Unit Consistency: Exam Prep in 8 Hours
  • Thread starter Thread starter jaimieee
    Unit
The discussion revolves around the concept of unit consistency in physics, particularly in preparation for an upcoming exam. Participants are exploring which units exhibit consistency and the definitions related to consistent units, referencing both the MKS and CGS systems.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants are attempting to identify consistent units and question the definitions provided in their textbook. They discuss examples of units, such as km/h and kg/m³, and explore the dimensional relationships between different units.
The conversation is active, with participants sharing their interpretations and seeking clarification on unit consistency. Some have offered definitions and examples, while others express confusion and seek further understanding of the concepts discussed.
There is mention of a specific time constraint due to an impending exam, and participants are working within the framework of their textbook's definitions and examples of consistent units. Some participants also note potential typos or inaccuracies in the definitions provided.
jaimieee
Ok, this is not a homework. But we have an exam later 8 hours from now.
On our book there is an activity called the Unit Consistency.
The instruction says: Which of the units below do no exhibit unit consistency? Give the equivalent consistent units for those that are not consistent.
1) cm/s2 - Answer: cm/s2
2) km/s - Answer: km/h
Our Physics teacher gave us some of the consistent units like:
km/h
mi/h
kg/m3
but I'm not sure if only these are the consistent ones, are there still consistent units? Can you share it? Thank you.
km/h
mi/h
kg/m3
Is there a definition of "consistent units" offered by the book or instructor?
Yes,yes! Sorry I wasn't able to define.
This is what is EXACTLY written :)
Unit Consistency
whenever you make calculations involving measurements, always remember to check for unit consistency; that is, the units should belong in the same system. Generally, if you are using meter for length, you should use gram for mass. Within the SI, the system of units based on the use of meter and kilogram is referred to as the MKS (meter-kilogram-second) system. Another system is the CGS system, which uses the centimeter, gram and second.
I didn't get it. It's confusing me :(
I think they mean which are dimensionally the same.
The basic dimensions are length, mass, time (plus temperature, and current)
So for example speed is length/time so could be given in miles/hour, m/s, km/min furlong/fortnight etc but could never be km/kg
So two sets of units are consistent if they refer to the set of same base units.
Unit Consistency
Oh, I understand now. Well, except for the typo in the sentence that says "if you are using meter for length, you should use gram for mass." That is incorrect. As the rest of the paragraph states, the typical unit systems are:
MKS (SI) -- meter, kilogram, second
cgs -- centimeter, gram, second
There are similar consistent unit systems for goofy units like we use here in the US (pounds, whatever). This is a pretty good intro to units, with pointers out to other articles:
http://en.wikipedia.org/wiki/Units_of_measurement
So it looks like the units you posted in your original post (OP) are consistent. Do you see why the following would be inconsistent?
g/m^3
Hmm for example the given is:
Newtons per centimeter , what will be the consistent unit?
I think km/min is not the consistent one? I think it should be km/h? What do you think?
I kinda get it but I'm not sure if my understanding is correct.
g/m^3
I think the answer should be kg/m^3? I used the MKS (SI).
Correct. kg/m^3 or g/cm^3 would be consistent sets of units, if I understand the definition correctly.
It should be Newtons per meter or dynes per centimeter(surface tension)
It is MKS(Meter Kilogram Second) so it is km/s
Hi. We just had our exam awhile ago but this one was not included. T__T Anyway thank you guys ;)
Given the earlier definition, km/s is not consistent by m/s would be.
See Post #1, Item 2 ... km/h is considered to be "consistent units".
  • · Replies 75 ·
