Unknown primes less than largest known prime?
  • Context: Graduate
  • Thread starter Thread starter SW VandeCarr
    Prime Primes
15 replies · 4K views
SW VandeCarr
The largest known primes for some time have all been Mersenne primes. Can it be shown either that there may exist or cannot exist unknown primes less than the largest known prime?
If you're talking only about other Mersenne primes, mgb_phys answered it: we have no idea. But to answer your literal question:
There are more than 1012978181 primes* beneath the largest known Mersenne prime. If storing each prime takes 1 bit, there has not been enough storage media produced on Earth through all history (hard drives, DVDs, clay tablets) to hold all these primes.
So yes, there are unknown primes beneath the largest known prime.
* In particukar, there are between 1.05901756822452 × 1012978181 and 1.05901756822453 × 1012978181 primes in that range, thanks to Pierre Dusart's tight bounds on pi(x).
Thanks GR Greathouse.
If I wanted to enumerate the primes over some tractable interval less than the largest known prime , would it be any easier given that at least one prime greater than the upper bound of the interval is known?
No, it would be just as hard. There's no good way to use that information.
I appreciate your patience with me. Just one more (two part) related question:
If I wanted to construct an unbroken sequence of all primes up to some prime p', would this limit be determined only by the limits of computability (brute force and/or algorithmic)? Is there any information regarding about what this limit might be?
Thanks in advance.
I don't mind answering your questions.
I don't understand what you're asking. But practically, if you want to make a huge list of primes, the issue you'll run into is storage: the memory needed for an efficient search (say, at least 20 * sqrt(n)/log(n) bytes to search up to n), and the hard drive (or whatever) space to keep the primes you find (say, 16 * n / log(n) bytes to store the primes up to n, or an eighth that amount for just the differences). So if you wanted a list of primes up to 10^20, you'd need several million terabytes of hard drive space (tens of millions unless you just store the differences).
SW VandeCarr said:
1)I'm trying to confirm that all primes up the largest known prime (or any arbitrarily large prime (p')) are in principle computable (Turing definition).
They are.
SW VandeCarr said:
2) Practically there is always a lot of interest in new largest prime, but none (as far as I can tell) as to the longest unbroken sequence of primes from 2 to p' . It seems such lists this would have utility for codes, "random" sequences and simply examining the statistical properties of such sequences. For example, do we know the first 10^6 or 10^7 primes?
There are algorithms that, given enough memory, can compute primes up to n faster than iterating through 1, 2, ..., n. So storage becomes the limiting concern there. You could fill a 250 GB hard drive with primes, but what then? It's often faster to generate them and use them on the fly anyway -- don't bother with the (slow) hard drive.
CRGreathouse said:
They are.
Thanks for your answers CRGreathouse. That's what I'll do.
CRGreathouse said:
May I ask what your application is?
I'm interested in the statistical distribution of primes as it relates to some interesting research in self-organizing processes. There's a number of papers on the net regarding this. I'm a retired epidemiologist.
CRGreathouse said:
They are.
Just out of curiosity and possibly to help the originator of this thread, can someone point to a source for such a list generating algorithm. I know of prime lists of the first n primes, n = 10,000 or lower are the typical lists of primes that I have seen, but as to the quickest or most powerful list generator, I have no idea of where to look.
The Sieve of Atkin is the asymptotically fastest method I know. Bernstein has an excellent implementation on his site.
Isn't it easier to use the formula by Riemann that gives an exact formula for pi(x) as a series involving the zeroes of the Riemann zeta function?
