Uniqueness of solution to the wave function
38 replies · 6K views
Could you help me a little more?
Now I have to look at [tex]u_3=u_2-u_1[/tex]. I know that [tex]u_3(0,x)=0[/tex] and that [tex]\partial _t u_3 (0,x)=0[/tex].
I have the fact that [tex]\int _{{S^2 (r)}_{r\to \infty}} (\partial _t u) \nabla u d \vec S =0 \Rightarrow E(t,x)=K \in \mathbb{R}[/tex].
gabbagabbahey said:
Well, what is [itex]E(t=0)[/itex] for [itex]u_3[/itex]?
If I'm not wrong: 0. Thus 0 for all t and all x. Does no energy mean no wave? So there's no difference between [tex]u_1[/tex] and [tex]u_2[/tex]? I don't know how to justify it properly.
[itex]E[/itex] is indeed zero (although you may want to show me your proof of this, so that I can check your reasoning), so
[tex]\int _{\mathbb{R}^3} \frac{1}{2} \left [(\partial _t u_3)^2 +\mathbf{\nabla} u_3 \cdot \mathbf{\nabla} u_3 \right] dV=0[/tex]
What kind of numbers (e.g. real, complex, imaginary, positive, negative etc.) are the quantities [itex](\partial _t u_3)^2[/itex] and [itex]\mathbf{\nabla} u_3 \cdot \mathbf{\nabla} u_3[/itex]? When you add up (integrate) a bunch of those kinds of numbers, what is the only way that you can get zero as a result?
[tex]\partial _t u_3 = \partial _t u_2 - \partial _t u_1[/tex]. In t=0, all terms are worth 0.
Hence the first term of the integrand of [tex]\int _{\mathbb{R}^3} \frac{1}{2} \left [(\partial _t u_3)^2 +\mathbf{\nabla} u_3 \cdot \mathbf{\nabla} u_3 \right] dV[/tex] is worth 0.
Now we've showed that the second term of the integrand is worth [tex]2 (\nabla(\partial_t u_3) \cdot \nabla u_3)[/tex]. But we just showed that [tex]\partial _t u_3=0[/tex] when t=0, hence all this term is also worth 0. And so [tex]E(t=0,x)=0[/tex], [tex]\forall t[/tex] and [tex]\forall x[/tex].
What kind of numbers (e.g. real, complex, imaginary, positive, negative etc.) are the quantities LaTeX Code: (\\partial _t u_3)^2 and LaTeX Code: \\mathbf{\\nabla} u_3 \\cdot \\mathbf{\\nabla} u_3 ? When you add up (integrate) a bunch of those kinds of numbers, what is the only way that you can get zero as a result?
Real and positive I'd say. Real, not really sure why (I just seen in Born's book on Optics that some general time-harmonic fields are complex and that the real parts represent the fields), but energy has to be real... although I wouldn't be so surprised if it's a complex number whose real part represent the energy.
The first term is positive if it's a real number. The second term is also positive if real since we're dot producting a vector with itself. We have [tex](a,b,c) \cdot (a,b,c)=a^2+b^2+c^2\geq 0[/tex].
Thus the only way for the E to be 0 is that both terms are actually 0. (unless there are some complex numbers! But I'll wait your voice as why it's not possible to be in such a situation).
Oh... thus [tex]u_3=0[/tex]... Is that done?!
We did?!... Certainly, if [itex]u_3(0,x)=0[/itex], you can also say [itex]\mathbf{\nabla}u_3(0,x)=0[/itex]...that's all you need in order to show the second term vanishes.
In order to say that the integral will be zero for all [itex]t[/itex], you also need to show that [itex]u_3[/itex] satisfies the wave equation, so that you can apply the proof of [itex]E[/itex] being constant.
I'd say it is is safe to assume that [itex]u_3[/itex] is real-valued (and hence so are its derivatives). However, [itex](\partial_t u_3)^2[/itex] doesn't necessarily have to be positive, it could also be zero.
Right.
You can't directly conclude that from the fact that [itex](\partial_t u_3)^2[/itex] and[itex]\mathbf{\nabla}u_3\cdot\mathbf{\nabla}u_3[/itex] are both zero. However, the fact that [itex](\partial_t u_3)^2=0[/itex] does allow you to conclude that [itex]u_3[/itex] is constant in time. And you also know that [itex]u_3(t=0,x)=0[/itex] so yes, [itex]u_3=0[/itex] and hence [itex]u_1=u_2[/itex] and thus thereis only one unique solution to the given wave equation.
In order to say that the integral will be zero for all LaTeX Code: t , you also need to show that LaTeX Code: u_3 satisfies the wave equation, so that you can apply the proof of LaTeX Code: E being constant.
Ok, what about this argument: "[tex]u_1[/tex] and [tex]u_2[/tex] are solutions to the WE, hence any linear combination of them also is a solution to the WE; thus [tex]u_3[/tex] also satisfies it."?
Thanks for the rest.
Exactly.:smile:
gabbagabbahey said:
Exactly.:smile:
Ok. A big thank you for everything for all the help you provided me and all the time taken to try to teach me a lot of things. I'm going to copy the full solution on a sheet of paper once again and try to digest it completely.
I have a similar problem although harder where the energy is not given and I have to deduce it; so you might see me again posting in the same forum!
