Unit Circle Double Angle Derivations
  • Thread starter Thread starter aronclark1017
aronclark1017
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality it is a miracle I was even able to solve this one that way. Don't be a dummy else could possibly spin off into infinity before simply making the simple decision to use 90-x.
Mathematics news on Phys.org
Never trust a diagram sometimes they are close but often it could be a trick.
Like making an equilateral triangle with angles of 70 degrees each or worse 90 degrees.
I recall one poster here showing a diagram of a figure but upon solving you found out it was a segmented straight line. Apparently, it was for a job interview.
Heh dry idea..I think is to never trust one person by self when it come to mechanics no debugger else is dry idea even with PhD.
Another way to say it is:
Trust but verify. While we can’t test everything, we should test those things that we are skeptical of and always remember to keep an open mind as all things are suspect.
As a software engineer, we write code, add bugs and then have to find them. But every once in awhile, the bug is in some third party code, invisible to the developer and it takes a lot of time to ferret out whats going on.
Another aphorism is: Extraordinary ideas require extraordinary proof that they are true.
This comes up a lot in physics where people think Einstein CAN’T be right because it goes against their daily experience or Quantum Mechanics because its too spooky.
Or the Flat Earthers who believe the world can’t be a pear-shaped oblate spheroid because their daily experience is that Earth is mostly flat as far as the eye can see.
All these group have yet to provide extraordinary evidence to prove their case.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
