Unknown android icon...what do you think?
  • Thread starter Chud
    Android
14 replies · 3K views · last reply
Chud
Whenever I turn on my hotspot, the hotspot icon appears but then second later this icon appears on upper left side. Anyone know what it is by any chance?
(the pic isn't screenshot obviously, but the icon looks identical to this. (the grey background = phone wallpaper)
I guess its related to hotspot but it must mean something additional to the regular hotspot icon right? thanks!
Black outline of an ellipse with a small filled black ellipse at its centre, on a white square against a grey background.
  • Black outline of an ellipse with a small filled black ellipse at its centre, on a white square against a grey background.
Will it be possible to post a screenshot of the notification? Maybe you can darken out your wallpaper if privacy is your issue.
Generally I have a different icon for hotspot:
Android quick settings panel showing 9:30 a.m. Thu, 21 March, toggles for Torch, Do not disturb, Vibrate, Wi-Fi and Auto rotate, a brightness slider, and notifications for Tethering or hotspot active and Caffeine.
But these do differ with mobile companies. Which phone are you using?
  • Android quick settings panel showing 9:30 a.m. Thu, 21 March, toggles for Torch, Do not disturb, Vibrate, Wi-Fi and Auto rotate, a brightness slider, and notifications for Tethering or hotspot active and Caffeine.
thanks for replying. Its not privacy issue I just can't be bothered to sreenshot then upload. But the icon is precisely as i drew it. It shows up in upper left corner second after the hotspot icon appears. Kinda weird right?
Tom.G said:
That link doesn't work for me. It redirects back to the page I was on. (right here!)
That was a pdf, I copied the link from google search.
The file has been attached.
Thanks for the pdf! I didnt even think of looking in a manual. I just went through whole thing though and there is no icon that matches. Any other ideas by any chance? Thanks again!
Also I reset phone and it still shows up after turning on hotspot
Unknown apps/malware? Go to Application manager under Settings, select Show System Apps (there should be an option), and check if it matches any app icon.
thanks I just checked all the apps with system checked and still no match.. Wouldnt reseting get rid of malware? Also I looked on this exhaustive glossary and it didnt match anything. thanks if you have any more ideas
That's quite frustrating! By the way, which android version are you using?
thanks for all the help Wrichik (and TomG.) , I ended up calling manufacturer and it is an andoird system icon for hotspot options. I didnt think of this at the time but when you pull the drop down its right there and it says "android system" along with tethering info. But I think its overkill because there's already the hotspot icon but whatever...mystery icon solved. thanks for troubleshooting
Weird. I never saw an Android system icon on activating hotspot. Anyways, all's well that ends well.
Maybe see if you can change the configuration of the 'hotspot' app to get rid of it. If not, call the manufacturer again; at least that way they will know it's an annoyance.
Cheers,
Tom
