MHB Understanding the CDF and PDF of a Uniform Distribution for Y
This discussion focuses on deriving the cumulative distribution function (CDF) and probability density function (PDF) for the random variable Y, defined as Y = min{X, 6-X} based on the uniform distribution of X. The CDF is established as P(Y < y) = y/3 for 0 ≤ y < 3, and the PDF is confirmed as f(t) = 1/3 for 0 ≤ t ≤ 3. The discussion clarifies that P(Y > y) is defined piecewise, with specific values for y ≤ 0 and y ≥ 3, ensuring a comprehensive understanding of the uniform distribution's properties.
  • Understanding of uniform distributions and their properties
  • Knowledge of cumulative distribution functions (CDF) and probability density functions (PDF)
  • Familiarity with piecewise functions and their applications
  • Basic calculus, specifically derivatives and their interpretation
  • Study the properties of uniform distributions in detail
  • Learn about piecewise functions and their graphical representations
  • Explore the relationship between CDF and PDF through examples
  • Investigate the concept of continuity in probability functions
Statisticians, data analysts, and students studying probability theory who seek to deepen their understanding of uniform distributions and their associated functions.
lemonthree
I need guidance on part c, finding the cdf/pdf of Y.
I understand that for X>3, Y=6-X and for X<3, Y=X.
For X = 3, Y=3
For part b, I got P(Y>y)= (3-y)/3, for 0≤y<3
Now for part c, I know P(Y>y) relates to the cdf.
But the definition of cdf relates to P(Y<y), so I'm guessing I have to
do 1-P(Y>y) to get the cdf which is y/3, 0≤y<3.
I'm thinking the pdf would be 1/3 for 0≤y<3?
I know for sure Y is a uniform distribution.
I'm not too sure on the interval (x-a)/(b-a)
Is it Y~Uniform distribution(0,3)?
Hi lemonthree,
The short answer to your post is that you're basically correct on everything you wrote. This response is really to help clean up some of the details. Please refer to the image below, which is a plot of the random variable $Y$ as a function of $X$, as defined by $Y = \min\{X, 6-X\}$.
For completeness in part (b), the values for $P(Y>y)$ should be included for $y\leq 0$ and $y\geq 3$. From the graph below we see that
$P(Y > y) = \begin{cases}
1 & y\leq 0\\
1-\frac{y}{3} & 0\leq y\leq 3\\
0 & y\geq 3
\end{cases}$
For part (c) you can certainly use $P(Y<y) = 1-P(Y>y)$ and the formula from part (b) to get
$P(Y < y) = \begin{cases}
0 & y\leq 0\\
1 & y\geq 3
\end{cases}$
Another possibility is to reason geometrically. For example, if $y = 1$ (as shown in the figure), we can see that $P(Y < 1) = P(X<1\,\text{or}\, X>5) = 2\cdot P(X <1) = 1/3,$ where the second equality is true because the graph is symmetric about the vertical line $X = 3.$ This same argument can be used for any $y$ such that $0\leq y\leq 3$; i.e., $P(Y<y) = P(X<y\,\text{or}\, X>6-y) = 2\cdot P(X<y) = \frac{2y}{6}=\frac{y}{3}$ for all $0\leq y\leq 3$.
The CDF is pictured below. The PDF is obtained by taking the derivative of the CDF. I suspect you're familiar with derivatives. If not, derivative means the slope of a graph. Hence, when we say the PDF is the derivative of the CDF, we mean we get the PDF by looking at the slopes of the CDF. Because there are sharp corners in the graph of the CDF, it is technically not differentiable at these points, which results in so-called "jump discontinuities" in the PDF. In any case, the resulting PDF is given by
$f(t) = \begin{cases}
0 & t< 0\\
\frac{1}{3} & 0\leq t\leq 3\\
0 & t> 3
\end{cases}$
Thank you so much GJA. That was very helpful. I just have a question on this part regarding the inequality signs.
1 & y\leq 0\\
0 & y\geq 3
\end{cases}$
Should it be
1 & y\ < 0\\
0 & y\ > 3
\end{cases}$
instead? Or both ways work fine? Although the values are the same I'm not very sure whether I'm mathematically correct...
Great question, and glad to hear the post was helpful.
Since the values are the same, both answers are acceptable. Because the values are the same, the CDF is a "continuous" function; meaning there aren't jumps/different values at the points $y=0$ and $y=3$. For comparison, the PDF is not continuous at $y=0$ and $y=3$. This can be seen as jumps in the graph below. For the PDF, you can see that we used strict inequalities to define $f(t)$.
Ah ok, that makes sense. Thank you so much for your help!
