UnimplementedError: Cast string to float is not supported
  • Context: Python
  • Thread starter Thread starter BRN
    Error Float String
5 replies · 5K views
BRN
Hello everyone,
I have this problem that I can't solve:
I have two types of images contained in two different folders. I have to create a dataset with these images and train a cycleGAN model, but for simplicity we assume that I want to print them on monitor and forget the cycleGAN.
My code is this:
[CODE lang="python" title="load and print"]input_path_A = './data/img_test_A/'
input_path_B = './data/img_test_B/'
EPOCHS = 50
buffer_size = 1000
batch_size = 2
def load_and_norm(filename):
img = tf.io.read_file(filename)
img = tf.cast(img, tf.float32) / 127.5 - 1 # normalization to [-1, 1]
return img
def load_dataset(ds_folder, batch_size, buffer_size):
img_filenames = tf.data.Dataset.list_files(os.path.join(ds_folder, "*.png"))
img_dataset = img_filenames.map(load_and_norm)
img_dataset = img_dataset.batch(batch_size).shuffle(buffer_size)
return img_dataset
def show_img(dataset1, dataset2):
iterator1 = iter(dataset1)
iterator2 = iter(dataset2)
num_rows = 4
num_cols = 2
fig, axs = plt.subplots(num_rows, num_cols, figsize=(10, 10))
axs = axs.flatten()
for i in range(num_rows*num_cols):
image1 = next(iterator1)
image2 = next(iterator2)
axs.imshow(image1)
axs[i+num_cols].imshow(image2)
plt.show()[/CODE]
I receive this error:
[CODE title="error"]2023-03-20 18:37:30.450694: W tensorflow/core/framework/op_kernel.cc:1722] OP_REQUIRES failed at cast_op.cc:121 : UNIMPLEMENTED: Cast string to float is not supported
UnimplementedError Traceback (most recent call last)
/tmp/ipykernel_18739/534026073.py in <module>
2 print("Starting epoch", epoch + 1)
----> 4 for x, y in train_dataset:
5 show_img(x, y)
~/.local/lib/python3.9/site-packages/tensorflow/python/data/ops/dataset_ops.py in __iter__(self)
488 if context.executing_eagerly() or ops.inside_function():
489 with ops.colocate_with(self._variant_tensor):
--> 490 return iterator_ops.OwnedIterator(self)
491 else:
492 raise RuntimeError("`tf.data.Dataset` only supports Python-style "
~/.local/lib/python3.9/site-packages/tensorflow/python/data/ops/iterator_ops.py in __init__(self, dataset, components, element_spec)
724 "When `dataset` is provided, `element_spec` and `components` must "
725 "not be specified.")
--> 726 self._create_iterator(dataset)
727
728 self._get_next_call_count = 0
~/.local/lib/python3.9/site-packages/tensorflow/python/data/ops/iterator_ops.py in _create_iterator(self, dataset)
749 output_types=self._flat_output_types,
750 output_shapes=self._flat_output_shapes))
--> 751 gen_dataset_ops.make_iterator(ds_variant, self._iterator_resource)
752 # Delete the resource when this object is deleted
753 self._resource_deleter = IteratorResourceDeleter(
~/.local/lib/python3.9/site-packages/tensorflow/python/ops/gen_dataset_ops.py in make_iterator(dataset, iterator, name)
3239 return _result
3240 except _core._NotOkStatusException as e:
-> 3241 _ops.raise_from_not_ok_status(e, name)
3242 except _core._FallbackException:
3243 pass
~/.local/lib/python3.9/site-packages/tensorflow/python/framework/ops.py in raise_from_not_ok_status(e, name)
7105 def raise_from_not_ok_status(e, name):
7106 e.message += (" name: " + name if name is not None else "")
-> 7107 raise core._status_to_exception(e) from None # pylint: disable=protected-access
7108
7109
[[{{node Cast}}]] [Op:MakeIterator][/CODE]
I don't understand what the problem is, but I think it is due to how the dataset is created.
How can it be resolved?
Thank you all.
I think you should try to search on this error in the context of Tensorflow as there is either a bug report on it or someone else has figured out what went wrong.
If not then you should file a bug report with Tensorflow.
Reply
For example, googling "tensorflow cast string to float" returns a lot of hits.
Reply
You could try downloading your training data again in case it got corrupted somehow.
Also check if there are any updates to tensorflow that you haven't installed.
BRN said:
Hello everyone,
My code is this:
return img
[/CODE]
tf.io.read_file reads the file as a string, and not as a tensor.
You'll need tf.io.decode_png to convert it to a tensor
https://www.tensorflow.org/api_docs/python/tf/io/decode_png
Reply
That's right, this was the problem.
Here the correct code
[CODE lang="python" title="correct code"]def load_and_norm(filename):
img = tf.io.read_file(filename) # get only filename string
img = tf.image.decode_png(img, channels = 3) # necesary converting to tensor
return img[/CODE]
Thank you all!
Reply
