the bottom-right box. :wink:
It's the conservation of energy equation for something falling vertically.
Since energy depends only on the endpoints, and not on how you get there (direct or devious),
the same conservation of energy equation applies to this circular motion. :smile:
Thanks, tiny-tim! I wish he's given us NAMES to all the formulas, and not just the formulas themselves. I guess next class a decent question to the lecturer would be "can you name all those formulas?"
Duly noted and written.
Oh yea, we were even told that in biology.
*nods*
Then I shall spur myself to action and reply back sometimes later! :) Thanks, tiny-tim.
They don't have names.
This one is only conservation of energy if a happens to be gravity.
erm … it doesn't work in biology :redface: …
you use energy just standing still! :biggrin:​
There! :smile:
https://www.physicsforums.com/showpost.php?p=3297647&postcount=24
My bad, I have to admit it looks a little different, and I guess it takes a bit of a super math/physics vision feat to see it.
You will, just give it another level, and then you will have this feat as well! :wink:
Yeah, conservation of energy (for gravity and kinetic energy).
More specifically it is:
E = m g h + m v2 / 2
This is the energy of the system that never changes (assuming no friction).
So after any change, the energy E before, must be equal to the energy after.
Perhaps it's premature for you to see this, but I think you'll get it soon enough and it probably doesn't hurt if you'd recognize it.
*looks at character sheet*
This says I need 2948xp to ding! You have any ideas how many tough physics bosses problems I'll have to solve to get there?!? :(
I need an item that imbues me with that power ;)
Really? Nameless formulas? Well, someone must've come up with them and named them sometimes in the past. It can't be that he just came up with it and left it nameless?
erm … it doesn't work in biology …
I think we may have studied the physical properties that are also important in biology, but I clearly and distinctly recall this quote
"Since energy depends only on the endpoints, and not on how you get there (direct or devious),"
I tend to only get stuff after lots of problem solving, it appears. That's also how I like it :)
I used the diameter for "h" -- is that right? it's the change in position, delta x. So, the change in position is 1.6m!
http://img546.imageshack.us/img546/9615/vsolutiona.jpg
you're assuming that α = 0
Oh yes, sorry I didn't mention that. A rather important fact!
We're told to:
"ignore the weight of the shaft and the pendulum and assume the angle at the beginning of the motion is 0."
Ah...I missed that didn't you? ;)
Now that I got V I'm a little bit hesitant how to continue.
I like Serena said:
Hi Fp :)
Even now? Because, to find what they ask of me (tension at pendulum) don't I need to find the normal force? And doesn't that mean sum of all forces?...
[edit: heading out to college to help a student in statics :) , might not reply for a while]
All right! :cool:
I'll give you a couple more hints... :smile:
What forces act (or are required to act) on the hammer?
And at what point of the trajectory will these forces generate the greatest tension in the pendulum?
Finally, how large will these forces be at that point?
EDIT: As for your previous calculations ...
I'm missing ...
A little more of you! :P
Find the centripetal acceleration …
then use net force = mass times acceleration. :wink:​
Clearly when the hammer drops and just hits the sample
Well, I'll need to find out T before I can tell you. So I could tell how long does it take to make half a circle.
Hmm...how do I find it T? Do I use this formula? (I hope I used it correctly)
http://img39.imageshack.us/img39/783/triedtodecent.jpg
I'm missing ...
;) I would but I'd hate for people to start to think I'm modeling and not trying to do my homework lol
Hmm...I'm still missing T to find a, (since "a" has "v" in its formula, and "v" has "t" in its formula. It all comes down to T, it appears!)
Of course, if my above calculation is correct, then I got T. Is that right?
T is the time for a complete revolution of a uniform circular motion.
It's a pity that the hammer just falls and breaks something and is not neatly swinging around at an even speed to break something else. :wink:
The formula you need is the one that relates the (required) centripetal force to speed and radius.
That is:
F = m v2 / R
More destruction! More destruction! :D
Brilliant.
And we were given this list of formulas.
http://img24.imageshack.us/img24/6849/frfrh.jpg
I can see that formula there :)
The first 1 is just general
F = ma
The second is the one that "relates the (required) centripetal force to speed and radius."
