Uniform Continuity of f(x) = 1/(|x|+1) on R: Epsilon-Delta Proof
The discussion focuses on proving that the function f(x) = 1/(|x|+1) is uniformly continuous on R using an epsilon-delta approach. The key requirement is to establish a delta (d) for any given epsilon (e) such that if |x-y|<d, then |f(x)-f(y)|<e for all x, y in R. Participants express difficulty in finding an appropriate delta and inquire about potential algebraic techniques or tricks to simplify the proof. The conversation emphasizes the need for a clear method to demonstrate uniform continuity effectively. The thread highlights the importance of understanding the epsilon-delta definition in the context of this specific function.
PsychonautQQ
Prove that f(x) = 1/(|x|+1) is uniformly continuous on R.
This needs to be an e-d proof (epsilon-delta).
So I suppose we should start with let e>0, then we want to find a d such that for all x,y in R, if |x-y|<d then |f(x)-f(y)|<e.
I'm having trouble locating a d that will work, is there some algebra trick or other type of trick that can help me?
bump because i don't want 666 post count
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
