Uniqueness Theorem Homework: Static Charges in Vacuum
The uniqueness theorem for static charges in a vacuum states that if a solution to the electrostatic potential exists, it is the only solution for that configuration. This means that if two potentials satisfy the same boundary conditions and the same charge distribution, they must be identical. The discussion raises questions about how this theorem applies to different systems and whether the explanation provided is sufficient. A more explicit formulation involves demonstrating that if two potentials satisfy the same Laplace equation under the same conditions, they must be equal. Overall, the uniqueness theorem is crucial for understanding electrostatic problems in vacuum.
captainjack2000
I have a situation with a charge distribution for a system of static charges in a vacuum. It then asks to state the uniqueness theorem for such a system.
I know that the uniquessness theorem means that once you have found one solution to the system you have found THE solution. But how does this change for different systems? Is this a good enoug answer to what is the uniqueness theorem?
perhaps you could be a little more explicit such as if we can find phi,psi such that del^2 phi = - rho/epsilon_0 and del^2 psi = - rho/epsilon_0 then phi=psi but id say it looks fine. perhaps someone else will disagree though...
  • · Replies 27 ·
12K