The 3rd one is angular velocity.
The 4th one is angular velocity squared? I'm not sure what is that.
And the last one...wow. Not even sure what's that either.
But I need a formula I'm sure of :) Thanks to you. I'll use it.
Femme_physics said:
Did I get it?
Clause B is easy, same as the other exercise getting me back to statics :) That's my thing!
Almost, but there are 2 forces: the tensile force and the force of gravity.
The resultant force must be equal to the centripetal force.
However, this means the tensile force is a little bigger! :smile:
:D
F = ma
Actually, all these formulas identify the centripetal force.
The omegas in between are intermediate steps to find the last formula, which is also the centripetal force, just with different variables.
Note the little r behind a in the first formula F = m ar
This identifies the centripetal acceleration.
Note in particular that once you introduce T or f, you're assuming it's a uniform circular motion.
Before T and f are introduced the formula is also applicable to non-uniform circular motion (such as a hammer smashing stuff :devil:).
OH! That's brilliant, I got to say :) Because if the centripetal force was smaller the thing would break. And, if the centripetal force was bigger...well, that's impossible, but the thing would be pulled in closer to the rotation axis.
:) Must... learn... more... (!)
I will probably review this exercise for a long time now (esp. since everybody in class going to ask me about it).
So, ahem...right, the solution! Add 200 [N] you get 1000 [N]! or 999.18
Awesome :)
Thank you! Soooooooo much.
Actually, I was just thinking of something when it comes to the free body diagrams:
I think "Vt" (tangential velocity) in drawing is wrong, since at this point tangential velocity turns into a force that hits the sample, so there are two forces at play to add for max tension--> the force of the tangential velocity and the reaction force of the sample. Is that right?
Hi Femme_physics! :smile:
No, your free body diagram (a) is wrong …
i] the velocity Vt should not be on it at all, it's neither a force nor an acceleration
ii] you must decide which body the diagram refers to: since you're using the acceleration of the hammer (M, at the end of the shaft), the body must be the hammer, so the reaction force N at O is irrelevant: instead you need the tension T, which does act directly on the hammer
iii] you have shown the acceleration the same way as a force: you should show it differently (I refer a double arrow, off to the side of the diagram)
(alternatively, you could use the non-inertial rotating frame of the hammer, in which case the acceleration is zero, and you must instead show the extra, centrifugal force )
Femme_physics said:
… at this point tangential velocity turns into a force that hits the sample, so there are two forces at play to add for max tension--> the force of the tangential velocity and the reaction force of the sample. Is that right?
The reaction force between the hammer and the sample will be horizontal, so it will not affect the tension (which at that point is vertical).
Femme_physics said:
As I'm still not imbued with super level 58 math vision, I'll have to ask: Are you saying all these formulas are essentially the same? Do I really need so many of them then?
I think that what you need is to understand in how far they are the same and what use they are.
The only thing you need to know of the centripetal force is that:
[tex]F_{centripetal} = \frac {m v^2} r[/tex]
But you also need to know that:
[tex]v = \omega \times r[/tex]
And if the circular motion is uniform:
[tex]\omega = \frac {2 \pi} T[/tex]
[tex]f = \frac 1 T[/tex]
The other formulas can be derived from these.
It may be useful to keep them at hand for easier calculation, but it would help if you see that they are the same.
For instance, if you substitute v from the second formula in the first one, you'll find the other form of the centripetal force: F = m ω2 r
Ah! Settings me straight as always :) Of course! If we're looking at the "hammer head" only it emerges "from" the hammer head, not from the support. But wait, the hammer head hasn't been defined to me in terms of length and width. Does it matter?
Acceleration is always towards the axis of rotation. Of course N would have to point the same way because it's opposite of W. It's normal force... hmm..what am I missing here?
Interesting! A great fact. And duly noted :)
But you also need to know that:[tex]v = \omega \times r[/tex]
That I know :)
Also know :)
Aha! Then this is the one that lost me. A very important one too! Thanks, formula master :)
You wrote it in small text- any reason? I'll look into it later tomorrow. Heading to sleep now-- thanks for all your great awesome help, tiny-t, ILS! :) You rrrrrrrrrrrrrrrrrock.
