High School Uniqueness of Analytic Functions
The discussion focuses on the properties of real analytic functions, particularly the theorem stating that if two real analytic functions f and g agree at a point and all their derivatives are equal at that point, then they are equal in a neighborhood of that point, and if the domain is connected, they are equal throughout the entire domain. This leads to the conclusion that the set of analytic functions has the same cardinality as the real numbers. Participants explore the possibility of extending this concept to smooth functions and discuss the challenges of finding analytical solutions to differential equations, noting that non-analytical solutions may be more complex to identify. The conversation also touches on the nature of continuous functions and their cardinality, emphasizing the intricacies of function classification in mathematical analysis.
jackferry
Hello, I am learning about smooth analytic functions and smooth nonanalytic functions, and I am wondering the following:
Is there a theorem that states that for any real analytic functions f and g and a point a, that if at a f=g and all of their derivatives are equal, that then f=g?
Yes, since the two functions have the same Taylor series at a, they most be equal in a neighborhood of a.
Does this imply that they will be equal for their entire domain?
Yes, if the domain is connected (which, I believe, is included in the definition of "domain"): If there was a point in the domain where the functions have different values, then there is a path from the first point to this point, parametrized by h: [0,1] -> D, say. Let s be the supremum of the subset of [0,1] for which f(n)(h(t))=g(n)(h(t)) for all n.. By continuity f(n)(h(s))=g(n)(h(s)) for all n, and then by the same argument as in my previous post, f=g in a neighborhood of h(s), and hence f(n)(h(t))=g(n)h(t) for some t>s, unless s=1. This is a contradiction (even if s=1, since f(h(1)) and g(h(1)) are unequal). Hence f=g in the entire domain.
Awesome, thank you very much! So this means that we can enumerate all real analytical functions by choosing a point, and "listing" all the possible values of the function at that point, and then doing the same with all of its derivatives. This seems to imply that the order of analytical functions is equal to the order of the real numbers.
Sent from my SCH-I545 using Physics Forums mobile app
I never thought of that, but yes, you are right! The set of analytic functions in a domain has cardinatilty c.
Would it be possible to extend that cardinality to smooth functions somehow, or are those too complex?
Even better, there are only |\mathbb{R}| many continuous functions \mathbb{R}\to\mathbb{R}. This is because a continuous function f:\mathbb{R}\to\mathbb{R} is determined by its values on \mathbb{Q}, so the cardinality of the set of such functions is no more than the cardinality of the set of functions \mathbb{Q}\to\mathbb{R}. As \mathbb{Q} is countable, this latter set is in bijection with the set of sequences of real numbers, which has cardinality |\mathbb{R}|.
Maybe you can trivially say that all constant functions are Analytic, which gives you the cardinality of the Reals. But I guess you want the non-trivial ones.
It seems you can use Complex-Analytic functions here and count them, since the two are the same when you deal with Complex-Analytic functions. I mean the Real/complex parts of a Complex-Analytic function are Real-Analytic. It seems one can also use a Baire Category argument here too.
That's amazing! So a slightly tangential question: when we talk about problems, esp. Differential equations, I've heard something along the lines of "there is no general analytical solution". Why is that important? Are non-analytical solutions difficult to find? Is the challenge somehow due to the fact that they can't be approximated by a taylor series?
Analytical , "nice" closed-form solutions are often hard to come about , but you can have, e.g., distributional/weak solutions.
This is one way of proving Erland's result from post #2 : Consider the set of points S={ x in (a,b): f(x)=g(x)}. We can show this set is open ( in (a,b), which is in this case the same as in the Real line):
S= {x in (a,b): f(x)=g(x)} = (a,b)- ({ x in (a,b): f(x)>g(x)} ##\cup ## {x in (a,b): f(x)<g(x) } . Each of these last two sets is closed: let h(x):f(x)-g(x) , the the two sets are of the form {## f^{-1}(0) ##} , inverse image of a closed set under continuous map, and therefore closed, and so is their ( finite here) union . This means S is open and therefore the union of open intervals.
EDIT: As Erland points out, there is an error here, in that the sets on the right _are not_ of the form ## f^{-1}(0) ##, THO, the set {## x: f(x)=g(x) ## } is of the form {## f^{-1}(0) ##} BUT my original proof _does not_ hold then. Back to the drawing board.
I don't understand why the two sets are of the form {## f^{-1}(0) ##}.
Likes WWGD
Aaargh. Right, my bad , it is ##f(x)-g(x)> 0 , f(x)-g(x)<0 ##. Let me correct. I meant for the case ##f(x)=g(x) ##
I still don't understand why these two sets are closed. They are clearly open, but why closed?
Sorry, I meant the set {## x: f(x)=g(x) ##} is closed, as it is of the form {## f^{-1}(0) ##} , while the others ( meaning {## x: f(x) >g(x)##} and {## x: f(x)<g(x) ##} ) are open, as preimages of sets of the form ## (a, \infty) ##. EDIT:Since the later are open, whenever ##f(x_0)>g(x_0) ## , there is an interval where this holds, which makes sense, given EDIT both f,g, and therefore their difference is/are continuous. EDIT2: It follows that the latter two sets are each the union of countably many open intervals.
